Old 10-08-2002, 12:55 AM   #1
eliterit
eliterit is an unknown quantity at this point
hello everyone, i was linked here from www.sr20deforum.com and currently own a 93 se-r. I love the sr20 motor and i am dying for the DET but i want to go about it the proper way by going RWD.
I'm probably gonna go with an s13 fb and i have some questions that i'm looking to be answered because i plan on doing the swap myself.
1) which det is best to swap into an s13?
2) does the det mount easily? what has to be done?
3) what parts do i have to keep or get new?
4) can i use the Jspec sr20det tranny or will i have to use the ka tranny?
5) certain brands of parts to stay away from.
6) where to get det from and how much(what will i need it to come with?tranny,harness,etc.)
7) links containing good swap info or writeups
8) any major issues i should be aware of on the s13.
sorry for so many questions, i couldnt find much with the search button, it only lead me to parts for sale.
jaime gutierrez
93 sentra se-r
eliterit is offline   Reply With Quote
Old 10-08-2002, 07:33 AM   #2
HippoSleek
HippoSleek's Avatar
HippoSleek is an unknown quantity at this point
Check out heavythrottle.  It will answer your basics.  Sport Compact Car did a basic write up on the process a few months ago.  I'm sure someone can link you.  After than, lurk and occasionally hit up SR owners for info and tips.
HippoSleek is offline   Reply With Quote
Old 10-08-2002, 09:59 AM   #3
Yoshi
Yoshi's Avatar
Yoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to behold
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (eliterit @ Oct. 07 2002,11:55)</td></tr><tr><td id="QUOTE">hello everyone, i was linked here from www.sr20deforum.com and currently own a 93 se-r. I love the sr20 motor and i am dying for the DET but i want to go about it the proper way by going RWD.
jaime gutierrez
93 sentra se-r</td></tr></table><span id='postcolor'>
Hello and welcome <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''>
the easiest way to answer most of your questions is to use the search feature at the top. &nbsp;There's a wealth of info to be had here, just gotta dig a little (older members tend to flame newbies for not using the search)... &nbsp;to answer some of your questions:
1) which SR is "best" really depends on how far you want to take your car... as far as ease of swap, then a s13 SR (black or redtop) would be easiest.
2) I'm not sure what you're asking, but it uses the same motor mounts if that's what you're getting at. Pretty much a straight swap.
3) check heavy throttle and unstable hybrids, etc for this info
4)you have to use the SR tranny (it comes with the engine), the KA will not bolt on
5) part brand opinions seem to vary greatly by personal experience of those who've tried... the only real complaint i've heard related to headers and BOVs... figure out what route you want to take with your engine, THEN ask around about specifics
6) I can't stress enough that you should look for a full clip when buying your engine, this will assure you have all the parts needed (minus things that need to be made custom... ie A/C)
7) use the "search" and see #3
8) timing chains req replacement after around 80-100k, beware spoiler rust, leaky trunks on most s13 hatches, extreme urges to go sideways around all corners... or maybe that's just me <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=''> &nbsp;
These are just REALLY short answers to your questions, but should help you in going the right direction. &nbsp;the 240 followers are a tight community with a lot of pride, if you get one, do it right, make us proud, no ricing the car, and street racing is for high schoolers. Use the search and absorb all you can <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''>
Good luck!
www.360realms.com/S13-S15
Yoshi is offline   Reply With Quote
Old 10-08-2002, 10:08 AM   #4
CoasTek240
CoasTek240's Avatar
CoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud of
Send a message via AIM to CoasTek240
ok.. well i' might be reading wrong.. but are u talking bout using ur sr20 fromt he sentra in an s13 and using a rwd tranny.. cuz it can be done.. but i think it's a lot of work and isn't worth.. don't flame me.. maybe i read wrong. but welcome to the forum
CoasTek240 is offline   Reply With Quote
Old 10-08-2002, 10:42 AM   #5
BEISSEN
BEISSEN is a well-known jackass
Send a message via Yahoo to BEISSEN
Like hippsleek said go to heavythrottle.com or srswap.com both the same.If you are talking about transplaniting the sr20det that is rwd there is also a sr20det that is made for the sentra as well it is the bluebird motor froma awd gtr iirc which when you get it is is made for a fwd car.But if you get a s13 hatch then a s13 redtop is gonna be chaper with a little more mileage and a blacktop s13 motor will have usally a little less but not always the truth.You have to use the jdm tranny or take alot of time to transfer bell houseings over to use the ka tranny.If you get a clip you will get tranny,motor,ecu,ignitor chip,harness etc everything need to do a basic swap.
BEISSEN is offline   Reply With Quote
Old 10-08-2002, 11:16 AM   #6
Yoshi
Yoshi's Avatar
I'm pretty sure he was just asking about the RWD SR, as he asked where to get one, and which is best... &nbsp;I think he was just mentioning the SE-R to point out that he has a form of SR currently and it aided in his decision to get another nissan with the RWD turbo form of the engine.
Old 10-08-2002, 11:40 AM   #7
camppain
Will never get banned...
camppain's Avatar
camppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enough
Send a message via AIM to camppain Send a message via MSN to camppain Send a message via Yahoo to camppain
i knew your name looked familiar! &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sly.gif" border="0" valign="absmiddle" alt=':sly:'>
best thing is unlike when we need to swap dets in our cars we have to have jwt retune the stock ecu to run the det on 240's you can use the sr20's ecu
-=-99 Sentra SE 5 speed-=-
-=-95 240 SE 5 speed-=-
camppain is offline   Reply With Quote
Old 10-08-2002, 12:22 PM   #8
eliterit
so you're saying i can use my sentra's stock ecu on a 240 with the det???
Old 10-08-2002, 12:34 PM   #9
Foxcolt
Foxcolt's Avatar
Foxcolt is an unknown quantity at this point
Send a message via AIM to Foxcolt
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (eliterit @ Oct. 08 2002,1:22)</td></tr><tr><td id="QUOTE">so you're saying i can use my sentra's stock ecu on a 240 with the det???</td></tr></table><span id='postcolor'>
No, he's saying you can use the ECU that will come with your clip as opposed to having the ECU retuned ala FWD SR.
Saves you the trouble of worrying about engine management right off the bat.
Josh: Find me a redtop s13 motor with less miles than a black top s13 motor. Do it, I dare ya <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=''>
Redtops were made from 91-94 blacktops were from 94-98. I wouldn't suggest going the redtop route unless you plan on rebuilding right away. They are just to old nowadays. This is just my opinion though I'm sure some people disagree.
Driftec
www.midatlantic240sx.com
Foxcolt is offline   Reply With Quote
