Old 07-30-2007, 01:05 AM   #1
rps13sr20
rps13sr20's Avatar
rps13sr20 is a name known to allrps13sr20 is a name known to allrps13sr20 is a name known to allrps13sr20 is a name known to allrps13sr20 is a name known to allrps13sr20 is a name known to allrps13sr20 is a name known to allrps13sr20 is a name known to allrps13sr20 is a name known to allrps13sr20 is a name known to allrps13sr20 is a name known to all
greddy type rs bov problem
My bov doesn't seem to be blowing off any air no matter what the boost is at. I search the forums but couldn't really find a solution. Ohh and one weird thing if I type "bov not working" in the search it always says database error. Anyone else get that.
Thanks in advance.
rps13sr20 is offline   Reply With Quote
Old 07-30-2007, 01:15 AM   #2
bigOdom1
bigOdom1's Avatar
bigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfection
have you adjusted the spring tension? (the little nut around the screw on top of it)
bigOdom1 is offline   Reply With Quote
Old 07-30-2007, 02:29 AM   #3
rps13sr20
rps13sr20's Avatar
yup, tightened and loosened it. Doesn't seem to make a difference.
Old 07-30-2007, 02:56 AM   #4
faded1004
faded1004 is on a distinguished road
did you check the vacuum lines? make sure the bov is connected to boost/vacuum line, not just boost line... (ie. dont' connect to wastegate, connect to the throttle body line...) i know this is obvious... but just wanted to throw that in...
also, is the bov new?
faded1004 is offline   Reply With Quote
Old 07-30-2007, 03:21 AM   #5
rps13sr20
rps13sr20's Avatar
all the lines are connected fine. i checked for leaks too.
the bov iis pretty new I bought it a couple of months ago. And was working fine until recently.
Old 07-30-2007, 08:48 AM   #6
240AM
240AM's Avatar
240AM has a little shameless behavior in the past
If your boost reference is correct and it was working previously, any chance that the bov was bought on ebay and may be a knockoff? If so it may have seized. Take it off and see if you can actuate it by hand.
http://www.driftopia.com
240AM is offline   Reply With Quote
Old 07-30-2007, 11:28 AM   #7
rps13sr20
rps13sr20's Avatar
Problem fixed.....i don't know why but I just replaced the screw and it blows fine now (strange...). My friend wasn't using his greddy anymore after he got the hks ssqv, so he gave me the screw. I'm kinda wondering how much it would cost to order just that from greddy. Autozone or Kragen don't carry it.
Ohh and I'm sure my bov is not a knockoff (unless they really put that extra effort into making the greddy box and etc). I was going to get the china-made a while back. The problem with that it always seemed to have a leak, no matter how you adjust it.
