Old 08-05-2007, 05:44 PM   #1
Bukoone
Bukoone is on the path to ruinBukoone is on the path to ruin
Close!
Is there a difference when it comes to smog, especially in California? I Need to know because I need to pass smog, after I failed, and want to know whether it will still be okay to get a High Flow CAT, possibly a CATCO.
Bukoone is offline   Reply With Quote
Old 08-05-2007, 07:21 PM   #2
s13rookie
s13rookie's Avatar
s13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant future
Send a message via AIM to s13rookie
There are a lot of hi flow cats out there. Get one that is CARB cert'ed
Ive spent most of my money on cars and women...the rest i wasted
s13rookie is offline   Reply With Quote
Old 08-05-2007, 07:24 PM   #3
SexPanda
SexPanda's Avatar
SexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfection
Send a message via AIM to SexPanda Send a message via MSN to SexPanda
Man its a shame most of you live in CA. I just gutten my friends SRT-4 cat. In MO, or at least this county, they just check to see if you have one. No smog, no emissions...
Go to autozone and pic up an OEM one. A high flow cat is high flow because it doesnt filter as well.
SexPanda is offline   Reply With Quote
Old 08-05-2007, 07:32 PM   #4
s13rookie
s13rookie's Avatar
I must disaggree. An aftermarket air filter filters better and flows better than a stock one. I think materials and design have a lot to do with it
Also, I remember seeing a dyno a few years ago of a high flow cat versus a gutted cat. The high flow won by a couple hp, im not sure if it had to do with too little backpressure, or possibly turbulence
Old 08-05-2007, 07:36 PM   #5
SexPanda
SexPanda's Avatar
An air filter and a cat are 2 different things, and they work 2 different ways. Catalitic converts CONVERT harmful exhaust gasses into not-so-bad ones by the use of catalists. Think about it. High-flow cat has better airflow because the hnoycomb is bigger, meaning less surface area to convert harmful gasses, meaning better flow, but worse emmissions.
and i read an article about that too. It was against a test pipe, a stock cat and 2 high-flows. The best hi-flow lost 1 hp to a test pipe.
Old 08-05-2007, 07:44 PM   #6
slamdbusa
slamdbusa's Avatar
slamdbusa is an unknown quantity at this point
High Flow cats do not convert the hydrocarbons as good as the OEM units, but in turn the OEM cats do not flow like the High Flow cats.
slamdbusa is offline   Reply With Quote
Old 08-05-2007, 09:03 PM   #7
Bukoone
Yeah, and that's where my problem was... The Hydrocarbons (HC) were high. I have a stock CAT. The smog tech. told me that it was maybe bad, which is why I failed emissions. So I think I should stick with a OEM CAT instead of an aftermarket? Unless, anyone knows any good aftermarket CATs that has better performace and throws better emissions....
Old 08-05-2007, 09:28 PM   #8
scarecrow27
scarecrow27 is not welcome here anymorescarecrow27 is not welcome here anymorescarecrow27 is not welcome here anymorescarecrow27 is not welcome here anymorescarecrow27 is not welcome here anymorescarecrow27 is not welcome here anymorescarecrow27 is not welcome here anymorescarecrow27 is not welcome here anymorescarecrow27 is not welcome here anymore
i use an oem cat to pass emissions then i rip that sucker off the second i pass and slap the test pipe back on.
scarecrow27 is offline   Reply With Quote
Old 08-05-2007, 09:33 PM   #9
bigOdom1
bigOdom1's Avatar
bigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfection
id try a high flow cat and get it smogged while brand new
bigOdom1 is offline   Reply With Quote
Old 08-05-2007, 10:00 PM   #10
Ninjabread
Ninjabread's Avatar
Well, at this point, i'm sure a NEW highflow cat would perform better than your 15+ year old stocker. Plus you don't wanna upgrade twice.
613DriftWerks.ca
Ninjabread is offline   Reply With Quote
Old 08-06-2007, 01:20 AM   #11
240on430
240on430 has a little shameless behavior in the past
I would stick with a stock cat if you have a ca registered car.
240on430 is offline   Reply With Quote
Old 08-06-2007, 02:06 AM   #12
Bukoone
alright thanks for the help guys! i think i know just what to do....please close this thread.
