Old 09-20-2002, 09:37 PM   #1
SSJ2Gohan
SSJ2Gohan is an unknown quantity at this point
2 part Question.
Down the road Im going with a KA24DET setup and it looks like upgraded internals are needed for anything higher than 7 psi boost.  Im looking to get up to the neighborhood of 15-20 psi.  I understand the connecting rods and pistons will need to be upgraded to accomplish this.
First, is there anything else that will need to be upgraded to sustain the pressure?  Im talking about the block itself and not the injectors or anything like that.  All 'accessories' would be done.
Second, do you have to pull the engine out of the car to change out the pistons and rods?
Kamehameha!
SSJ2Gohan is offline   Reply With Quote
Old 09-21-2002, 09:31 AM   #2
Jim96SC2
Jim96SC2 is an unknown quantity at this point
Send a message via AIM to Jim96SC2
Definitly get forged pistons and rods! Get your head worked on a bit too.
Swap DONE: 40K Redtop, Greddy Turbo extension, Greddy DP, Greddy V-SPL FMIC, Greddy Hotpipe, HKS SSQV, Koyo Radiator, Toda Ultralight FW, Spec Stage 2 Clutch, ATS 2-way Diff., Rice-Boy Red Air Filter.
Jim96SC2 is offline   Reply With Quote
Old 09-21-2002, 06:31 PM   #3
ca18guy
ca18guy's Avatar
ca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfection
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (SSJ2Gohan @ Sep. 21 2002,4:37)</td></tr><tr><td id="QUOTE">2 part Question.
Second, do you have to pull the engine out of the car to change out the pistons and rods?</td></tr></table><span id='postcolor'>
You can go over 7 psi on stock parts, but thats another thread in itself.....
Take the block out of the car, its not that hard and will save you work.
ca18guy is offline   Reply With Quote
