Old 06-02-2007, 02:56 PM   #1
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
s14 tire size fitment help?
im tryin to get some rims for my s14 and i would like to know if these rims will fit with out a pull or roll the sizes are 17x9 +24mm offset with 235/40r/17 and for the rear they are 17x10.5 +27mm offset with 255/40r/17 the rear wheel well has the lip bent up but has no pull or roll. thank u in advance
Old 06-02-2007, 03:25 PM   #2
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
In the rear you will need a pull for sure. The front you SHOLD be fine though you might need a roll at most. but im 90% sure you're fine on the front, 100% positive you need a pull on the rear.
Old 06-02-2007, 03:30 PM   #3
blueshark123
Trader Rating: (55)
what if i go for 17x9 all around also i cant roll front cause they are fiberglass fenders
Old 06-02-2007, 03:32 PM   #4
blueshark123
Trader Rating: (55)
well the front are also 20mm wider thenstock so i should be good for the front
Old 06-02-2007, 03:46 PM   #5
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
the front will be sunken in a tad bit. On stock fender im going 18x9 +0 and 18x10+10 with pull in the rear. you might want to check out some wheel fitment threads on the forum. http://www.zilvia.net/f/showthread.php?t=129865 I'm going to be running some very agressive fitment. on stock fender if I were to run 235/40 in front I would probably do that a 18x9+12.
If i were you and wanted to fit 235/40/17 and have a conservative setup I would run on a stock body:
17x9 +15 235/40
17x10 +25 255/40
very conservative fitment would be 17x9 +20 and 17x10+30, with -1 camber all around.
I believe the very conservative setup would be more for people who care about handling and are aiming for time attack. Though i'd go beefier tires if it was time attack. I'm not an expert and too lazy to type, maybe someone can correct me.
Old 06-02-2007, 03:52 PM   #6
blueshark123
Trader Rating: (55)
what tires would u recommend if i ran the 17x9 27mm offset for front and rear i
Old 06-02-2007, 03:56 PM   #7
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
that depends on what you want. normally I think you want more traction in the rear. I would not go 9 in the rear though and I would personally run staggered. If you are going for performance I can't help you there unfortunately...
Old 06-02-2007, 04:27 PM   #8
blueshark123
Trader Rating: (55)
i dont have stock fenders cause i have a s15 conversion done
Old 06-02-2007, 04:30 PM   #9
blueshark123
Trader Rating: (55)
i want staggered but they only have the rim 17x9 or 17x10.5 and i domt want to pull my rear fenders cause it just got itpainted and the rims arre for performance not just looks cause im doing 1/4 miles
Old 06-02-2007, 04:53 PM   #10
OptionZero
OptionZero's Avatar
You're referring to mustang wheels.
The fronts should clear but it will be tight, depending on what coilover it might rub.
The rears you'll need a pull.
Old 06-02-2007, 05:40 PM   #11
blueshark123
Trader Rating: (55)
i got stock suspension for now im just gonna end up going 17x9 all around with a slight stretch on the tires then later upgrade does anybody have pics of the mustang rims on there car.
Old 06-02-2007, 07:34 PM   #12
floodo1
floodo1 will become famous soon enoughfloodo1 will become famous soon enoughfloodo1 will become famous soon enough
something no one ever seems to consider around these places is the effect of running such low offsets has on how the car handles.....you're massive increasing stock scrub radius, and decreasing the wheel rate of the spring.
anyways thats a pretty aggressive rear wheel, definately going to have to work those rear fenders.
17x10 +33 or +34 basically puts the outside edge of the lip dead nuts even with the outside (vertical) edge of the fender, with no flare at all..in the rear.
17x9 +28 or so does the same in the front.
so if you have + 20mm front fenders then +8 should put your real close to normal flush.....
in zilvia terms you could subtract about 20mm from each of those figures!!
floodo1 is offline   Reply With Quote
Old 06-03-2007, 05:16 PM   #13
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
I once tried to explain to my friend that higher offset wheels is actually better for handling and he pretty much said who cares....
Old 06-04-2007, 06:36 AM   #14
blueshark123
Trader Rating: (55)
im not gonna go 17x10.5 in the rear im just gonna go all around 17x9 24mm so my question is will this be fine?
Old 06-04-2007, 08:57 AM   #15
chrisman2k
chrisman2k's Avatar
chrisman2k is an unknown quantity at this point
Send a message via AIM to chrisman2k Send a message via MSN to chrisman2k
Ask and you shall recieve! Mine with Cobra R's 18x9 +20 2000 all round. 255/40 Falkens. Front rub a tad durring hard cornering, rear needed a roll.
Clicky!
chrisman2k is offline   Reply With Quote
