Old 05-08-2007, 02:55 AM   #1
nism014
nism014 is an unknown quantity at this point
SR trans help
I searched the forums for a problem similar to this but couldn't find anything related to this
I got a s13 redtop and I noticed that I have some leakage going on right under the shifter kind of by the driveshaft.
What are the name of the seals around that area that I should change and where can I find them? Do you guys have part numbers that I can use to get them? my friend told me to change the trans seal connecting to the driveshaft. Anything else I should change while I'm at it? could it be something else?
my clutch started acting up saturday night while going home. Instead of grabbing halfway through releasing the pedal, it now grabs really low. like an inch from the bottom while releasing the pedal. I tweaked the adjusment screw on the clutch pedal and its a little better now, but its nowhere near what it normally feels like. I have a lot of play on the clutch now.
Could it be related to the fact that my trans is leaking and probably doesn't have the proper amount of fluid in there? I'ma fill the trans with some fluid tomorrow and see if it helps.
I doubt its my master or slave cylinder but at this point I'm open to all ideas/input cuz the clutch fluid is clean and when I press on the pedal it seems like the slave is pushing all the way out and coming back all the way. I'ma fill the trans with some fluid tomorrow and see if it helps
any help would be appreciated.
thx guys
nism014 is offline   Reply With Quote
Old 05-08-2007, 03:37 AM   #2
nism014
is this the o-ring my friend was talking about? what is the other gasket for?
http://cgi.ebay.com/ebaymotors/SR20D...mZ320033839054
Old 05-08-2007, 04:03 AM   #3
DoriftoPnoy
DoriftoPnoy's Avatar
DoriftoPnoy is on a distinguished road
Those two are for the front tranny seal. And they go here:
For future reference the part numbers are"
32114-Y4000 for the seal, and part# 32112-08U01
What you want is the rear seal and I am not really sure what that part number is. Just call up Superior Nissan in Puente Hills or find "WestCoJustin" (I think that's his name here) and they'll hook you up with the right part.
DoriftoPnoy is offline   Reply With Quote
Old 05-08-2007, 04:09 AM   #4
nism014
ok thx for the picture, I was looking at the manual on my computer and figured it out already.
But I think I need the gasket where the purple arrow is. Cuz my fluid leak is right under it.
Old 05-08-2007, 04:11 AM   #5
nism014
more importantly. Could the lack of trans fluid be the cause behind why my clutch is acting up?
could I get the part number for that rear seal and shifter gasket?
I live in Hawaii and would like to get it localy so I can get my car back on the road. Ordering it online is last resort.
Old 05-08-2007, 04:24 AM   #6
DoriftoPnoy
what you prolly want is this gasket. Print out his picture and take it to wherever you can get a gasket from. Sorry I don't really know the part number.
Old 05-08-2007, 02:50 PM   #7
nism014
k I found out the o-ring for the rear of the trans is the same as the KA. anybody know if that shifter gasket is the same as a KA?
Old 05-08-2007, 07:21 PM   #8
nism014
never mind. I found out everything I needed thx for the help dude
