Old 10-06-2002, 04:32 PM   #1
the3SecondJerk
the3SecondJerk is an unknown quantity at this point
I just finished rebuilding my KA24e. Everything seemed fine. The car will only turn over however. Its getting spark for sure. So we figure its the injectors not firing because the plugs are dry and the fuel is getting into the fuel rail. Does anyone have an idea of what can be the problem?
Drive it like you stole it.
the3SecondJerk is offline   Reply With Quote
Old 10-06-2002, 06:44 PM   #2
mrdirty
mrdirty is an unknown quantity at this point
sure u got firing order correct?
mrdirty is offline   Reply With Quote
Old 10-06-2002, 09:41 PM   #3
transient
transient's Avatar
transient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant future
Send a message via ICQ to transient Send a message via AIM to transient
firing order would just make it run like shit, it would at least try to start. You could always pull an injector and put it into a container and then try to start the engine. That would defintately tell you if it was firing or not.
Learn everything you can, while you still have the chance.
transient is offline   Reply With Quote
Old 10-06-2002, 10:10 PM   #4
LexusRules
LexusRules is an unknown quantity at this point
Send a message via ICQ to LexusRules
did you check that your ecu is connected proporly? if some pins are not connecting that would not let your injectors fire or even not deliver spark. Check it out <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''>
-Alex
*Sideway Or No Way At All*
LexusRules is offline   Reply With Quote
Old 10-07-2002, 01:54 PM   #5
the3SecondJerk
well the ecu was never removed so it should be fine
