Old 05-05-2007, 05:00 PM   #1
nissandriftky
nissandriftky is an unknown quantity at this point
Send a message via AIM to nissandriftky
SR only 1 injector firing in my sr
ok here is my issue...
after hours of searching i come to zilvia
i'm a longterm nico club fan and there stumped so lets see what you guys think...
installed sr in 90 240...yes yet another install problem..make a long story short
had no spark fixed that,transmission nuetral switch
had no fuel fixed that, walbro 255
now i only have one injector firing...i used some starter fluid and the darn thing runs great. but i'm only getting fuel out of my injector near the fire wall. i hope my ecu is not screwed any ideas?
nissandriftky is offline   Reply With Quote
Old 05-05-2007, 05:36 PM   #2
'90RPS13
'90RPS13's Avatar
'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute
Send a message via AIM to '90RPS13
getting power to the injectors?
'90RPS13 is offline   Reply With Quote
Old 05-06-2007, 12:27 PM   #3
nissandriftky
yes, all four injectors have two wires to them one of wich is always hot the other i'm asuming is a signal wire
Old 05-06-2007, 12:59 PM   #4
drftwerks
well get a test light,
clip to B+ on batt
and back probe on the injectors, the one thats not hot at all times, see if it blinks, if not the backtrace to the ecu, see if there is any breaks or something, if not, then i would say try another ecu.
giantroboteyes.wordpress.com/
Old 05-06-2007, 03:32 PM   #5
nissandriftky
i took the fuel rail off and hooked fuel up swictched the wires around and tried to start then none of the injectors did anything which tells me that the injectors must be bad not signal cuz if there was no signal then the first injector wire should fire on the second injector (wrong order but should still squirt right?)
oh and i had my fuel lines crossed at first so maby i could of got some trash in the injectors? any way to clean them, or get some new ones?
Old 05-06-2007, 06:05 PM   #6
shayrgob240
shayrgob240's Avatar
shayrgob240 is an unknown quantity at this point
Send a message via AIM to shayrgob240
First of all, learn some grammer. Secondly, get yourself a test light.
Actually, if you want to do this according to the textbook, buy yourself a noid light kit. But since you probably don't want to spend the $ just use your test light to see that the ECU is switching the injectors on/off. If there isn't any switching...follow the wiring to ECU and see if there's an issue. If there is injector switching, then the electrical side of things are A ok, but that doesn't tell us anything about how the injector is mechanically. The injector could be stuck closed, hence no fuel. Just do these basic tests and get back to us.
shayrgob240 is offline   Reply With Quote
Old 05-07-2007, 06:07 AM   #7
nissandriftky
haha.. zilvia mods please add spell check
i'm jk
anyway, well i do have a test light. and i did do that.
secondly after this post i went home and swapped the injector that was working #4 with #1 injector and it fires so i put an order in for some new injectors...i think this should get me running. oh and by the way
Ithink i like zilvia better than nico
haa oh sh*t i just notest there is a spellcheck
Old 05-07-2007, 07:35 AM   #8
S14DB
AFC #1
S14DB's Avatar
get FireFox and Google toolbar. Both have spellcheck.
Old 05-07-2007, 08:17 AM   #9
nissandriftky
I've got spell check i was just being stupid...your mom goes to college!!!
seriously though thanks for the help ....
Old 05-09-2007, 05:44 AM   #10
nissandriftky
she's ALIVE!!!! finally thank you i took out for a spin last night runs absolutely sweet! thanks alot to all
ps.
sorry for the run on sentenance, exited!
i'll try to post some pics so you can see what you helped me with
