Old 06-05-2007, 01:26 PM   #1
chmercer
chmercer's Avatar
info on keyless remote?
ok so i have a y33 and a s14. my original s14 keyless remote broke, so i reprogrammed it to one of my extra y33 remotes. now the remotes operate both cars at once since they are both in the driveway so its kindof retarded. how can i fix this? i dont have a good enough understanding of how the remote functions to figure out how to program them properly to avoid this happening again.
would it work if i like drove one of the cars out of range, then reprogrammed the other car, then repeat with the other car on a seperate remote? do i need to have the 2nd remote out of range when i reprogram the first remote?
chmercer is offline
Old 06-05-2007, 09:54 PM   #2
projectRDM
projectRDM's Avatar
Nope. You've programmed the remote to both cars, so you have to go back in and erase all the codes and start over.
FORMERLY R240NA
projectRDM is offline
Old 06-05-2007, 10:47 PM   #3
chmercer
chmercer's Avatar
how would i do that though? all i can think to do is move one car and remote out of range, then do the reset procedure on one car, then do the same on the other car? i guess i should take the batteries out of the remotes before i do this, will that reset the fobs?
chmercer is offline
Old 06-06-2007, 07:57 AM   #4
projectRDM
projectRDM's Avatar
Nope. In order to 'reset' the codes you have to store three more new codes in each module, this will push the current code out of sync.
FORMERLY R240NA
Old 03-25-2009, 04:19 PM   #5
lflkajfj12123
can you get one for a 180sx type-x?
lflkajfj12123 is offline
