Old 04-02-2007, 05:52 PM   #1
huda424
huda424's Avatar
huda424 is just really nicehuda424 is just really nicehuda424 is just really nicehuda424 is just really nicehuda424 is just really nicehuda424 is just really nicehuda424 is just really nicehuda424 is just really nicehuda424 is just really nice
Send a message via AIM to huda424
strange grinding noise
so finally i got rid of the stalling problem on my sr and the grinding noise came back. i would rev the engin to about 3000 when i let go of the gas i would hear a grinding noise. samething when i rev to 7000 rpms once i go past 3000 rpm i would hear a grinding sound. sounds like its coming from the bottom of the car, near the trans. any idea what it could be????
huda424 is offline   Reply With Quote
Old 04-02-2007, 06:06 PM   #2
pr0ject TRUENO
pr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfection
Send a message via AIM to pr0ject TRUENO
Piston chatter or from the actual transmission? It could be the clutch engagement or synchros. Does it grind when you put it into gear? How about when you depress the clutch?
pr0ject TRUENO is offline   Reply With Quote
Old 04-02-2007, 06:28 PM   #3
huda424
huda424's Avatar
it was making the same sound when it was in gear. i believe its more of a trans thing than pistons.
Old 04-03-2007, 09:43 AM   #4
origin_s135
origin_s135's Avatar
origin_s135 is close to perfectionorigin_s135 is close to perfectionorigin_s135 is close to perfectionorigin_s135 is close to perfectionorigin_s135 is close to perfectionorigin_s135 is close to perfectionorigin_s135 is close to perfectionorigin_s135 is close to perfectionorigin_s135 is close to perfectionorigin_s135 is close to perfectionorigin_s135 is close to perfection
yeah i also believe it's the transmission, same thing happened to my car, i forgot to get it checked up, and one day i hear something snap while driving on the freeway couldn't drive in gear, days later i ordered a new clutch kit, and my mechanic told me to get a transmission just to be safe, ordered it, opened the old one, and the synchros or the gears [ i forgot ] was all messed up, so thank god i ordered a newer one. btw, on the old one my clutch release sleeve was also fudged up. pic:
-robo
origin_s135 is offline   Reply With Quote
Old 04-03-2007, 12:16 PM   #5
huda424
huda424's Avatar
oh snap! um....i guess i have no choice but to get it checked out. how much does a trans run for these days??? 3-4 hundred???
Old 04-03-2007, 09:29 PM   #6
benefitx
Banned from the Marketplace
benefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choices
use the ka internals in the sr bellhousing
benefitx is offline   Reply With Quote
Old 04-04-2007, 12:44 AM   #7
sblack13
sblack13's Avatar
sblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud of
are you sure its the transmission?? i had a similar problem with my s14. it only lasted for about 1 day then the engine blew up.
sblack13 is offline   Reply With Quote
