Old 06-04-2007, 12:48 PM   #1
nismosil40zx
nismosil40zx is a well-known jackass
Send a message via AIM to nismosil40zx
SR Dies on Decel....Also low volts
Im having 2 issues...
1. When Im decelling at low rpm the car tends to die like it wont hold a idle. what can be the cause of this (bad IAC)
2. When I start my car its charging voltage is 14 and the ECU is reading 12.6 Volts good as I drive the charging drops to13.0 to 13.5 and the ecu is reading 11.5 to 11.8v. sometimes low also I am on a ka Alternater. Should I through more grounds on or what?
sr20det redtop
Mods are
SC-61 top mount, 370cc (7psi),SAFCII, stock ka MAF I just put it together could this be the cause, my 300zx MAF will be here today, Injectors next week.....Never did it before before i put this stuff on with the decel problem.
nismosil40zx is offline   Reply With Quote
Old 06-04-2007, 12:51 PM   #2
steve shadows
steve shadows's Avatar
check your alternator, throw piggy back in garbage, get larger injectors, get larger MAF, get tuned rom.
honestly just dont drive the car until you do that, your life will be much better.
Like Me on FaceBook !
Old 06-04-2007, 12:59 PM   #3
crazybb
crazybb is on a distinguished road
im having the same problem.. but i have 600cc and enthpaly tune computer..
i think its my iacv.. going to clean it tomorrow..
crazybb is offline   Reply With Quote
Old 06-04-2007, 01:06 PM   #4
swayray
swayray's Avatar
swayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfection
steves right...
or check your alternator fuse incase it blew...
http://www.thenismoshop.com
swayray is offline   Reply With Quote
Old 06-04-2007, 01:25 PM   #5
nismosil40zx
SR
You dont think it has to do w/ IAC...I drove it just to make sure it runs turbo is good ect...
