Old 01-08-2002, 09:01 PM   #1
Takumi
Takumi's Avatar
Takumi is an unknown quantity at this point
I'm wondering, how much wear and tear does a turbo kit cause on the engine?  I know a turbo kit would wear out the engine even faster, but by how much?  I'd definately know that you're supposed to run 92 octane ...or at least I think you should. It would suck to have a turbo kit and then having your motor blow out on ya in a couple years or so.  I'm just wondering just for future references on boosting around 7-8 psi daily or even less.
Takumi is offline   Reply With Quote
Old 01-08-2002, 09:58 PM   #2
White240sx
White240sx is an unknown quantity at this point
The heat is the only "side effect" of turbo charging. As long as you don't detonate, go lean, or starve the shaft bearing of oil (all extremely rare occurrences) you should have many years of trouble free service.
White240sx is offline   Reply With Quote
Old 01-09-2002, 03:18 PM   #3
S14 Drgn
S14 Drgn is an unknown quantity at this point
wouldn't the intercooler help here as well or is that related with something else?
S14 Drgn is offline   Reply With Quote
Old 01-09-2002, 04:24 PM   #4
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from S14 Drgn on 3:18 pm on Jan. 9, 2002
wouldn't the intercooler help here as well or is that related with something else?</td></tr></table><span id='postcolor'>
the intercooler lowers the intake temp... and i suppose would lead to lower exhaust temps, even though the air/fuel mixture pretty much determines that. &nbsp;the IC is more of a performance item than a wear preventing item.
AceInHole is offline   Reply With Quote
