S14 Anti-sway Bar End Links
I just purchased S14 front and rear Cusco anti-sway bars. It was suggested that I change out the end links or get inserts for them. Does anyone here know where I can find these? Thanks guys.
![]() Join Date: Aug 2005
debloz parts on fleabay will have your front sway bar endlinks. You can use SPL as well but they're expensive. Don't go junkyard diving for endlinks. I did and after going through 6 s-chassis's I couldn't get a regular front pair without striped this or bent that. For the rear I used a prothane kit.
Eye on the Prize |
![]() Join Date: Mar 2004
spl isnt really expensive when you consider the quality of the heims that he uses. you can maybe make some cheap ones, but i doubt for 40....you need 4 heims alone
For drifting stiff as shit sway bars and endlinks are fine. If you look at road track cars, the sway bars usually aren't the stiffest shit available.. Stock with poly bushings, or stiffer.. but not over the edge. Or atleast stock endlinks are rocked. I have largus bars. With the poly bushings, the over steer was just insane. I put in OEM rubber bushings to loosen up the sways.. Car handles like a dream now. Great in the corners.
-Bart |
http://www.pdm-racing.com/products/suspensionbush.html
there u go. scroll all da way down. 28$ a set shipped to ur door. |
