Old 08-27-2007, 09:58 AM   #1
sean350z
sean350z's Avatar
sean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of light
Thinking about making my own ignition cut rev limiter...diagram included
I have a PFC and the fuel cut leaves my A/Fs at 13.5 at the rev limiter under high load. I don't want to spend 220-250 dollars on a Bee*r unit or 500+ on an MSD ignition seeing I don't really need the added spark capacity. So I want to make my own.
All I am going to use is a RPM switch ($40), SPDT relay ($5), and some wires and solder.
Is my wiring correct? Will this even work? I needs some thoughts and opinions seeing I don't know jack about electrical theory but just some small knowledge. Here's the diagram..
sean350z is offline   Reply With Quote
Old 08-27-2007, 11:30 AM   #2
lazierhobo
lazierhobo is on the path to ruinlazierhobo is on the path to ruin
it seems like a really good idea. fuel cuts like that are pretty horrible and i have seen many kids blow engines because of that.
why are you using the CAS signal line for your interrupt?
i would just use the power for the igniter or some other component in the actual spark system. im just not sure how the ecu will feel about you just killing the cas signal.
lazierhobo is offline   Reply With Quote
Old 08-27-2007, 11:38 AM   #3
drifting_changed_mylife
drifting_changed_mylife's Avatar
drifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymoredrifting_changed_mylife is not welcome here anymore
Send a message via AIM to drifting_changed_mylife
thats pretty frikin smart! +1
your neg reps match my avitar.... keep em commin
drifting_changed_mylife is offline   Reply With Quote
Old 08-27-2007, 11:42 AM   #4
sean350z
sean350z's Avatar
I have an S15 SR so I have no ignitor or single power source for the coil packs. Cutting the CAS signal will not cut fuel but will cut spark (I'm pretty sure).
Old 08-27-2007, 11:52 AM   #5
lazierhobo
it will still cut fuel i think, cause doesn't the PFC use sequential injection? if there is no cas signal then it wont know when to deliver fuel.
if you wanted to be really baller, you could turn this into a soft cut rev limiter.
the way its setup on my haltech is i drop ignition to one cylinder at a time. just use multiple rpm triggers with the relay in series with the power signal to the coil packs.
or if you want to keep it simple, just rewire your coil packs so that there is a common power source
Old 08-27-2007, 11:53 AM   #6
sean350z
sean350z's Avatar
Or you could just tie into the +12V supply for the coils which would be at the ecu relay.
Old 08-27-2007, 11:56 AM   #7
sean350z
sean350z's Avatar
That would be nice. It would def require a circuit board which I don't have access to creating my own.
Old 08-27-2007, 11:58 AM   #8
lazierhobo
you can buy all the stuff you need to make circuit boards at radio shack. and i really dont think you would need one. just 4 rpm switches and 4 relays.
