Old 04-13-2007, 05:44 PM   #1
ghostracing
ghostracing's Avatar
ghostracing has made poor choicesghostracing has made poor choicesghostracing has made poor choicesghostracing has made poor choicesghostracing has made poor choicesghostracing has made poor choices
Send a message via AIM to ghostracing
b m short shifter HeLp NeEdEd!!
i kno this is probably pretty obvious , but im too tired to think straigh so i need some help. i took apart my b m short shifter in order to mount the plate to the top of the trans and in doing so one of the springs in the shifter fell out anyhow no that the trans is back up and im tryin to put the shifter in i cant remember which way everything goes between the small clip the spring and the small spacer that are all inside the shifter. and how the actual shifter sits in it -- in between everything else. and than on top of all that i cant remember if the freakin shifter is bent away or toward you. i kno i kno its NOOB MANIA on my end its crunch time and i got a million things goin on.
ghostracing is offline   Reply With Quote
Old 04-13-2007, 05:52 PM   #2
Bryants95240sx
Bryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the rough
Dude seriously learn english before posting again.
Bryants95240sx is offline   Reply With Quote
Old 04-13-2007, 05:53 PM   #3
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
Away from you.
The spring sits first, then the tiny spacer thing.
If you can't wrench in the SS, you should give up.
SochBAT is offline   Reply With Quote
Old 04-13-2007, 08:52 PM   #4
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
wait, y couldnt u mount the SS on without taking it apart? it should go on ez straight from the package
lexus baby
5t341tH is offline   Reply With Quote
Old 04-13-2007, 11:16 PM   #5
ghostracing
so uh... once again ^smart guy^ i appreciate the help but uh... wrong area! thanks you wanna teach english work @ a school other wise keep the misc. comments to your self ! thanks. anyhow i took the short shifter apart so that i could mount the plate and remove the shifter so that when i put the trans back up i could still have a place to put the trans fluid in. so yea thats why i took it apart. i kno bad choice on my part. uh i tried to put the springs than the small circle piece and than bracket and the ss ontop of all of that but there is too much play in there like maybe thats not the way its supposed to go, but hey maybe that is the right way.
Old 04-14-2007, 05:13 AM   #6
s13_gearhead
s13_gearhead's Avatar
s13_gearhead will become famous soon enoughs13_gearhead will become famous soon enoughs13_gearhead will become famous soon enough
Send a message via AIM to s13_gearhead Send a message via MSN to s13_gearhead
Um, trans fluid in? Are you filling your transmission from the shifter linkage opening?
s13_gearhead is offline   Reply With Quote
Old 04-14-2007, 02:59 PM   #7
ixfxi
Guest
Posts: n/a
ghost racing.
apparently not all there.
its a shift assembly, you take the ENTIRE unit off to fill up your transmission. THEN, you bolt the entire unit on when done.
serious, you cant figure this simple one out, eh?
dont forget, when you change an alternator - you disconnect your negative battery terminal. oh yeah, and when you change your oil, you should unbolt the drain bolt. hehe
Old 04-14-2007, 03:05 PM   #8
420sx
420sx's Avatar
420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future
well..... if you really want EASy...
.like 3 years ago i put my bm in which i sold. its only good for drag.
anyway. its very straightforward. but, to access top 2 bolts i just drilled holes in the tranny firewall. then after install slapped thick ass piece of dynomat - actually is queter now haha. but thats if u are lazy.
hydropgrahics!
ls1......
420sx is offline   Reply With Quote
Old 04-14-2007, 03:12 PM   #9
ixfxi
Guest
Posts: n/a
oh come on, thats so russian....
you dont need to cut the car to access those 2 bolts, you just need a proper sized wrench or ratchet - jesus...
i own a B&M shifter, besides the rattle (which i only had on the KA, not the SR).. the shifter is great. i really think its fantastic, and i canyon drive my car to shit.
i dont think there is a better shifter for our cars. just dont drill your chassis to install it!
Old 04-14-2007, 03:16 PM   #10
420sx
420sx's Avatar
haha. well when u dont know any better.lol... that was sooo long ago hehe. was one of my first mods. along with header and exhaust.
i welded a plate since then. but thats too much work for something so little. i dont like the way b&m feels for drift so i sold it... was great for drag
hydropgrahics!
ls1......
Old 04-15-2007, 12:32 AM   #11
onepuff
onepuff's Avatar
onepuff is on the path to ruinonepuff is on the path to ruinonepuff is on the path to ruin
you can also drill a hole in the shifter plate, tap it and put a bolt in it. easy way to have a trans fluid fill hole. just don't drill it while it's installed.
onepuff is offline   Reply With Quote
Old 04-15-2007, 05:43 AM   #12
SochBAT
Or just go buy a single drive adapter.
By Drive Adapter, i mean the open ended wrench with an opening for a ratchet.
Old 04-15-2007, 04:38 PM   #13
ghostracing
ok so let me get this right lol-- i kno i kno i should jus kept it together and bolted it on when the trans was up but like the other guy was saying i didnt have then right tool to do that since the last two bolts are a little further back so i figured id pour the trans fluid the area where the shifter sits and place it back in. so its the spring the space piece and than the shifter? on both sides? i jus wanna make sure because when i did that it didnt seem right since the shifter was still had a little too much play in it.
Old 04-15-2007, 04:46 PM   #14
kandyflip445
kandyflip445's Avatar
^^^ If you talked like that in person I would punch you in the face. At least put some effort in to your post so we can decipher what you're trying to say.
An easy way to fill your tranny up with fluid is to get a drill pump from Sears or any other tool place. Get some tubing and then fill it up through the fill plug on the side of the transmission.
When you get to it the front bolts are easier with a stubby 12mm ratcheting wrench and you can even drop the transmission crossmember a little to make it easier to get in there.
Good luck with it.
My 240 vBgarage
Old 04-15-2007, 04:57 PM   #15
onepuff
onepuff's Avatar
it's really easy to get to the bolts if u get your car up on jackstands. takes like 30 seconds to get to the front 2 bolts. take the whole thing out and start over. get it back together and install as one piece
Old 04-15-2007, 05:04 PM   #16
snappy
snappy's Avatar
snappy is an unknown quantity at this point
You could always jack up the car and tighten the screws from the bottom of the car.
Originally Posted by holemilk00 View Post
Its a 98 LE (leather edition)
snappy is offline   Reply With Quote
Old 04-15-2007, 05:34 PM   #17
projectRDM
projectRDM's Avatar
You'd get a lot more help if you appeared even remotely intelligent. People tend to ignore posts that look like a 4 yr old wrote them, including myself. If you're not even smart enough to use a keyboard, do you really need to be operating a car?
Old 04-15-2007, 08:56 PM   #18
ghostracing
ok people since the entire forum tends to think there is something wrong with my writing please be a little more specific than just randomly saying, "oh you need to learn how to write" or what ever other dumb a** irrelevant comments that are coming through here. what dont you seem to understand? what can't you decipher? the trans is up. the crossmember is bolted on. the b&m short shifter plate is mounted on the trans alllreaddyy. the issue is that i have already takin the ss apart. i am now attempting to to re-assemble the shifter, and since some of you are have such a difficult time understanding plain and normal english ill break it down further. at this moment i have the actual shift rod out along with the plate that holds it down and also i have two small one inch brackets, two 1/2-3/4" spings and a small 1/8" spacer. these are the items that i am trying to put back together. these pieces are why i have opened up this forum. so for those that have attempted to offer legitament help- thanks. and to everyone else that has post miscellaneous junk on my thread -- maybe its time for you to get off the computer and go do something else becuase its obvious your spending wayyyy to much time on here. go do something useful! i dont care if you opened up the forum and it was writtin greek! if you noticed-if u could read the title says in plain english--b m short shifter help need... i didnt read anything about me needing help speakin english!
Old 04-15-2007, 10:27 PM   #19
kandyflip445
1-818-882-6422
The number to B&M. They can tell you where everything goes!
The only problem with your situation is that you took apart the assembly. I haven't heard of anyone else doing this to install a B&M shifter or knockoff.
Try breaking down your posts in to paragraphs with each one relating to something else. In your last post above you could have whined in the first paragraph and made another paragraph for when you started to talk about what was wrong again. Also using capital letters at the beginning of sentences helps people read your post easier. It doesn't have to be perfect. Just generally people don't like to read through things written like crap, much less help the person afterwards. Reading through your first post is like when I try to drive my car through 1' of snow. I start to go, then all the crap piles up and I stop.
My 240 vBgarage
Old 04-16-2007, 01:03 AM   #20
s13_gearhead
May I offer a suggestion? If you used a digital camera to take pictures of what you needed help with as far as re-assembling your shifter into the transmission, I bet everyone could help out. I'm down to help you out also.
I did a B&M knockoff. The round spring that's not flat but kinda wavy goes in first. Then you slide the bottom of the shift rod through your plastic spacer and insert it into the transmission, making sure that the pivot point fits properly into the linkage connection housing. Then you slide your 1/8" plastic spacer on top of the shift rod pivot ball. On top of the plastic spacer sits the top plate, and the two brackets you have attach the plate to the shifter housing by sliding into the groove on the side of the shifter housing and then being snugged down by alan (sp?) bolts at the four corners of the plate. I've included a drawing that may help.
Old 04-16-2007, 11:44 PM   #21
ixfxi
Guest
Posts: n/a
hey, i take this post very personally, ya know.
first of all, i am greek.
second of all, i dont like doing useful things. i like doing nothing, which is why i post here.
you need to have more respect man. especially when talking to professional shit talkers who are extremely sarcastic.
peaceout
Old 04-17-2007, 03:06 AM   #22
SochBAT
Originally Posted by s13_gearhead
Thats not a B&M knockoff. Thats a C's knockoff or whatever.
B&M has a single rectangular plate that is a solid one piece design. The SHifter, IIRC, is also single onepiece design.
The shifter type shown above is ASS.
Old 04-17-2007, 04:31 AM   #23
s13_gearhead
Oh, right, actually I think it was an ASS knockoff. Wow, I spent 10 minutes drawing that picture, and it means nothing to this guy. lol.
Old 04-17-2007, 04:42 AM   #24
CoasTek240
CoasTek240's Avatar
CoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud of
Send a message via AIM to CoasTek240
+1 for taking your valuable time from whacking off, for this guy.
CoasTek240 is offline   Reply With Quote
Old 04-17-2007, 05:15 AM   #25
s13_gearhead
+1 for trolling
Old 04-17-2007, 04:12 PM   #26
SochBAT
Its been a while since i took apart that shifter, but again, the plate is a single piece.
Old 04-17-2007, 06:04 PM   #27
ghostracing
hey man thanks a million for the time you took drawing the picture. i appreciate it.
