Old 01-11-2007, 08:54 AM   #31
S14DB
AFC #1
S14DB's Avatar
Originally Posted by ESone3
anyone know if this works for an SR?
Yes, same hose on the cold pipe.
Old 01-11-2007, 02:31 PM   #32
DrifteRs13
DrifteRs13's Avatar
DrifteRs13 is on the path to ruinDrifteRs13 is on the path to ruinDrifteRs13 is on the path to ruin
timing was righ and the flames are gone thanks, but i just need to do the intake cleaning thing, how long until i see a dif are will ir be like a mirical and just be gona once i put it in there
1990 Acura Integra- Deer (mother fucker)
1993 240sx- still tickin
DrifteRs13 is offline   Reply With Quote
Old 01-11-2007, 03:15 PM   #33
Dream240
Dream240's Avatar
If you use about 1/2 can as suggested it should clear up on your next drive out. Just make sure your putting the cleaner in as it's running with the throttle open a little.
GL
Old 01-11-2007, 07:45 PM   #34
ms!3
you can always just loosen the idle adjuster too. sure cleaning it is good but if you want to get to the parts store to get intake cleaner without youre car dieing at stop lights just loosen the screw.
ms!3 is offline   Reply With Quote
Old 01-11-2007, 07:58 PM   #35
illvialuver
illvialuver's Avatar
will this work with a ka-t?
Old 01-12-2007, 01:21 PM   #36
DrifteRs13
DrifteRs13's Avatar
no, dont use for superchared or turbocharged engines, i just did it asnd used half a can and didnt do anything. would the timing have anythign to do wiht it, i never got it timed i just put my new exhause on there thinking it might be no back pressure?
Old 01-12-2007, 01:48 PM   #37
Dream240
Dream240's Avatar
I'm not sure if you mean "right" or "high" So did you or did you not check and adjust timing as needed?
You could try using the WHOLE can, maybe yours is just really dirty. Did you put the cleaner in the right hose? The second one from the left, the bigger of the two.
And Drifter.....could you please take the extra 30 seconds and make your posts more gramatically correct? I'm having a hard time understanding you. Thanks.
Old 01-25-2007, 01:18 PM   #38
tachikoma
tachikoma is an unknown quantity at this point
I would like to post that I tried this, and it hasn't realy fixed my stumbling idle. I honestly am at a loss here.
I have new spark plugs, cleaned intake & manifold (didn't take it apart, just with the intake cleaner), adjusted timing so its perfect. I followed directions here and cleaned that tube through, but I dont know. Anyone have any ideas?
It's a 96 btw, and it doesn't die at idle, it just stumbles around causing the car to shake lightly, its just annoying really. It accelerates beautifully, its just when its sitting still.
tachikoma is offline   Reply With Quote
Old 01-25-2007, 01:49 PM   #39
Dream240
Dream240's Avatar
I found another problem about a week ago, there's a vaccumm line that plugs into the underside of the throttle body. It's only about 5 inches long but it goes to the idle control system. Replace that hose with a new piece from autozone. I found mine to be plugged up at the elbow portion. I replaced it and voila!! no more stumbling idle. Worth a try.
Also when you pull it out, just blow into it. How much air is going through? Mine was completely clogged. I'm currently in the process of changing out ALL the old vaccumm line from my engine bay, there's alot...
Old 01-25-2007, 02:21 PM   #40
tachikoma
Does this require taking apart the intake manifold?
Old 01-25-2007, 02:31 PM   #41
Dream240
Dream240's Avatar
no...
Just go to the throttle body and feel the underside of it near the butterfly. You can feel and see the hose. Just work that little shit off and go get some new hose. Best to do it while the engine is cold.
Old 01-25-2007, 02:42 PM   #42
tachikoma
no...
Great I'll check that next.
I really should just take apart the manifold so I can access all the EGR stuff behind it to make sure that's all ok, as well as other vacuum lines. But I'm to busy lately
Old 01-25-2007, 02:43 PM   #43
Blackhat
Blackhat is an unknown quantity at this point
This would work on a SOHC also. Just make sure your A/C is off and the car is warmed up first. I imagine that would apply to the DOHC as well. You have 3 idle control valves connected to that hose you're spraying cleaner in. They are:
Air Regulator: Just for cold start idle. When the Fuel Pump comes on so does this valve. When it heats itself up the whole way it closes the valve.
FICD: When your A/C compressor kicks on this valve opens.
AAC: This is the valve you're most likely trying to clean. This is the PWM valve your ECU controls to maintain idle RPM. There's a spring in this part of the assembly that you need to keep fairly clean.
Hope this helped someone!
Blackhat is offline   Reply With Quote
Old 01-25-2007, 02:47 PM   #44
s13gold
s13gold's Avatar
Trader Rating: (79)
s13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfection
Feedback Score: 79 reviews
ohhhhh......good one...thanks man!
s13gold is offline   Reply With Quote
Old 01-25-2007, 02:51 PM   #45
Blackhat
Oh, and the hoses that connect to the Throttle body on the SOHC are coolant hoses. I can't speak for the DOHC, but I would think they are the same thing. I've been told it's so the throttle body doesn't freeze up during cold weather.
Old 01-25-2007, 02:54 PM   #46
redsuns3838
redsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the rough
Send a message via AIM to redsuns3838
I find it to clean the AICV better if I just take mine off, and clean it with carb cleaner, re-gasket and re-install. THat way I can really get in there and spray carb cleaner up close and get rid of everything. sometimes I let it soak in there for 10 -15 minutes.
redsuns3838 is offline   Reply With Quote
Old 01-25-2007, 03:49 PM   #47
Dream240
Dream240's Avatar
You're thinking of a separate hose, the one that loops into the throttle housing and back out and goes into the upper manifold. The vaccumm line is the 3/8" (i think) line that goes into the throttle body directly under the butterfly. Stand over your passenger fender and you'll see the hose sticking out there. It's easier to access by removing the intake piping section that goes into the throttle body.
Wish i had a pic......
Old 01-26-2007, 07:40 PM   #48
tachikoma
Baaaahhhh.
Well after a day or two of fooling around and tweaking everything, it turned out to be my cylinder 4 spark plug.
My friend I put this car together, and he was responsbile for the spark plugs at the time. I was cleaning the throttle body while he installed the plugs. Apparently the 4th one got bent (so the gap was screwed up) and he didnt notice and installed it anyways, hahaha. Thus causing my shaking and stumbling at idle.
Note: he also installed the wrong brand, but that's another story.
So, I have NGK V-Power coppers in there now and it's haulin ass and idling perfect!
Old 02-07-2007, 01:55 AM   #49
zugoi
zugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to behold
Originally Posted by outerheaven2k4
I had the same problem on the KA24E, but i was silly and took off the whole thing without buying a gasket to replace it LOL. I found out however, this method would work and wished I did it.
On the SOHC-
Locate the idle adjust screw
Unscrew completely, be sure to apply some pressure on the screw while unscrewing, there's a spring, dont lose it.
Spray your favorite cleaner in there
Replace screw and adjust your idle back to normal
WOOT
^_^
I remember reading in ALdata that you shouldnt mess with the idle screw until you unplug the Tps. If you do you can confuse the ecu which will throw your idle off. Something like that.
Drunk posting FTW!
zugoi is offline   Reply With Quote
Old 02-07-2007, 06:10 AM   #50
Dream240
Dream240's Avatar
Correct-a-mundo...
But first be sure you have your timing set at 20 degrees BTDC (KADE), THEN proceed to set idle. If your timing is off, it will affect your idle.
Old 07-05-2007, 01:12 PM   #51
santacruisin
santacruisin is an unknown quantity at this point
I have a problem with my IACV but its the opposite of everyone. The car idles ok (rough b/c of cams) but my problem is that the car stays at wide open throttle when I put the clutch in to shift gears. If I rev to 5K rpm or more air is still rushing in the engine through the IACV because it is still open and the car bounces of the rev limiter. I just got the car back from the mechanic and he says it must be the IACV because its HUGE in the SR compared to other engines and thats the only place besides the throttle where air can get in. No vacuum leaks.
So is it possible that the IACV is so dirty that it is actually sticking open instead of shut? I searched and it no one else seems to have this problem.
santacruisin is offline   Reply With Quote
Old 07-05-2007, 05:27 PM   #52
SlidewayzS14
SlidewayzS14 is not welcome here anymoreSlidewayzS14 is not welcome here anymoreSlidewayzS14 is not welcome here anymoreSlidewayzS14 is not welcome here anymoreSlidewayzS14 is not welcome here anymoreSlidewayzS14 is not welcome here anymoreSlidewayzS14 is not welcome here anymoreSlidewayzS14 is not welcome here anymoreSlidewayzS14 is not welcome here anymore
wait, cant all this hassel of pulling tubes and holding up the throttle be taken away by taking off the filter on the intake, have a friend hold the revs at like 2k and just spray the into the now wide open intake?
SlidewayzS14 is offline   Reply With Quote
Old 07-06-2007, 07:34 AM   #53
Dream240
Dream240's Avatar
yeah sure if you like wasting 3 cans of cleaner to do the job that should take only one.
You're getting a more concentrated dose of cleaner if you pull the IACV intake tube and spray in there. It's not that hard really, should take LESS time than pulling the intake filter off, plus you're not getting cleaner on your MAF and possibly damaging it. Those things are touchy.
Old 10-14-2007, 01:09 AM   #54
supreme_1
supreme_1 is on the path to ruinsupreme_1 is on the path to ruinsupreme_1 is on the path to ruin
since the AAC is the thing which you are trying to clean would taking off the iacv and cleaning it be a waste of time? where exactly is the iacv located?
supreme_1 is offline   Reply With Quote
Old 12-25-2007, 12:24 PM   #55
whomiked
whomiked has made poor choiceswhomiked has made poor choiceswhomiked has made poor choiceswhomiked has made poor choiceswhomiked has made poor choiceswhomiked has made poor choices
The small line to the left of it, what does it go to? The nipple from my intake broke off and I can't hook that line up. Should I plug the line, leave it free, do I need to get a new intake now?
whomiked is offline   Reply With Quote
Old 12-28-2007, 11:42 PM   #56
thedecapitator
thedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choices
Originally Posted by nsn240 View Post
tps
so... after this cleaner goes through the aicv... it goes into your engine. I cant imagine its that bad for it though.
what does tps mean?
thedecapitator is offline   Reply With Quote
Old 12-29-2007, 12:38 PM   #57
whomiked
Originally Posted by thedecapitator View Post
what does tps mean?
Throttle Position Sensor
Old 04-21-2008, 10:31 PM   #58
Tearlessj
Tearlessj's Avatar
Anyone have a pic of the hose?
Nagasaki Motors
Friends help you move. Real friends help you move bodies.
Tearlessj is offline   Reply With Quote
Old 04-22-2008, 12:23 AM   #59
KA-T_240
KA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond repute
The house that you put stuff in to clean the IACV? Its one of the like 2 big hoses that goes into the stock intake. One goes to your VC, the other goes to your IACV
KA-T_240 is offline   Reply With Quote
Old 05-23-2008, 05:32 PM   #60
Champz
Champz's Avatar
Champz is an unknown quantity at this point
sorry to bring up this tread again, but can some1 verify which hose it is? theres 2 hose on the intake, is it the small one or big one?
a picture if possible
thanks
Tooo Sloooow 4 youuuu!
Champz is offline   Reply With Quote
