Old 05-10-2007, 07:33 PM   #1
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
Disconnecting EGR... OK to drive 300miles/race with?
I have a stumbling(feels like running out of gas) problem at freeway speeds and when coming to a stop. I've replaced EVERYTHING possibly related to this problem, without fixing it!!!
Only thing left to try is a clogged EGR. Is it ok to disconnect the vaccume to the egr, drive 300 miles, and a full race/track day with the egr disconnected???
Suggestions on cleaning clogged ports?
gotta240 is offline   Reply With Quote
Old 05-10-2007, 07:39 PM   #2
4thHorse
4thHorse's Avatar
4thHorse is just really nice4thHorse is just really nice4thHorse is just really nice4thHorse is just really nice4thHorse is just really nice4thHorse is just really nice4thHorse is just really nice4thHorse is just really nice4thHorse is just really nice
What do you mean by replaced everything, what is everything
4thHorse is offline   Reply With Quote
Old 05-10-2007, 07:54 PM   #3
projectRDM
projectRDM's Avatar
An unplugged EGR won't hurt anything.
As far as cleaning it, the best way is to remove the valve and the BPT valve and soak both in carb cleaner overnight. Blow out all related vacuum hoses and replace as required.
Old 05-10-2007, 11:50 PM   #4
gotta240
Thanks for the reply R240na... Seems like you always come through on technical questions.
Is there a way to do it without removing the manifold?
Also, my shop teacher said that my car may PING with the EGR disconnected. Is there any possibility of pinging(which i wouldn't be able to hear because my car is kinda loud and i don't have great hearing)
Old 05-11-2007, 12:46 AM   #5
projectRDM
projectRDM's Avatar
On the exhaust side you can plug with an AIV delete from the dealer, or any M24x1.25 (IIRC) plug. Intake side, buy the blockoff plate found on Ebay, or cap the pipe off once it's removed from the valve.
The 'pinging' he's suggesting may be possible in theory, but he's also probably used to older cars with preheaters that ran ragged lean anyway and would detonate once that added recirculation was removed.
FORMERLY R240NA
Old 05-11-2007, 01:01 AM   #6
gotta240
Sorry for my horrible descriptions, but here it goes.
On the rear, left of the motor there are two brass-like, flying saucer looking things. There is vaccume line going between the two. My shop teacher told me to disconnect the vaccume line between the two, and put a screw in the vaccume hose.
Will that work for saturdays race day? (200 miles each way plus a couple hours on the track)
Old 05-11-2007, 07:40 AM   #7
myriad
myriad is an unknown quantity at this point
Send a message via AIM to myriad
My EGR is in a box somewhere in the garage and my car words fine *knock on wood* You should be fine without it in there.
Woot.
: S14 :
myriad is offline   Reply With Quote
Old 05-11-2007, 07:56 AM   #8
Phlip
Yes, I look like that
Phlip's Avatar
He instructed the removal of mine, and I just got home from a road trip, 350+ miles each way with some bouts of well over 100MPH for extended periods, you'll be fine
Weirdo
And I write too!
Old 05-11-2007, 08:06 AM   #9
gotta240
Thanks a lot guys. Sorry for needing things spelled out, but you're saying that hose i disconnected and blocked off is an "ok" way to bypass it? I now understand completly that i'll be fine without an egr, but just making sure that what i did will indeed bypass it.
Again, thank you. This is bringing some peace of mind as i leave in 18hrs and counting!!!
