Old 04-18-2007, 09:25 AM   #1
MeSs
MeSs's Avatar
MeSs has a spectacular aura aboutMeSs has a spectacular aura aboutMeSs has a spectacular aura aboutMeSs has a spectacular aura aboutMeSs has a spectacular aura aboutMeSs has a spectacular aura about
GT2871r, fitment thread number 2.
Since the old thread is 2 year old i would like to start a new one.
Maybe someone else have made/come up a better solution!!
Here is the old thread:
http://www.zilvia.net/f/showthread.p...hlight=gt2871r
I have the same problem, with a Megan Racing manifold.
Regards
2011 BMW F11 5-series and 2003 Nissan 350Z
MeSs is offline   Reply With Quote
Old 04-18-2007, 09:30 AM   #2
statik
statik's Avatar
statik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond repute
Send a message via AIM to statik Send a message via MSN to statik
clock the compressor housing and modify the wastegate bracket, whats the problem?
That's exactly what I had to do for my gt28rs, just flip the bracket and space it out with longer bolts/washers.
97 240sx esaarr | Current Status: SOLD
statik is offline   Reply With Quote
Old 04-18-2007, 09:38 AM   #3
MeSs
MeSs's Avatar
Where does the compressor outlet point then? Down?
Old 04-18-2007, 09:45 AM   #4
slider2828
slider2828's Avatar
Just clock the turbine housing to the angle of your T25. Just monkey see monkey do and then poundthe actuator holder plate till it is flat and your set. You can use a hammer on concrete or better cover it with a towel and pound it.
Old 04-18-2007, 09:59 AM   #5
statik
statik's Avatar
clock it enough so that the outlet clears the manifold and the wg bracket still bolts on
You can see the wg bracket is flipped from how it comes normally
Old 04-18-2007, 11:04 AM   #6
MeSs
MeSs's Avatar
Can i get a picture from front?
Old 04-18-2007, 11:13 AM   #7
MeSs
MeSs's Avatar
I belive the wastegates your picturing is different.
Old 04-18-2007, 11:16 AM   #8
statik
statik's Avatar
ok, well I can't see what actuator you are using since you didn't post a picture of it. How about this: clock the turbo, make the wg bracket fit, if you can't, make a bracket, or buy a bracket like the one pictured from atpturbo
Old 04-18-2007, 03:42 PM   #9
MeSs
MeSs's Avatar
Made it, thanks guys.. But the wg seems to be a bit tight in there.
Old 04-18-2007, 03:48 PM   #10
statik
statik's Avatar
You can notch the holes in the wg bracket so the actuator can slide a bit to center the arm, hook up a compressor to the actuator and make sure it opens ok, ive had the actuator arm not move and let the air blow by it due to a bad angle.
Old 04-18-2007, 03:50 PM   #11
MeSs
MeSs's Avatar
Thanks.. Will do!
