Old 06-03-2007, 03:27 PM   #1
KAs14slider
KAs14slider is making a name for him/her selfKAs14slider is making a name for him/her selfKAs14slider is making a name for him/her self
turbo over-oiling question
Hi guys, just turboed my KA with a t28 and after driving it around for a bit, it became obvious that the turbo was being over-oiled, either that or I have a blown turbo. But I bought the turbo from my friend and it was in good condition because I rode around in his car many times before he sold me the turbo. We pulled off my IC piping and there seemed to be oil in all my piping. I just had a few questions: can over oiling kill the turbo or the engine? Does oil actually get into the throttle body because it seems like it could? I parked the car and after doing some research I ordered an oil flow restrictor that will limit the oil feed line to 50 psi.
Since there is oil inside my piping and maybe even the intercooler, what is the best way to get it out? Is there something I can pour through the pipes/IC to get clean everything out?
KAs14slider is offline   Reply With Quote
Old 06-03-2007, 03:38 PM   #2
2bad240
2bad240's Avatar
2bad240 has a spectacular aura about2bad240 has a spectacular aura about2bad240 has a spectacular aura about2bad240 has a spectacular aura about2bad240 has a spectacular aura about2bad240 has a spectacular aura about2bad240 has a spectacular aura about
SR
the samething happened to a guy i know and his oil return was kinked backing the oil up into the turbo so check that.
you, its whats for dinner.
2bad240 is offline   Reply With Quote
Old 06-03-2007, 03:50 PM   #3
KAs14slider
It isn't kinked but it's not running straight down either so what I'll do is probably get a 90 degree bend for the oil pan bung and try to run the drain down straight as much as possible.
Old 06-03-2007, 03:51 PM   #4
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
an oil seal is an oil seal.
need i say more?
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 06-03-2007, 03:54 PM   #5
jdmspooge
jdmspooge's Avatar
Trader Rating: (39)
jdmspooge has a spectacular aura aboutjdmspooge has a spectacular aura aboutjdmspooge has a spectacular aura aboutjdmspooge has a spectacular aura aboutjdmspooge has a spectacular aura aboutjdmspooge has a spectacular aura about
Feedback Score: 39 reviews
Oh man! Ring lands maybe...?
jdmspooge is offline   Reply With Quote
Old 06-03-2007, 04:23 PM   #6
GSXRJJordan
GSXRJJordan's Avatar
Ring lands? He said he's got oil in his I/C pipes, not his exhaust.
You're probably gonna fix the cause of the problem by getting that oil restrictor, problem is (like kouki said) you've probably already blown the seals. Yes, too much pressure can kill turbo seals.
To get the oil out of your intercooler and piping, you don't have a whole lot of options. Carb cleaner will be a good start, but anything that you spray in there will leave a residue and fuck with how your car runs for a while after... Carb cleaner will evaporate mostly, but then when the car runs it'll be rich. Then I've seen people light the shit on fire to try to burn the oil, but then you've got this charred mess inside there that your engine is breathing for the next 100 miles - you get the point. I'd clean out as much as you can from the pipes by hand (rags/etc) and leave the rest, it'll burn itself out eventually.
Old 06-03-2007, 05:00 PM   #7
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Ive used gas from my lawn mower canister to get oil out of my fmic before. Works and once you drain all the crap out, just let it air dry completely before you slap it back on.
CLICK HERE!!!
Old 06-03-2007, 06:27 PM   #8
Sileighty_85
Sileighty_85's Avatar
What kind of oil feed line are you running? Do you have an oil resrictor for the oil feed line? T-28's require a resrictor fitting if not using the stock bajo Bolt, otherwise what happens to you happens.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 06-03-2007, 07:16 PM   #9
KAs14slider
I already ordered a restrictor
