Old 05-22-2007, 10:08 PM   #1
drift_ricer
Banned from the Marketplace
drift_ricer is on the path to ruindrift_ricer is on the path to ruin
Z32 Brake Master Cylinder HELP??????
hi guys, I just installed Z32 26mm Front caliper and Z32 rear caliper....I also change my stock MC to 1'' Z32 MC...When I bleach, all the brake line are shooting out the fluid. My question is that my brake pedal is still too soft? is my caliper pistons are no good or something that I did wrong?
drift_ricer is offline   Reply With Quote
Old 05-22-2007, 10:11 PM   #2
Sexy_Ninja
Sexy_Ninja's Avatar
Sexy_Ninja is an unknown quantity at this point
your suppose to take the flared fitting from the stock BMC and put it in the z32 BMC.
Sexy_Ninja is offline   Reply With Quote
Old 05-22-2007, 10:19 PM   #3
drift_ricer
I did already
Old 05-23-2007, 07:38 AM   #4
aznpoopy
aznpoopy's Avatar
you need to make yourself more clear...
what does 'bleach' mean? do you mean bleed?
where on the brake line is fluid shooting out from?
Old 05-23-2007, 07:44 AM   #5
The Chad
The Chad's Avatar
The Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really nice
I agree, I've done this swap as well but there is no way for anyone to help you if nobody can understand the post.
The Chad is offline   Reply With Quote
Old 05-23-2007, 09:18 AM   #6
NI_YON_Zenki
NI_YON_Zenki's Avatar
NI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud of
hmm, no flame but the name fits the comment.
CHECK: IF THE BRAKE ARE BEING BLED, THEN THERE SHOULD BE FLUID COMING OUT OF THE LINES, THIS CREATES NEW OPPORTUNITY FOR NEW, BETTER FLUID. IF YOUR BRAKE PEDAL IS TO SOFT, THEN YOU NEED TO MAKE SURE YOUR INNER FLOW STEM WITHIN THE M/C IS FITTED CORRECTLY ON IT'S SEAT, OR MAYBE USING THE WRONG DOT FLUID. JUST CHECK ALL THE LINES CONNECTING TO THE CALIPERS, I can gather you have installed conversion steel lines, so make SURE THE TREAD IS SEATED EVENLY. AND CHECK YOUR BRAKES FRONT TO BACK IN THAT PATTERN WHEN BLEEDING.
BEST REGARDS.
"GHOST"
NI_YON_Zenki is offline   Reply With Quote
Old 05-23-2007, 03:32 PM   #7
drift_ricer
sorry about that..my english is kindda bad..anyway I am guessing is that my caliper is bad...so I will change to a different rear z32 caliper tonight and bleed it again tomorrow and see what's up....
Old 05-23-2007, 04:01 PM   #8
FRpilot
FRpilot's Avatar
you have a leak somewhere.. either your lines have holes in them, your bleeding screws aren't tightened, or your caliper seals are bad.
FRpilot is offline   Reply With Quote
Old 05-23-2007, 06:45 PM   #9
drift_ricer
I did check around all the lines, and it show no sign of leaking....I'm just curious is it the caliper problem?
Old 05-23-2007, 06:49 PM   #10
sliddinsil8o
sliddinsil8o's Avatar
sliddinsil8o will become famous soon enoughsliddinsil8o will become famous soon enoughsliddinsil8o will become famous soon enoughsliddinsil8o will become famous soon enough
Send a message via AIM to sliddinsil8o Send a message via Yahoo to sliddinsil8o
you still havent said where the leak is coming from?????? is it at the BMC...or that one caliper...if so were on the caliper...simple info like this can go along way to help you out in your little delema
****SIGNATURE EXCEEDS FORUM LIMITS....PLEASE READ THE RULES****
sliddinsil8o is offline   Reply With Quote
Old 05-23-2007, 07:05 PM   #11
mandoz85
mandoz85 will become famous soon enoughmandoz85 will become famous soon enoughmandoz85 will become famous soon enoughmandoz85 will become famous soon enough
make sure the bleeder on the caliper is facing up. if you installed the calipers on the wrong side then you will never bleed the system.
mandoz85 is offline   Reply With Quote
Old 05-23-2007, 07:10 PM   #12
WilloW
WilloW's Avatar
WilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfection
Send a message via AIM to WilloW Send a message via Yahoo to WilloW
Going with what the wrote, it seems like he has multiple leaks (BMC?)
As for the OP, did you kink the lines when you were bending them? Did you correctly tighten the lines to the BMC? Give DETAILED description of your problem if you want a direct answer.
WilloW is offline   Reply With Quote
Old 05-23-2007, 07:43 PM   #13
ixfxi
Guest
Posts: n/a
i have a good feeling, a very very...... VERY good feeling this guy didnt bench bleed his Z32 MC.
Old 05-26-2007, 06:49 AM   #14
misfitsfreak81
misfitsfreak81's Avatar
misfitsfreak81 is an unknown quantity at this point
bench bleeding is over rated and a waste of time. 90% of the time you can go with out doing it. but i do agree that he didnt do something right.
misfitsfreak81 is offline   Reply With Quote
Old 05-26-2007, 08:07 AM   #15
babowc
babowc's Avatar
babowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfection
lolol.
you guys must have some bad comprehension skills.
he opens up the bleeder screw and bleeds them, all fluids come out, however the pedal is still soft.
he also changed to an 1" Z32 BMC as well.
whats so hard to understand?
*make sure you have the calipers' bleeder screws on the correct sides. as well as gravity bleeding.*
babowc is offline   Reply With Quote
Old 05-26-2007, 05:38 PM   #16
TEALSQUEAL
TEALSQUEAL's Avatar
TEALSQUEAL is making a name for him/her selfTEALSQUEAL is making a name for him/her self
if the mc is used it sounds to me that the seal is bad and fluid is simply blowing by it when u hit the pedal, i would like to think u are compitant enough to install parts properly otherwise u should take it to a shop being as with effed up brakes u aren't just endangering yourself but other people also
TEALSQUEAL is offline   Reply With Quote
Old 05-26-2007, 08:43 PM   #17
ixfxi
Guest
Posts: n/a
yeah, it is.
if you like sitting there pushing air from the MC out the lines, wasting tons of fluid.. yeah, its a waste of time.
Old 05-26-2007, 11:54 PM   #18
drift_ricer
I found out the my z32 front caliper bleeder is down. that's I it didn't work. I change the caliper bleeder up, now it work...thanks everyone!
