Old 07-05-2007, 02:52 PM   #1
wisDOMination
wisDOMination is a jewel in the roughwisDOMination is a jewel in the roughwisDOMination is a jewel in the roughwisDOMination is a jewel in the roughwisDOMination is a jewel in the roughwisDOMination is a jewel in the roughwisDOMination is a jewel in the rough
need engine bay cleaning techniques
for all your engine-bay-cleaning-ninja's who's been training for years and has perfected this art of cleaning, i need to be schooled on this shit.
just pulled out my motor the other day and my engine bay looks like ass. i was wondering what you guys use and do to get all the gunk and shit all over the engine bay off and cleaned...
also, what parts should i NOT get wet...
thanks in advance... tsk tsk
wisDOMination is offline   Reply With Quote
Old 07-05-2007, 02:55 PM   #2
ThatGuy
Admin Asshole
ThatGuy's Avatar
Soak the engine bay with a strong cleaner (Simple Green works well) Spray it out with a pressure washer. Whatever doesn't come loose, hit it with a scraper, screwdriver, rags + Elbow Grease, whatever. Repeat as many times as necessary to get it clean.
Old 07-05-2007, 03:01 PM   #3
wisDOMination
wow, that was a fast reply
alright, imma try to get a pressure washer.
any idea on what i SHOULD NOT get wet?
Old 07-05-2007, 03:05 PM   #4
ThatGuy
Admin Asshole
ThatGuy's Avatar
If the engine is out, then just wrap up any wiring/electronics in plastic bags. Make sure all your reservoir covers are on tight so you don't get water in your fluids.
Old 07-05-2007, 03:08 PM   #5
wisDOMination
alright, thanx man!
Old 07-05-2007, 03:10 PM   #6
arkive43
arkive43's Avatar
arkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud of
after cleaning, this is the best time to paint it. i did take advantage... other than that theres nothing else i can think of.
arkive43 is offline   Reply With Quote
Old 07-05-2007, 03:21 PM   #7
exitspeed
aWingThing.com
exitspeed's Avatar
Best place to do what ThatGuy said is a car wash where you spray it yourself. That was you have a nice pressure washer and then no clean-up afterward.
Old 07-05-2007, 03:24 PM   #8
95Blue240sx
95Blue240sx's Avatar
95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection
After it dries spray on some Meguiars Hot Wheels spray all over and wipe clean. It will smell gooood and look fucking sweet.
Please leave me feedback
95Blue240sx is offline   Reply With Quote
Old 07-05-2007, 03:30 PM   #9
A Spec Products
A Spec Products's Avatar
I used degreaser (purple stuff + orange stuff) to get the main stuff off
Then after I washed it with dishwashing soap
Then sanded
Then washed again with dishwashing soap
Then painted
Worked pretty well, although time consuming
No pressure washer, just elbow grease and a hose
A SPEC PRODUCTS CORP
Old 07-05-2007, 03:44 PM   #10
TOMKAIRA93
TOMKAIRA93 is making a name for him/her selfTOMKAIRA93 is making a name for him/her self
Car quest sells a degreaser that rips through grease pretty good. Spray, wait some time and hose it, should come out clean as hell. The brand of the product is Car Quest, by far the best I've used so far. I just went through and engine bay cleaning myself and this is what I used and worked great. good luck!
TOMKAIRA93 is offline   Reply With Quote
Old 07-05-2007, 04:06 PM   #11
A Spec Products
Yeah, the degreaser foam one is supposed to be good
Spray it on, let the foam sit and penetrate and wham
Rinse
Old 07-05-2007, 04:51 PM   #12
wisDOMination
niceeee
ill try to see if i can find that car quest stuff...
im sure i can get a pressure washer, so that car quest stuff and the pressure washer should work wonders...
i was gonna paint on some of that POR15 stuff, anyone ever used that? then maybe ill spray over that, or just keep it black...
Old 07-05-2007, 04:56 PM   #13
Vision Garage
Vision Garage's Avatar
Vision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfection
Send a message via AIM to Vision Garage
Pressure washer will get off most caked on dirt. Dont forget to clean the bottom of the engine and tranny.
Vision Garage is offline   Reply With Quote
Old 07-05-2007, 04:59 PM   #14
ThatGuy
Admin Asshole
ThatGuy's Avatar
You only need POR-15 if you have really bad rust. If it is just surface rust, you'll be fine sanding and repainting.
Old 07-05-2007, 05:13 PM   #15
opponheimer
opponheimer's Avatar
opponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond repute
1) borrow a steam cleaner
like that would ever happen
SR20 & RB20/25/26 in s13/s14 Wiring from $125 to $200.. Best prices EVER.
opponheimer is offline   Reply With Quote
Old 07-05-2007, 05:49 PM   #16
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
Simple Green + Tootbrush = builds character.
Old 07-05-2007, 06:03 PM   #17
timlush
timlush's Avatar
timlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to behold
Send a message via AIM to timlush
Kinda hard to get to the car wash without an engine, lol.
timlush is offline   Reply With Quote
Old 07-05-2007, 06:14 PM   #18
projectRDM
projectRDM's Avatar
I saw this thing one time called a trailer.
FORMERLY R240NA
Old 07-05-2007, 06:17 PM   #19
j20accord00
j20accord00's Avatar
j20accord00 is an unknown quantity at this point
Send a message via AIM to j20accord00
do it right man..this is what i did..( ill post up some pics if you like) i'm currently still doing it but this is like my 3rd time doing it. *clean the bay out super good remove all loose rust, dirt, greese,ect. fix rust spots and then have at it...alright..i use 1000grit sandpaper and then i just WET sand the whole thing down..i use water and simple green. put it into a spray bottle and have at it...soak the whole thing and let the sand paper get really wet into like a bucket or something, next start to sand everything down, dont go too hard in the same spot because you will burn through the paint and get to the bare metal..then after that use Dupli-color self eteching primer its like a green color do a few coats maybe like 2-3. then wetsand that super smooth and let it all dry then just use dupli-color paint any color u want...make sure to put a good amount on there i used about 4-5 cans. if you have any over spray u can wet sand it out and make sure to build up to make it match even. then use to your clear top coat. if using laquer then use laquer clear coat..if using enamel then use enamel clear coat. thats about it..turns out super fresh and clean..looks like someone did it perfessionally. its gonna coat you about 60-75 bucks in materials but its gonna be worth it. my car had no harness in it, no fenders, bumper or hood because i did EVERYTHING. again ill post up some pics of the process almost done..should be done tomorrow if the weather is nice. hope that helps. sorry for the long post.
-Evan
j20accord00 is offline   Reply With Quote
Old 07-05-2007, 08:23 PM   #20
timlush
timlush's Avatar
Trailering a car to the carwash?
LOL You guys are hardcore.
Old 07-05-2007, 08:34 PM   #21
ALEXTHESUS*PECT
ALEXTHESUS*PECT's Avatar
they already told you what you need to do the job, now just put on your head band, and go to work danielsan!
TEAM SUS*PECT
Old 07-05-2007, 08:36 PM   #22
opticfilms
opticfilms's Avatar
opticfilms is a glorious beacon of lightopticfilms is a glorious beacon of lightopticfilms is a glorious beacon of lightopticfilms is a glorious beacon of lightopticfilms is a glorious beacon of lightopticfilms is a glorious beacon of lightopticfilms is a glorious beacon of lightopticfilms is a glorious beacon of lightopticfilms is a glorious beacon of lightopticfilms is a glorious beacon of lightopticfilms is a glorious beacon of light
use A Power Washer And Grease Lightning.
opticfilms is offline   Reply With Quote
Old 07-05-2007, 09:01 PM   #23
JDS Performance
JDS Performance's Avatar
Trader Rating: (53)
JDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of light
Feedback Score: 53 reviews
I have always heard that if you spray your engine bay - say at the car wash you should leave the car running - as it could crack the head/block etc?
Never actually done it or heard of anyone doing it - just wondering since we are on the subject.
JDS Performance is offline   Reply With Quote
Old 07-05-2007, 09:05 PM   #24
ThatGuy
Admin Asshole
ThatGuy's Avatar
Get any metal really hot (i.e. Exhaust manifold, block, etc.) and then drench it with cold water, and you run the risk of cracking. Just don't drive 90mph for 30 mins straight to get to the car wash, and immediately spray the engine, and you should be fine. Like I said, you can turn the engine off, just cover all the vital stuff (intake, electronics, reservoirs) with plastic bags, and go to it. Elbow grease will still be your best friend.
Old 07-05-2007, 10:02 PM   #25
projectRDM
projectRDM's Avatar
I've done it many a time, why use my water and soap when they have it there, fully pressurized? Plus they have a drain, nothing worse than oily shit in your own driveway.
FORMERLY R240NA
Old 07-06-2007, 12:44 AM   #26
wisDOMination
j20accord00: it'll be cool if you posted some of them pics.
thanx everyone. i think imma just get some simple green or some of that car quest stuff, then use a pressure washer.
Old 07-06-2007, 01:49 AM   #27
Anto
Anto's Avatar
Anto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfection
this man speaks the truth
I have countless doo doo stains on MY driveway
Anto is offline   Reply With Quote
Old 07-06-2007, 12:33 PM   #28
exitspeed
aWingThing.com
exitspeed's Avatar
Ha, my bad. I thought it was in the car.
Well for future reference.
Old 07-06-2007, 02:13 PM   #29
turbo2nr
turbo2nr's Avatar
turbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enough
Send a message via AIM to turbo2nr
http://www.superhonda.com/forum/showthread.php?t=193483
have fun like the honda boys!
s14 kouki ka-t
turbo2nr is offline   Reply With Quote
Old 07-06-2007, 02:33 PM   #30
TOMKAIRA93
That stuff is like acid man...I use to used on my bath tub, but quite cause the fumes are too damn strong. Stay away from it, I'd say.
