Old 07-11-2007, 10:50 AM   #1
onehalfasia
onehalfasia is making a name for him/her selfonehalfasia is making a name for him/her self
Motor Swap Questions Thread
hello, front clip arrives tomorrow morning, this is my first motor swap and i'm kinda assuming i'll be able to remove everything from the clip and figure out where it goes on the 240. I have a few questions, i search and read but asking questions in a thread is simpler than searching. so...
I'm not sure how to deal with wiring, specifically the RHD jdm harness with the LDH and usdm firewall. Also If i'm gonna run Apexi Power FC D-jet in a few months how to wire things for that to work also. Do i have to cut a passage in the firewall for the JDM harness to reach the left hand drive, or extend the wires...is there any harness job or whatever lightening that works properly with the d-jetro. basically not sure about the harness situation, i'd like the cleanest setup capable with the apexi.
I guess thats all i'm wondering at the moment, I'll probably have a few other questions for a few days during the swap. I'm going for a completely stock install since i cant afford parts(injectors, management, toda flywheel/clutch, guages, radiator, ect...) at the moment. thank you for your time
john
onehalfasia is offline   Reply With Quote
Old 07-11-2007, 11:05 AM   #2
Mlogue84
Mlogue84's Avatar
Mlogue84 is close to perfectionMlogue84 is close to perfectionMlogue84 is close to perfectionMlogue84 is close to perfectionMlogue84 is close to perfectionMlogue84 is close to perfectionMlogue84 is close to perfectionMlogue84 is close to perfectionMlogue84 is close to perfectionMlogue84 is close to perfectionMlogue84 is close to perfection
Send a message via AIM to Mlogue84
How about you stop being lazy and search, There are threads that discuss this. You're gonna waste a lot more time making an ass of yourself than if you just searched.
Mlogue84 is offline   Reply With Quote
Old 07-11-2007, 11:09 AM   #3
onehalfasia
i doubt it, in the time you spent writing that you probably could have provided useful info...
also this is from heavy throttles swap guide...can i remove the CONSULT diognostic wires and connector with the stock sr20ecu or apexi d-jet.
"The rest of the wires are for the CONSULT diagnostic device. It is not necessary to connect any other wires than those listed above to get the SR to run properly.
Connect the remaining wires if you plan to use the onboard diagnostic CONSULT connector. "
Old 07-11-2007, 11:15 AM   #4
Mlogue84
Mlogue84's Avatar
See if this helps. I was a little harsh at first.
http://www.frsport.com/sr20det-swap-...r20-p-665.html
Old 07-11-2007, 11:18 AM   #5
Dream240
Dream240's Avatar
There you go, the epitome of being lazy. Either way you're going to have to read the threads that have the info. If you're this lazy when it comes to searching, how many corners are you going to cut doing the install?
The best and most efficient way to solve your problem is extending the wires. You can buy ready-made wiring harnesses online, or send yours to a shop to do it for you.
GOOGLE SEARCH!!
Or just make it easy and leave all the excess SR wiring clumped up on the passenger floor board after you install everything. Looks really JDM that way.
Old 07-11-2007, 11:18 AM   #6
onehalfasia
that info is helpful, How does all that rewiring work alright with the Apexi Power FC? Also how about routing the RHD wiring with the LHD firewall/chassis.
Old 07-11-2007, 11:25 AM   #7
onehalfasia
GOOGLE SEARCH!!
I'll search, also the previous owner had 3 sr20det's in the car so the wiring could possibly be set, Seems like theres alot of wiring though compared to other sr swaps i've seen. Either way i'm probably gonna remove the rest of the wiring, and sort things out this afternoon. I'm looking for the minimal wiring for cleanness and proper function with the Apexi D-jetro, or stock sr20det ecu.
Old 07-11-2007, 11:34 AM   #8
Mlogue84
Mlogue84's Avatar
If you insist on being spoonfed
http://www.greenline.jp/catalogue/el...es/powerfc.php
Old 07-11-2007, 12:57 PM   #9
onehalfasia
well idk about that link, i'm not gonna worry about the apexi, i just figured since its a direct install with the stock s13 ecu and harness, that if i splice and reorganize the harness it might not work properly. I'm not really asking to be spoon fed, i'm looking for advice...pretty sure i'll be able to figure it out though.
Old 07-11-2007, 02:30 PM   #10
Mlogue84
Mlogue84's Avatar
You can do it, It's gonna use the stock harness just fine. What SR btw?
Old 07-11-2007, 02:59 PM   #11
Dream240
Dream240's Avatar
The only way you'll have mate up problems with the Apex FC and your "repaired" harness is if you screwed up the rewire. It's designed to use the stock ECU harness connector just as if it was the ECU itself.
Since you sound like you're going to be doing the rewire yourself, I would recommend getting the appropriate SR FSM and study that electrical section like it's the Holy Bible. Other wise you could end up with an electrical mess the size of which this forum has never seen. Especially if you've got the remains of 3 previous harnesses in there.
Why not source out a completely clean already cut and ready to install harness from the web? Seems to be alot less hassle.
Old 07-11-2007, 03:30 PM   #12
Mlogue84
Mlogue84's Avatar
^^^ Word
He's got a good point.
Old 07-11-2007, 03:32 PM   #13
onehalfasia
red top s13 not sure, heres a pic of the actual clip...
Old 07-11-2007, 03:36 PM   #14
onehalfasia
i have an sr FSM from the web. I'd rather rewire and save a few hundred for other parts...I'm gonna remove the entire 240sx harness, and S13 harness and figure out whats needed for the car afterwards.
Old 07-11-2007, 04:48 PM   #15
Vision Garage
Vision Garage's Avatar
Vision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfection
Send a message via AIM to Vision Garage
splice the two harnesses together then put it back the way it should. behind dash through existing firewall holes. Power FC shouldnt have to do anythign with wiring since its plug and play. Unless you mess up on wiring power FC shouldnt matter. If you are gonna run AVCR you will splice into wiring later.
Vision Garage is offline   Reply With Quote
Old 07-11-2007, 05:22 PM   #16
kassed33
kassed33 is an unknown quantity at this point
for like a $100-$200 you can have Yury do it and save you a "Lot" of time and have it done right the first time check it outhttp://www.wiringspecialties.com/s13sr20det.html, i used them for my S14 SR swap and had them wire in the SAFC2 while he was at it, they did a great job and saved my lots of time
josh kassed
kassed33 is offline   Reply With Quote
