Old 05-06-2007, 07:45 PM   #1
MacDrevi0us
MacDrevi0us is on the path to ruinMacDrevi0us is on the path to ruin
s13 My car stumbles like a drunk
92' Coupe 5spd. Only thing done to the engine is intake at this point. Car has also been seafoamed but it did not help this problem.
Ok so ive been doing a lot of reading about this because its a problem that ive had for a while, but heres the deal. Im basically have a type of idle issue. When i start up the car cold its totally fine ive NEVER had a problem with the idle on a cold start. When i notice it the most is ill be coming off the freeway and ill shift into neutral and the rpm's will drop to about 3-400 and sometimes stick and then pop back up. Its like the idle isnt catching it. Same thing happens when i start the car when its already warm. But now recently something new has started where when im sitting at a light it will bounce up and down. Ive read that this is commonly IACV which gets easily clogged with crap but im wondering if there are any other possible solutions for these symptom? Also, if someone has a picture of the location of IACV assembly that would be great. I saw it in a thread on here but cant find it anymore. Thanks
MacDrevi0us is offline   Reply With Quote
Old 05-06-2007, 08:20 PM   #2
lazierhobo
lazierhobo is on the path to ruinlazierhobo is on the path to ruin
IACV is a cylinder sort of thing attached to the intake, after the throttle plate. should be held on by a couple of small bolts. when you take it off, you will easily be able to see how to clean it. sorry i dont have any pictures, but if you have a FSM you will be able to see it.
lazierhobo is offline   Reply With Quote
Old 05-06-2007, 08:24 PM   #3
benefitx
Banned from the Marketplace
benefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choices
run seafoam in the IACV tube
benefitx is offline   Reply With Quote
Old 05-06-2007, 10:14 PM   #4
MacDrevi0us
Aite thanks for the feedback it was very helpful. Is there only one tube on the IACV? And if not which one should I run seafoam into?
Edit: Also is this something a new fuel filter might solve or are these symptoms not typical for that?
Thanks in advance i cant wait to figure this out
Old 05-07-2007, 01:27 PM   #5
beetlejuice
beetlejuice's Avatar
beetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura about
The IACV is on the underside of the intake manifold, near the firewall.
There is a hose going from the stock intake tube to a metal tube (underneath the upper portion of the intake manifold), which leads to the IACV. It is the larger of the two hoses connected to the intake tube, a few inches from the throttle body.
You want to spray seafoam, carb cleaner, etc in this tube while the engine is running.
If you have ABS, it will be extremely difficult to get your hands on the IACV unit itself, as the ABS control module thing in the corner of the engine bay is a monster.
jollydwarf.com
beetlejuice is offline   Reply With Quote
Old 05-07-2007, 01:36 PM   #6
Canaduh
Canaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of light
after a 10 second search i found this...
http://www.zilvia.net/f/showthread.p...ght=idle+screw
It shows you the hose to disconnect and spray throttle body cleaner into.
Done it to my car many times, very simple.
Canaduh is offline   Reply With Quote
Old 05-07-2007, 04:29 PM   #7
MacDrevi0us
thanks for the info i appreciate it!
edit;;Just swapped the fuel filter with the z32 one. big difference but not solved yet so next is cleaning of the iacv.
