Old 04-18-2007, 10:33 AM   #1
Bigballin
Bigballin's Avatar
Bigballin is an unknown quantity at this point
POS CAR! (Z32 brake convo) update!
original problem seems to be fixed...... BUT
now my rear is locked up, meaning when i put it in gear it wont move. wtf is going on???
Bigballin is offline   Reply With Quote
Old 04-18-2007, 10:47 AM   #2
!Zar!
!Zar!'s Avatar
First bleed your brakes then start the car up. To try and seat the pads.
If the piston is still sticking out enough to compress against the rotor then of course the hub won't spin.
Old 04-18-2007, 01:41 PM   #3
Bigballin
Bigballin's Avatar
this is fuckin ridiculous. i might have to burn this car
Old 04-18-2007, 03:09 PM   #4
drift_ricer
Banned from the Marketplace
drift_ricer is on the path to ruindrift_ricer is on the path to ruin
did u put the hub bearing into the rear axle fit right. and e brake lock or or not?
drift_ricer is offline   Reply With Quote
Old 04-18-2007, 03:15 PM   #5
Bigballin
Bigballin's Avatar
im using the J30 assembly which the Hub is pressed in and i dont have ebrake... it feels like the ebrake is up though
Old 04-19-2007, 01:38 AM   #6
Bigballin
Bigballin's Avatar
anyone might know it feels like the ebrake is up when its not even connected??
Old 04-19-2007, 09:45 AM   #7
emersonLP
emersonLP's Avatar
emersonLP has a reputation beyond reputeemersonLP has a reputation beyond reputeemersonLP has a reputation beyond reputeemersonLP has a reputation beyond reputeemersonLP has a reputation beyond reputeemersonLP has a reputation beyond reputeemersonLP has a reputation beyond reputeemersonLP has a reputation beyond reputeemersonLP has a reputation beyond reputeemersonLP has a reputation beyond reputeemersonLP has a reputation beyond repute
Send a message via AIM to emersonLP
So you do have the ebrake assembly installed? just no cables? Maybe you need to adjust the ebrake drum. There is a little hole to adjust the ebrake through the rotor iirc.
emersonLP is offline   Reply With Quote
Old 04-19-2007, 11:07 AM   #8
Bigballin
Bigballin's Avatar
i dont have the ebrake assembly installed just the calipers and rotor
Old 04-19-2007, 12:14 PM   #9
emersonLP
emersonLP's Avatar
Is the caliper squeezing the rotor or is there something else inhibiting the wheel from spinning?
Old 04-19-2007, 12:36 PM   #10
Bigballin
Bigballin's Avatar
i took off the calipers and rotors and the axle still would not spin when i put it in gear. so i took off the axle nut on both sides and everything worked correctly. so now im wondering if it is possible to have to axle nut "too" tight??? something just doesnt seem right
Old 04-19-2007, 12:48 PM   #11
chmercer
chmercer's Avatar
haha no you cant have the axle nut too tight. iirc the torque for it is somewhere in the neighborhood of 300 pounds.
maybe you have shitty wheel bearings or something? i dunno
chmercer is offline   Reply With Quote
Old 04-19-2007, 01:16 PM   #12
Bigballin
Bigballin's Avatar
any way to confirm that my bearings are fucked up i just got the j30 assembly
i really dont want to sell this bitch...
Old 04-19-2007, 07:52 PM   #13
drift_ricer
hey bigballin, at first I got the j30 same like u two week, but I just change my though last week, decided to install the z32. I just got done one side today. it look nice. sell the j30 and go with z32
Old 04-19-2007, 08:12 PM   #14
Bigballin
Bigballin's Avatar
ya i think im going to sell it. but now i have to find s14 assembly cause i sold mine should be parting out this chassis and moving on to another
