Old 04-10-2007, 02:25 AM   #1
SR240DET
SR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud of
Send a message via AIM to SR240DET
How to: s14 ka mafs repair
So I have been having a weird problem fixing my stalling/bogging/hesitating problem for about a month. Nothing worked after I repaired and fixed everything that could possibly cause this problem. I wasnt throwing any codes so it made me think it was mechanical but i was wrong. this also fixed my buddys 240 that was throwing a mafs code.
If you are having a problem with stalling/bogging/hesitating, and it isn’t going away, start your car, and wiggle your mafs connector left and right kinda hard (but don’t break it!). If it stalls out check to see if their isnt any loose wires or it isnt dirty. If everything checks out good then you have a pretty common problem I have encountered for the past few years. take out your mafs and take off the 4 small Philips screws where the harness connector goes, and you will see your problem is inside. Sometimes the solder breaks loose and you get a bad connection. Here is how to fix it.
You will need:
1.small pliers
2.soldering iron
3.the really slim solder
4.heat shrink
5.something to cut with
6.heat gun
7. 20-22 gauge wire
First you want to remove the 4 small Philip screw on your mafs connector and remove that part from the mafs. Now you will take you connecter and pliers and bend the prongs down the opposite direction.(make sure you do all 3)
Take your mafs and hold it how I am in the picture, you will see 3 prongs sticking out and bend them down twards the writing that says flow. You don’t want the prongs to be down completely, just enough to stick your wire in there so you can get a good angle to solder.
Now take your 20-22 gauge wire and cut 3 1-2 inch strips. Strip both ends and apply a little solder to each end. I found it to be easier to solder the mafs first then the connecter part second. Now all you have to so is solder the wire to each of the correct ends. Make sure you use heat shrink as close as possible to each base of the mafs and connector.
Before you put it all back together make sure everything is good and tight. Shoving the wires inside the mafs is tricky, and try not to use any tools to shove the wires inside.
bolt your mafs back up and test it out
Well thats it i hope this will help some of you guys out. I honestly dont know if this will effect the mafs reading, but i havent had any problems for sometime now. If you are having similar problems try it out and make sure everything checks out good on your mafs reading with your DMM or consult. Good luck
SR240DET is offline   Reply With Quote
Old 04-10-2007, 02:34 AM   #2
chmercer
chmercer's Avatar
wierd. i have never heard of this being a problem area
chmercer is offline   Reply With Quote
Old 04-10-2007, 02:39 AM   #3
SR240DET
yeah me neither, my friend and i are just unlucky I guess, so I assume this was common. I have 5 s14 mafs that went bad on me and this is how i recently learn how to fix it.
Old 04-11-2007, 12:29 PM   #4
pbcstylez
pbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfection
Send a message via AIM to pbcstylez
this is odd, but i do see effects of crap messing up the connections, I just dont see how there's an opening that can get to those connections that you soldered?
also, any type of specific solder or flux?
pbcstylez is offline   Reply With Quote
Old 04-11-2007, 04:59 PM   #5
SR240DET
When you open up your mafs from the only place possible, you look at the top most part their should be 3 resister looking parts with little prongs sticking out. You need to bend that part down. It should be really easy to bend, because they have the consistency of solder. I will try to get some better pictures.
As for solder just get the really slim stuff, like if you where soldering a printed circuit board
Old 04-11-2007, 05:09 PM   #6
krappy
Trader Rating: (41)
krappy is an unknown quantity at this point
Feedback Score: 41 reviews
i had the same problem, bent the prongs so they could get a better connection and cleaned the prongs off....
krappy is offline   Reply With Quote
Old 04-11-2007, 05:12 PM   #7
pbcstylez
i wonder if PCB cleaner in a can will work?
Old 04-11-2007, 05:20 PM   #8
SR240DET
yep thats what happened to me. I just solder wires on so it wont ever happen again.
im sure it will, just do what krappy said if you dont want to solder anything.
Old 04-11-2007, 05:24 PM   #9
krappy
Trader Rating: (41)
LOL i used brake cleaner.... i shouldnt have but i did... it worked fine... just use a metal brush and brush off any build up on the prongs...
Old 04-11-2007, 05:27 PM   #10
pbcstylez
nice thanks for the input!
Old 04-11-2007, 11:02 PM   #11
swift_style
swift_style is a jewel in the roughswift_style is a jewel in the roughswift_style is a jewel in the roughswift_style is a jewel in the roughswift_style is a jewel in the roughswift_style is a jewel in the roughswift_style is a jewel in the rough
hey thanks for the write up sr24. I've been having the same problem and couldn't find out what was causing it. Plus I've been through two maf already. I'll check this out tomorrow. Thanks!!!
swift_style is offline   Reply With Quote
Old 04-11-2007, 11:05 PM   #12
SR240DET
good luck swift, just ask if you have any questions, and let me know if it works.
