Old 04-17-2007, 04:49 PM   #1
ni$$an_2fortysx
ni$$an_2fortysx has made poor choicesni$$an_2fortysx has made poor choicesni$$an_2fortysx has made poor choicesni$$an_2fortysx has made poor choicesni$$an_2fortysx has made poor choicesni$$an_2fortysx has made poor choices
Red face Rays extended lugs
Okay............so Im Thinking About Purchasing Some Of Rays Extended Lugs For A 92 Fastback, But Im Getting So Many Answers To As They Will Fit Or Not!
What Is The Real Deal?
Does It Fit Or Does It Not?
Is There Anything Needed Done To The Studs?
*anyone That Could Give Advice Will Be Greatly Appreciated*
ni$$an_2fortysx is offline   Reply With Quote
Old 04-17-2007, 04:54 PM   #2
ThatGuy
Admin Asshole
ThatGuy's Avatar
Stop typing with the CAPS LOCK button on!
Old 04-17-2007, 05:09 PM   #3
S13Dreamer
S13Dreamer's Avatar
S13Dreamer is just really niceS13Dreamer is just really niceS13Dreamer is just really niceS13Dreamer is just really niceS13Dreamer is just really niceS13Dreamer is just really niceS13Dreamer is just really niceS13Dreamer is just really nice
Send a message via AIM to S13Dreamer
You're talking about the Duranuts right? If so, I don't see why it wouldn't fit. I have them and they're fine. I've used them with the stock wheels and aftermarket. It never gave me an issue. Just make sure you get the correct thread pitch.
http://img.photobucket.com/albums/v118/s13dreamer/tobysig.jpg
S13Dreamer is offline   Reply With Quote
Old 04-17-2007, 07:41 PM   #4
arkive43
arkive43's Avatar
arkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud of
end thread/ thanx....
arkive43 is offline   Reply With Quote
Old 04-17-2007, 08:20 PM   #5
chmercer
chmercer's Avatar
get lugnuts that wont strip out and dont cost 100$
chmercer is offline   Reply With Quote
Old 04-17-2007, 08:28 PM   #6
Ian
Ian is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfection
just weld your wheels to the hubs...done and done...forever
Team Pterodactyl
SHARK ATTACK!!!
LookOutDrift
Originally Posted by Brian
No it isn't
This is "cool stickers"
not"let's make our car look like a pile of shit and dead babies"
Ian is offline   Reply With Quote
Old 04-17-2007, 10:39 PM   #7
crazyikimasho
crazyikimasho's Avatar
crazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond repute
agreed. Is there a particular reason you wanted these?
***PLEASE NOTE*** I am no longer affiliated with West Covina Nissan.
crazyikimasho is offline   Reply With Quote
Old 04-17-2007, 11:18 PM   #8
chmercer
chmercer's Avatar
^^^ theyre blue
people know they cost 100$
possibly some delusions of performance gain from .02 ounce weight savings
did i miss anything
Old 04-17-2007, 11:18 PM   #9
CoasTek240
CoasTek240's Avatar
CoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud of
Send a message via AIM to CoasTek240
for real those seems awefully pricey for extended lugs. whats wrong with the nismo ones. Maybe i got a steal, but i bought mine new from some kid for $40.
I need to install them cuz the ones on my 25mm koyei spacers are too short. I have GTO/attain hubs and stock Z32 hubs, and was inteding to install the nismo studs on them, but now i need to install them on the spacers. if ppossible
CoasTek240 is offline   Reply With Quote
Old 04-17-2007, 11:44 PM   #10
chmercer
chmercer's Avatar
ah i thought he meant nuts. maybe he means studs. if you want studs 10 moroso 10 arp is 40$ total new and are much better than nismo. there is a thread with the part numbers on here if somebody wants to search.
Old 04-18-2007, 11:54 AM   #11
ronmcdon
ronmcdon's Avatar
about wheel studs, i think here is the link. really good writeup, directions and overall info; they were moroso studs iirc purchased via summit racing. really wish i could have found that thread before i got the more costly arp studs
http://www.zilvia.net/f/showthread.p...ight=lug+studs
http://store.summitracing.com/egnsea...nresults=false
you can get arp studs, although they're not cheap. I got a set through splparts for my s14, and it came out to be around $120-$130. Had i known you could have gotten them for only $40, I would have done more research :P
http://www.splparts.com/Parts/Univer...es/default.htm
Old 04-18-2007, 02:33 PM   #12
A Spec Products
A Spec Products's Avatar
Yes, as stated, needs to be pitch 12x1.25 (Nissan)
Fits on aftermarket wheels with the proper taper
On stock studs you have no problem. With extended studs it depends on length of studs, but most likely will not fit, better to get an open ended in that case.
A SPEC PRODUCTS CORP
Old 04-18-2007, 04:52 PM   #13
kensreliableb18b
kensreliableb18b's Avatar
Location: so cal - 626, 909, 562 and 949. 818 if i feel like running away
kensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nice
i think he's talking about these:
http://www.zilvia.net/f/showthread.php?t=139383
nissan pitch n ull be cherry
kensreliableb18b is offline   Reply With Quote
Old 04-18-2007, 04:57 PM   #14
A Spec Products
Yeah, if it matters I have black extended in stock
Rays lugs are hard to keep in stock
Old 04-18-2007, 06:03 PM   #15
skate07
skate07 is making his/her stupidity well-knownskate07 is making his/her stupidity well-knownskate07 is making his/her stupidity well-knownskate07 is making his/her stupidity well-known
IM FEELIN THAT ^^^
for sure, it makes sense
[[[[ PSSSST, I LOVE YOUR MOMS NEGATIVE REPS ]]]]
skate07 is offline   Reply With Quote
Old 04-18-2007, 09:32 PM   #16
chmercer
chmercer's Avatar
late model gm arp studs fit s14 rear hubs, 10 dollars per 5 pack. come in 2.5 and 3.5 inch. front needs moroso studs. the arp studs take 12x1.5 nuts, moroso i forget the measurment like 7/16" nuts iirc? w/e
Old 04-19-2007, 10:42 AM   #17
kuruptR
kuruptR's Avatar
kuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfection
Send a message via MSN to kuruptR
screw those get these.
http://www.aj-racing.com/catalog/pro...3&cat=6&page=1
only about $520USD
@woooster on instagram
kuruptR is offline   Reply With Quote
Old 04-19-2007, 12:35 PM   #18
ronmcdon
ronmcdon's Avatar
lol, if i could afford that much for lugnuts i wouldn't even bother driving a 240.
Old 04-19-2007, 12:37 PM   #19
chmercer
chmercer's Avatar
i wonder how titanium heat expansion compares to steel wheel studs
i will stick with steel lugnuts since i can torque them to 100 and not worry about breakage
Old 04-20-2007, 03:26 PM   #20
clean_s14 (VIP ed.)
clean_s14 (VIP ed.)'s Avatar
clean_s14 (VIP ed.) can only hope to improve
Send a message via AIM to clean_s14 (VIP ed.)
the lug nuts to end all lug nuts, Kics Project R40. def. worth it for the price but the 5zigen pro racers come a close second in my opinion bein' that i'm somewhat biased since i have em'...
clean_s14 (VIP ed.) is offline   Reply With Quote
