Old 04-24-2007, 07:54 PM   #1
CRZY_AZN
CRZY_AZN is an unknown quantity at this point
Electrical Problem!!
ok well I've been searching for a bit and cant find any thing.
the other day i took my car out for a spin (i haven't driven out past my block for bout 2-3 months) well any ways i got my friends shop and when I'm leaving i goto start my car i put the key in and well the nothing happens n the clock just dies after i remove the key it comes back on. so i think hum maybe its just a weak battery so i try again this time the clock just dies and this time doesn't come back on. so i check my circuit breaker and the fuses and everything is fine. so i get my friend to give me a jump start but nothing happens. ive tested the battery n everything is ok. so now my car has no power what so ever. the clocks arent on and the lights dont go on. so im not sure what it is.
CRZY_AZN is offline   Reply With Quote
Old 04-24-2007, 08:01 PM   #2
Nismotech91
Nismotech91 is an unknown quantity at this point
i had the same problem with my 240, i had enough volts but when i went to crank it my voltage dropped below 9 volts. I juss replaced my battery and everything worked.
Nismotech91 is offline   Reply With Quote
Old 04-24-2007, 08:01 PM   #3
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
El grounds. check em out. and get back at us.
Review Thread
bardabe is offline   Reply With Quote
Old 04-24-2007, 08:02 PM   #4
JDMClifford
JDMClifford's Avatar
JDMClifford is an unknown quantity at this point
do you have your battery reloacated? maby you should look behind the steering wheel and see is a whire came loose on the ignition. or look for burnt wires or a "burnt" smell.
Parking lot pimping
JDMClifford is offline   Reply With Quote
Old 04-24-2007, 08:35 PM   #5
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
make sure your battery terminals are tight on the posts on the battery. if they are then follow the ground and make sure where it bolts to the chassis is tight, and the engine is tight. as far as the positive, it runs to your starter and alternator, make sure both those nuts are tight. if all that is good, then pull on the battery cables, spin around three times, and say oOOOOooo BUKAKE!! @_@ and your car will magically start =]
Z U L8R is offline   Reply With Quote
Old 04-24-2007, 08:53 PM   #6
CRZY_AZN
yea my battery is located in my trunk. i have checked the connections of the battery and the grounds everything looks fine. tomorrow ill check under the steering wheel for loose wires.
Old 04-25-2007, 08:15 PM   #7
CRZY_AZN
sup, well i checked the fuses again and under the dash. i found a loose wire under the dash n reattached it but it still isnt working.
Old 04-25-2007, 08:19 PM   #8
statik
statik's Avatar
statik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond repute
Send a message via AIM to statik Send a message via MSN to statik
check the main fusible links in the engine bay?
97 240sx esaarr | Current Status: SOLD
statik is offline   Reply With Quote
Old 04-25-2007, 09:14 PM   #9
ixfxi
Guest
Posts: n/a
sounds like a loose connection, either power or ground.
you already checked voltage at your battery, check voltage INSIDE the cabin of the car. also, just because a battery has sufficient voltage, doesnt mean it has amperage. whats the condition of your battery? do your headlamps turn on, and are they bright? all of that should be checked.
Old 04-25-2007, 10:08 PM   #10
CRZY_AZN
well thats the problem. im not getting any power what so ever nothing is on.
Old 04-25-2007, 10:30 PM   #11
kouki_kouki
kouki_kouki's Avatar
kouki_kouki is making a name for him/her selfkouki_kouki is making a name for him/her self
Send a message via AIM to kouki_kouki
you should try to grind the battery terminals with a grinder or a file. maybe there is too much residue on there.
kouki_kouki is offline   Reply With Quote
Old 04-26-2007, 04:40 PM   #12
CRZY_AZN
ok well i got a volt-meter. i check my batt n it is 12.6v then i went the the front and check with everything attached and it was .67v so im thinking it might be a loose ground wire somewhere. any ideas?
Old 05-03-2007, 10:32 PM   #13
CRZY_AZN
i finally had more time today to work on it today. and i found out that the wiring from the battery that goes to the alternator fuse is the one that is draining all the power. i looked in the fuse box n everything looked ok. i even took it apart and all of the sudden the power in my car went back one. then i went to test it and start it and well the electrical system took another crap on me. so i dont know exactly what is going on. if anyone could plz help me.
Old 05-04-2007, 08:06 AM   #14
Sileighty_85
Sileighty_85's Avatar
Sounds like a short, look for wires melted together in that box or open wires grounding on the chassis
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 05-04-2007, 08:28 AM   #15
drifting_changed_mylife
drifting_changed_mylife's Avatar
drifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymore
Send a message via AIM to drifting_changed_mylife
aint nothing worse for me than electrical problems!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
drifting_changed_mylife is offline   Reply With Quote
Old 05-04-2007, 12:45 PM   #16
pbcstylez
pbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfection
Send a message via AIM to pbcstylez
my guess is you have a short on your power wire trace it through your car, how did you run this wire? perhaps it got clipped by somethign?
parking lot pimpin...
Seller Feedback here:
http://www.zilvia.net/f/showthread.p...ight=pbcstylez
pbcstylez is offline   Reply With Quote
Old 05-04-2007, 03:24 PM   #17
bongnak
bongnak's Avatar
bongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of lightbongnak is a glorious beacon of light
haha dont you hate when that happens...those unknown shorts or loose connections? yeah just open up the box and maybe even the wire loom and look for open lines, a buddy had something similar prob where the maf wires was rubbing up on the intake plenum and after sometime finally cut through.
Zzzz
bongnak is offline   Reply With Quote
Old 05-04-2007, 11:08 PM   #18
CRZY_AZN
well after i unscrewed the fuse box. and tried to trace the wiring. n after messing around wit it all of the sudden my electronics went on. i went to try and start it but it wouldnt start. so theres something but i dont know where cuz goto.
