Old 10-17-2002, 09:56 PM   #1
KingKong8247
KingKong8247's Avatar
KingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of lightKingKong8247 is a glorious beacon of light
Send a message via AIM to KingKong8247
I was wondering today if my intake or any other intake for that matter improves the gas milage? I would check myself but I have the faulty digital speedo and when that does not work my odometer doesnt work and I havnt had the speedometer working for a full tank yet so I cant tell.  I was just wondering.
Also if anyone knows how to fix the odometer so it works even when the speedometer is off. Thanks
90 240sx Coupe
KingKong8247 is offline   Reply With Quote
Old 10-17-2002, 10:01 PM   #2
BEISSEN
BEISSEN is a well-known jackass
Send a message via Yahoo to BEISSEN
usally your gas will decrease due to more air and more full being used.
BEISSEN is offline   Reply With Quote
Old 10-17-2002, 11:36 PM   #3
Kreator
Kreator's Avatar
Kreator will become famous soon enoughKreator will become famous soon enoughKreator will become famous soon enough
Basic idea (works for most stuff)
anything that increases performance increases comsumption.
кто болеет за Зенит, у того всегда стоит!
Kreator is offline   Reply With Quote
Old 10-18-2002, 10:53 PM   #4
sykikchimp
WOW addicted
sykikchimp's Avatar
it only increases consumption when your using the new potential.  If you look at it from the other angle, you have just made it easier for you car to do the work it wa doing before.    So YES, when driving normally you WILL see better gas mileage.  same is true with exhausts.  If I use that new potential released by thew mod, my gas mileage drops drasticly..  when I drive normally it rewards me with a good 2-3 mpg more.
Old 10-19-2002, 12:27 AM   #5
Kreator
Kreator's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (sykikchimp @ Oct. 18 2002,11:53)</td></tr><tr><td id="QUOTE">it only increases consumption when your using the new potential. If you look at it from the other angle, you have just made it easier for you car to do the work it wa doing before. So YES, when driving normally you WILL see better gas mileage. same is true with exhausts. If I use that new potential released by thew mod, my gas mileage drops drasticly.. when I drive normally it rewards me with a good 2-3 mpg more.</td></tr></table><span id='postcolor'>
Uhhhh.... i dunnow about that one, but i could explain it from the fact that you lose power. eg, with intake and exhaust u lose low end, what actually makes your car a bit slower when u are cruising around....
Old 10-19-2002, 03:10 AM   #6
DuffMan
DuffMan's Avatar
It probably wont make much difference either way. Your air flow through a barely opened throttle isn't going to be affected by a filter a few feet away from it.
Old 10-19-2002, 09:30 AM   #7
Chicken Magnet
Chicken Magnet's Avatar
Chicken Magnet is an unknown quantity at this point
Theoretically, an intake would give you better gas mileage as your engine is running more efficiently due to more air entering the engine. &nbsp;The reason that most people don't think it does, is they like to REV their engine so much to hear the sound of their intake! <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''>
'98 240SX Apex-i Dual N1 exhaust, Injen CAI, 17"OZ Racing Nova Wheels, Tein S-Tech Springs and KYB AGX Struts
Chicken Magnet is offline   Reply With Quote
Old 10-19-2002, 11:47 AM   #8
Kreator
Kreator's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Chicken Magnet @ Oct. 19 2002,10:30)</td></tr><tr><td id="QUOTE">Theoretically, an intake would give you better gas mileage as your engine is running more efficiently due to more air entering the engine. The reason that most people don't think it does, is they like to REV their engine so much to hear the sound of their intake! <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''></td></tr></table><span id='postcolor'>
Hmm, i don't think it's really the case. I don't think that any of the better flow argument applies to the mpg. The point being that your ecu resieves data on how much was flowing through and what temperature it had. The intake improves the amount that flows through. When the ecu recieves data saying that more air is coming through, it dumps more gas. That also makes the engine smoother. Now when u put the cold air on, you lower the temperature, and again the ecu is dumping more fuel in. So the only way i see it improving the mpg is when u are cruising.... but it's reall questionable... my stats on when i had the intake were something like this:
Stock - 23.5mpg
Injen + CAI - 22.5mpg
Injen + CAI + Tornado - 21mpg
