Old 04-30-2007, 07:27 AM   #1
speedgod^s13
speedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond repute
Send a message via AIM to speedgod^s13
C's short shift with tomei duracon shiftknob
Is anyone else running this combo? If so, does your shifter sit really high? I currently have this setup, and was going to buy a pimpin new shiftboot. I thought, I should ask this first, just in case. Because, I may just have to buy a new short shift kit, if I can't find the solution to this problem. I don't think my shiftknob, has that much to do with it. Also, i'm pretty sure I installed it correctly, since I have been driving it for a long time. Shifts are crisp, and short. Just don't get why it sits so high.
speedgod^s13 is offline   Reply With Quote
Old 04-30-2007, 09:22 AM   #2
Ian
Ian is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfection
Because it's a full length shifter opposed to a shorter shifter...
It'll be fine
Team Pterodactyl
SHARK ATTACK!!!
LookOutDrift
Originally Posted by Brian
No it isn't
This is "cool stickers"
not"let's make our car look like a pile of shit and dead babies"
Ian is offline   Reply With Quote
Old 04-30-2007, 09:23 AM   #3
bigOdom1
bigOdom1's Avatar
bigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfection
also depending on the knob it may sit higher due to its design
bigOdom1 is offline   Reply With Quote
Old 04-30-2007, 10:17 AM   #4
ronmcdon
ronmcdon's Avatar
It'll be fine
Hmmm is the C's the similar to the nismo shifter? I know the nismo is about the same shift distance as stock. i wonder if this is any coincidence.
Sorry to get somewhat ot, but i'm actually looking for a new shifter with stock throw distances. initially i was set on the nismo shifter. however, it seems like the C's are a bit cheaper than the Nismo units. if thats the case, the C's would prob be a better buy.
back on topic. to the OT, try throwing back on your stock shift knob onto the C's shifter and see if that helps. At the very least you'll find out whether it was the new shiftknob or the actual shifter (or a bit of both) that contributes to the height of the overall shifter setup. BTW - thanks a lot for the info! coincidently, i happen to be very interested in long shifter, and i like the idea of rubber based shiftknob. one man's trash is another's treasure I guess.
Old 04-30-2007, 11:21 AM   #5
Ian
get a stock shifter
Team Pterodactyl
SHARK ATTACK!!!
LookOutDrift
No it isn't
Old 04-30-2007, 11:48 AM   #6
upSLIDEdown
upSLIDEdown's Avatar
Location: VA.. And for those that keep PMing me asking what kit I have, it's Origin Stream.
upSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfection
C's shifter is a short throw shifter. NISMO is stock throw, with a more solid feel. Both are the same physical height as stock. Most "short shifters" will shorten the throw, but the physical height will be the same. You could always cut the shaft down shorter, although you may have to turn the big bulge down on a lathe and rethread it, and that may be more work than you want to do.
upSLIDEdown is offline   Reply With Quote
Old 04-30-2007, 01:20 PM   #7
C. Senor
C. Senor's Avatar
C. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfection
Send a message via AIM to C. Senor
if you really want a short shifter hieght you can try the b&m shifter with the leather nismo shift knob...used to have that and it was pretty ****** short. atleast for me.
C. Senor is offline   Reply With Quote
Old 04-30-2007, 03:26 PM   #8
ronmcdon
ronmcdon's Avatar
thank you for illustrating the mechanism so clearly. I think I know exactly what you mean by now. I will look for the nismo instead of the C's, as I wish to retain the stock shifting distances (along with the more solid feel, prob from the stiffer nismo shifter bushings). so much for saving a few bucks, lol.
Old 04-30-2007, 03:37 PM   #9
JDMClifford
JDMClifford's Avatar
JDMClifford is an unknown quantity at this point
i have an ebay shifter, same hight as stock just amore machanical feel ans shorter throw.
Parking lot pimping
JDMClifford is offline   Reply With Quote
Old 04-30-2007, 04:26 PM   #10
ronmcdon
ronmcdon's Avatar
get a stock shifter
what I'd like to know is how the stock shifter differs from the nismo unit. ppl frequently note on different threads and merchant sites that the nismo shifter is somehow more 'solid', while retaining close (if not exact) to oem shift distances. my guess is that the difference is prob due to stiffer bushings, or it could be just psychological.
It may not be very scientific, but it prob choosing the Nismo shifter is the safest choice. at the very least, it can't be worse than stock. note that I haven't actually purchased or decided on a shifter yet. im still discussing what I plan to replace my worn out sloppy shifter with. nismo seems to be the best bet so far.
The HKS shift return spring kit seems like an interesting gimmick to play with too, as it seems to allow the user to adjust the degree of stiffness for the shifter feel. its a shame its kinda pricey, but maybe I'll check it out;
http://www.frsport.com/HKS_27006_AN0...ET_p_1353.html
Old 04-30-2007, 04:45 PM   #11
apexhumper
apexhumper's Avatar
apexhumper is on a distinguished road
Thread jacking mode: On
just curious, is the C's shifter worth the extra mula over the B&M? I've been thinking about getting it, I keep reading it's the best one but dont know anyone running it so not sure. Any info would be great. Thanks.
Thread jacking: Off
Dont sweat the petty things, pet the sweaty things.
apexhumper is offline   Reply With Quote
Old 04-30-2007, 04:57 PM   #12
Full-Lock
Full-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfection
Send a message via AIM to Full-Lock
i heard the b&m rattles a lot..but i dunno
dont quote me on that
Full-Lock is offline   Reply With Quote
Old 04-30-2007, 04:59 PM   #13
tacotacotaco
tacotacotaco's Avatar
tacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfection
Send a message via AIM to tacotacotaco
My friend has a b&m and it sounds like theres a buzzard in his car.
tacotacotaco is offline   Reply With Quote
Old 04-30-2007, 05:12 PM   #14
ronmcdon
ronmcdon's Avatar
Thread jacking: Off
was that a typo? I was under the impression that B&M's were more expesive than the C's. i thought the C's was around $190, while the B&M's were around $240. Which happens to be better is a matter of personal preference. get in touch with ppl who have them and decide for yourself. I had the chance to mess with someone's Nismo shifter and I liked it very much.
Old 04-30-2007, 06:16 PM   #15
apexhumper
apexhumper's Avatar
Well I'm looking for a short shifter, from what I read in this thread the Nismo is stock shift throw isnt it?
Old 04-30-2007, 08:05 PM   #16
speedgod^s13
I have heard good, and bad things about the B&M short shifter. Even with their newest version, I heard it's still noisy, at certain rpm's/speed. I'm very happy with my c's. The shifting, is precise, and crisp. Also, my tomei duracon shiftknob is ftw action. It doesn't heat up, even when it's sitting in direct sunlight. Get's warm, but nothing more. The only reason I brought this up, is because I was thinking, that it would look funny with the new shiftboot. Since, it seems longer than stock, an inch, or inch and a half would be sticking past the boot, not including the shift knob. Oh well, i'll just get the boot, and see how it looks. Off topic, but I am looking for some parts. I only got the rubber accordian, piece, that surrounds the shifter, from the tranny. I need everything else, that goes from the tranny, to the shifter, including all the bolts.
Old 04-30-2007, 10:49 PM   #17
C. Senor
C. Senor's Avatar
haha the b&m is awesome....its ridiculously short and somewhat notchy. and yes it does vibrate at high rpms. on my car it vibrates above 5000. but its a small price to pay for the shortness of the throw.
Old 04-30-2007, 11:05 PM   #18
jspecusa
jspecusa's Avatar
jspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfection
Send a message via AIM to jspecusa
I replace the metal shiftnob from the B&M shifter to a nismo plastic one and it doesn't vibrate anymore.
Plus I don't get burn or freeze when I shift during summer/winter.
Nissan Japan: "road to happiness has many curves"
Jdmlivin: "Jdm is dead, the yen is crazy"
jspecusa is offline   Reply With Quote
Old 05-01-2007, 12:27 AM   #19
sideview_180sx
sideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to behold
Send a message via AIM to sideview_180sx Send a message via Yahoo to sideview_180sx
jspecusa is the man......he knows what he is talking about.
feel the rythym. feel the ride. get on up. it's bobsled time. COOL RUNNINGS!!!
formerly sideviewcivic
Save a Horse. Drift This Cowboy.
AirBag Club Member #0014
sideview_180sx is offline   Reply With Quote
Old 05-01-2007, 12:35 AM   #20
jspecusa
jspecusa's Avatar
"sharing is caring"
share your experience and let other learn from it.
I think there should be more thread on useful topics like
"favorite tool while working on s chasis"
"tips and tricks you learn while owning your car"
"what not to do list"
"to do list"
"favorite brand of xoxoxo and why"
Old 05-01-2007, 01:28 AM   #21
ronmcdon
ronmcdon's Avatar
yeah that does appear to be the consensus' decision. I tried searching about this before. I haven't read that anyone had actually measured and compared the throw distances, but if there is any difference its prob negligible for the most part.
Old 05-01-2007, 11:43 AM   #22
apexhumper
apexhumper's Avatar
I've actually seen the exact opposite, B&M for about $180 or so and C's for almost $300
Isn't the C's also discontinued?
Old 05-01-2007, 01:46 PM   #23
speedgod^s13
Yeah, i'm pretty sure the C's has been discontiued for a while now. I don't care how good a shifter is, but if it makes noise, I ain't buying it. Guess i'm sticking with the JDMness for nowl
Old 05-01-2007, 07:25 PM   #24
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
C's are considered some of the best shifters in the business. BM is a copy of the C's.
Old 05-01-2007, 08:11 PM   #25
C. Senor
C. Senor's Avatar
^sounds about right. i still love my b&m though.
Old 05-01-2007, 08:12 PM   #26
Phlip
Yes, I look like that
Phlip's Avatar
"best" is a matter of subjective opinion, really.
Some like C's, some like OBX (God, why?) and some just like their soft quiet stockers (PM me if you want to buy one for $cheap.99).
My opinion? B&M, and if the rattle is a problem, turn the radio up.
I have ALSO found that there is a specific shifter floating about ebay that is a knockoff of the B&M, boasting the SAME shift feel, appearance and (yes, also) that rattle. No one has complained of failures or questionable build quality, I know of a couple of other people ON THIS SITE using it...
I had a $200something B&M in my S14 before I cartwheeled it, I sold it after the fact, I have that knockoff in my S13 and I cannot for the life of me figure out why I paid 3 times what I paid for this one for an identically performing B&M.
My knob is a custom one, link below the photo in my signature for details on that.
Weirdo
And I write too!
Old 05-01-2007, 08:13 PM   #27
JDS Performance
JDS Performance's Avatar
Trader Rating: (53)
JDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of light
Feedback Score: 53 reviews
I have the ebay B&M knock off - I love it minus the buzzing and rattling - its really bad at high RPM - numbs your hand while it rattles your hand - but I am using the metal shift knob it comes with too - a Nismo knob would help this.
I read a while back about fixing the rattling but cant seem to find it now? it may have been on another site?
Also you need the stock shifters plastic piece on the bottom that goes into the hole of the stricker arm - as the one that comes with the knock off shifter wont fit into the hole.
Agrees with "PHLIP" 100%
JDS Performance is offline   Reply With Quote
Old 05-01-2007, 10:40 PM   #28
jspecusa
jspecusa's Avatar
If you put B&M and C's side by side they are not even close.
B&M developed the shifter on MAV1178's s13 then test fitted on Kyle's S14, final version went on my old yellow s13.
I've been at their headquarter many times, they have real engineer there that does R&D for them.
I gave them test run up and down De soto so they can figure out the noise problem, I told them just get rid of the metal shiftknob which I did later.
B&M is my favorite shifter as well, but I can't justify paying over $200 for one.
To me, you should only spend a certain amount on a car(it's totally waste of money) and use it on useful mods then expensive name brand stuff(cough ARC).
Old 05-01-2007, 11:26 PM   #29
slapinfunk
slapinfunk is on a distinguished road
Send a message via AIM to slapinfunk
My C's shifter with NISMO GT-TI shift knob sits and shifts just fine
slapinfunk is offline   Reply With Quote
Old 05-01-2007, 11:42 PM   #30
Dousan_PG
Dousan_PG's Avatar
i use an Uras
shits awesome
slightly shorter
solid!
and sits stock heights
its the best
my friend drove my car once
and ordered it.
Aaron
Pink GodziRa
