Old 05-07-2007, 04:19 PM   #1
REVo
REVo's Avatar
REVo is on the path to ruinREVo is on the path to ruin
KA Header problems?
alright let me start by saying i have searched through many threads reading about others problems with o2 sensors and mafs...i just help install some pace setter headers on a 89 240sx ka24e, the install went in flawlessly....we took it for a test drive and where noticing that when we put our foot down the car was hesitating and bogging...with a huge lost of performance...the next day we checked the codes and where getting a code 55 ( no problems ).... so we tried it again and same thing...
today we changed the o2 sensor thinking it could be that...which made it not hesitate and bog so much but we still have a huge lost of performance..i thought it could be the MAF but where not getting any code for it...
Any help is greatly appreciated and thank you in advance.
WTB: 89-94 240sx coupe auto or manual pm
REVo is offline   Reply With Quote
Old 05-07-2007, 09:06 PM   #2
REVo
REVo's Avatar
Still same problem...
Old 05-07-2007, 10:08 PM   #3
Creizai
Creizai has a spectacular aura aboutCreizai has a spectacular aura aboutCreizai has a spectacular aura aboutCreizai has a spectacular aura aboutCreizai has a spectacular aura aboutCreizai has a spectacular aura about
Well start off by making sure you dont have any leaks on any of your gaskets of your new header. Also make sure when you torqued down the bolts you went in the order the manual of your car.
Creizai is offline   Reply With Quote
Old 05-07-2007, 10:39 PM   #4
REVo
REVo's Avatar
just went out retorqued and checked the gaskets everything was as it should be...went for another test drive and same thing
Old 05-08-2007, 10:58 AM   #5
allmotorKA
allmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really nice
Double check your spark plug wires. Firing order might be off.
allmotorKA is offline   Reply With Quote
Old 05-08-2007, 11:44 AM   #6
REVo
REVo's Avatar
Wires are on there good and tight..
Old 05-08-2007, 01:28 PM   #7
240trainee
240trainee's Avatar
240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection
Send a message via AIM to 240trainee
If you installed headers on a KA-E, that would be your problem right there, you have something extra
but yea, check the wire to the o2 sensor, but it should still run.
check firing order
check for exhaust leaks.
other than that I dunno.
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
240trainee is offline   Reply With Quote
Old 05-09-2007, 12:23 PM   #8
REVo
REVo's Avatar
Pulled off the pace setter headers and put the stock ones back on...still same problem..it only really hesitates under full acceleration.
Old 05-09-2007, 12:47 PM   #9
los_inc
los_inc's Avatar
los_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond repute
Send a message via AIM to los_inc
remove your egr.
and check if you can
rev past 2500 rpm
-los
los_inc is offline   Reply With Quote
Old 05-09-2007, 01:00 PM   #10
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
check your fuel filter too while your at it
Slip Gypsies Blog
not sure if you realize this
Old 05-09-2007, 01:12 PM   #11
240trainee
240trainee's Avatar
Dude, it's a header.
You messed with something besides the header, figure out what that is.
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
Old 05-09-2007, 01:20 PM   #12
PRADOgy
PRADOgy's Avatar
PRADOgy is close to perfectionPRADOgy is close to perfectionPRADOgy is close to perfectionPRADOgy is close to perfectionPRADOgy is close to perfectionPRADOgy is close to perfectionPRADOgy is close to perfectionPRADOgy is close to perfectionPRADOgy is close to perfectionPRADOgy is close to perfectionPRADOgy is close to perfection
header has nothing to do with that bro, chck plugs,wires,and coil.... its either not combusting right.. so thats either the fuel source or spark
PRADOgy is offline   Reply With Quote
