Old 06-01-2007, 09:44 AM   #1
DJ_Sunrise
DJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to all
Send a message via AIM to DJ_Sunrise
SR hesitation, stumbling, breaking up..
hey guys.. under full throttle especially in 3rd gear, once my car hits 4500 rpm it starts breaking up and losing power. occasionally in 1st even with partial throttle, it breaks up real bad past 3k rpm. when i shift under full throttle into the next gear the motor hesitates terribly, then takes off again. to start.. here are my mods..
z32 maf
aeromotive fpr
apexi suction kit
apexi power fc
apexi n1 dual
hks w/g actuator
forge unos mbc
blitz fmic
tomei exhaust mani
mr turbo outlet, dp
4ply silicone coupling, tbolt clamps
i changed the o2 sensor and spark plugs(ngk iridiums, HR 7) 1 month ago. fuel filter was changed about 2 months ago.
i thought it might have been a boost leak, so i reinstalled all the couplings and clamps and have them tight as shit now.. everything checks out with the boost. i also had a similar problem when my mafs ground was kinda shitty.. so i redid the ground.. still having the problem.. cleaned the mafs sensor, and plug. the breaking up started a few weeks ago, right after i did the aeromotive fpr kit from enjuku, but i didnt think much of it. at first the pressure was too high causing my car to sound like a lawn mower. after i redid the couplings, vac dropped causing the pressure to lower.. so i raised it back to 45psi. fuel pressure is set around 45psi w/o vac. off of the intake manifold as a vac source, i have the FPR and boost gauge hooked up together. at idle, my vacuum reads .65-.68 bar, and for whatever reason occasionaly dips to .60-.62.
im at a loss here.. to the best of my knowledge everything should be solid. do you guys have any idea of what else i can try??? to test my aeromotive fpr, can i turn the pressure all the way up, hook up my factory fpr, and see what happens?? i dont know what to do =( someone please help...
-Bart
DJ_Sunrise is offline   Reply With Quote
Old 06-01-2007, 11:07 AM   #2
slider2828
slider2828's Avatar
Swap out coilpacks... Your problem does look like a coilpack issue. Borrow a friend's known good one and swap out one by one. Try ti.
Old 06-01-2007, 11:22 AM   #3
Chrischeezer
Chrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the rough
sounds like a MAF problem..
under a load.., anything above 50 % it brakes up? def MAF
Chrischeezer is offline   Reply With Quote
Old 06-01-2007, 01:06 PM   #4
swayray
swayray's Avatar
swayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfection
did you tune your power fc yourself? or did you have it tuned by a pro? it soundsl like your fuel starts to be lean at 4500 rpms...
http://www.thenismoshop.com
swayray is offline   Reply With Quote
Old 06-01-2007, 01:43 PM   #5
DJ_Sunrise
yea it was tuned a while back, before i did most of these bolt ons. im going to dentsport on the 16th. i didnt think the mods would cause such an adverse effect.. most of the problems occured coincidentally around the install of the fpr.. although other stuff could have gone bad since then. car ran great before.. maybe the aeromotive fpr is bad? do you guys think i should seperate the vac sources? damn pfc..is there any way to get this thing to spit some codes?? is there any way to test coilpacks? im swapping mafs and coil packs sunday to rule those out..
-Bart
Old 06-01-2007, 01:51 PM   #6
johngriff
johngriff's Avatar
You can test continuity of the coil pack wireing. You can also use a infared thermometer to measure the coil pack temp.
Did you check the base fuel pressure after the install?
[email protected]
Old 06-01-2007, 02:10 PM   #7
slider2828
slider2828's Avatar
yah pretty much everything above mentioned will call you to the problem. BUt just becareful of blowing your motor if you run too lean.
Old 06-01-2007, 03:44 PM   #8
DJ_Sunrise
yea i hope the motors not running lean i can barely afford gasoline at the moment, much less a new motor lol. a technician over at my work was telling me to use a spray bottle.. mist the coilpacks while the motor is running, and see if there are any sparks on the coilpacks.. blaaahhh. can you guys give me any tips as far as the packs go? i was told to put dielectric grease inside the boot.. that and if theres gray powder in side, the spark is arcing. anything else anyone can offer into my motors issues?
you nissan and your distributorless shit!!!!
-Bart
EDIT: yea i checked fuel pressure.. i have it set around 45psi.. my dick head friend reset my power fc map so im back to the old one for a little while now. ive just been increasing inj. 10%... been running fine so far, till this bs popped up
-Bart
Old 06-01-2007, 03:47 PM   #9
nisans13turbo
nisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nicenisans13turbo is just really nice
check all basic maintance first, ground, wired, plugs , make sure they are all nice and tight and connected. Then go from there.
I almost bought a new clutch, asumming my clutch was slipping and it ended up to be my loose TPS sensor. DUH, but yea doublecheck.
nisans13turbo is offline   Reply With Quote
Old 06-01-2007, 05:56 PM   #10
slider2828
slider2828's Avatar
Wait FPR should not be at 45, it should be around 55psi. Secondly, turn off the boost controller to see if there is stumbling or buckling happening. If there is no buckling when mbc is off, then it is a tuning issue. Thirdly, read the tips off your spark plugs, powdery white = too lean, black/sticky = too rich, and oily means timing is off. You have no one that can lend you a coil pack?
Old 06-01-2007, 06:36 PM   #11
swayray
swayray's Avatar
stock fuel pressure is between 45-49 psi... how much are you boosting?
Old 06-01-2007, 08:14 PM   #12
slider2828
slider2828's Avatar
18 PSI lol....
Old 06-01-2007, 08:19 PM   #13
johngriff
johngriff's Avatar
What is the Rate of the Aeromotive you got? If its like 2/1 you might have your answer right there.
[email protected]
Old 06-04-2007, 04:39 PM   #14
DJ_Sunrise
unless enjuku sent me the wrong fpr, it should be 1:1 ratio. i thought stock SR fpr was 38 with vac, 44 without vac??
-Bart
Old 06-04-2007, 04:44 PM   #15
slider2828
slider2828's Avatar
I do 55 with vacuum.
Old 06-12-2007, 10:13 AM   #16
SILVIA_KIDs14.5
SILVIA_KIDs14.5's Avatar
Trader Rating: (-1)
SILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choices
Feedback Score: -1 reviews
SR
z32 maf
aeromotive fpr
apexi suction kit
apexi power fc
apexi n1 dual
hks w/g actuator
forge unos mbc
blitz fmic
tomei exhaust mani
mr turbo outlet, dp
-Bart
check again you got a boost leak had the same thing wit my s14 was gettin like no pwr past 3.5k found the leak now runs like a champ hope it helps
SILVIA_KIDs14.5 is offline   Reply With Quote
