Old 05-29-2007, 10:46 AM   #1
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
need some quick answers
i have put two new wheel spacers on why does it make my steering wheel shake when i drive only at 40 miles an hour.
why does my RPM drop and my car dies on me when i'm driving.
i just put on a z32 Maf. caliberated with POWER FC to work already.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 05-29-2007, 10:51 AM   #2
adrians_s13
adrians_s13's Avatar
Trader Rating: (29)
Feedback Score: 29 reviews
theres an imbalance somewhere, its either your tires or its your spacers. If it didn't do it before the spacer install, my money's on the spacers. What kind of spacers do you have?
@adrianfromthecastle
Old 05-29-2007, 10:52 AM   #3
s13gold
s13gold's Avatar
Trader Rating: (79)
s13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfection
Feedback Score: 79 reviews
did you get wheel alignment?
s13gold is offline   Reply With Quote
Old 05-29-2007, 10:59 AM   #4
s13silvia123
its H&R wheel spacers its hubcentric too. wheel alignment is ok and the tires are new driven on a few miles. it didnt do that when i didnt put wheel spacers on.
Old 05-29-2007, 12:14 PM   #5
Sileighty_85
Sileighty_85's Avatar
Well I gotta ask but did you tighten the lugs good on the Spacer?
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 05-29-2007, 01:24 PM   #6
s13silvia123
its been done torque to 85-90 lbs
Old 05-29-2007, 01:55 PM   #7
S13NismoStyle
S13NismoStyle will become famous soon enoughS13NismoStyle will become famous soon enoughS13NismoStyle will become famous soon enough
Have you re-torque the spacer lugs after the first couple of miles or so? Also i would check to make sure there is no debris between the spacer and the hub. This has happened to me in the past with a burr from when i drilled my
q45 rotors. A small burr caused the rotor to not seat properly and caused my wheel to shake at certain speeds.
S13NismoStyle is offline   Reply With Quote
Old 05-29-2007, 02:13 PM   #8
s13silvia123
thanks man you have the most adequate answer for me thanks man
