Old 06-19-2007, 02:40 PM   #1
drift_or_die
drift_or_die is an unknown quantity at this point
ka head problem!!
i think it might be a floating valve but I'm not sure at all!! my motor "only under load" make a rattle/gargle sound from the fourth cylinder!!! Ive tried thicker oil cause its hot as hell outside, down to burping the coolant system and it still makes the strange ass sound!! post up with any ideas cause i can use the help!! thanks
drift_or_die is offline   Reply With Quote
Old 06-20-2007, 02:51 PM   #2
drift_or_die
and just to add it only does this when the motor gets heated up!! for instance at night it doesn't do this but only when its hot as hell out!!!
Old 06-20-2007, 05:51 PM   #3
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
run thick ass oil, just kidding............. why dont u pull the valve cover off and inspect it... u might just need new tensioners... but if ur valve is moving... why dont u try lashing it...
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
