Old 08-30-2007, 07:10 PM   #1
Folken
Folken's Avatar
Folken is an unknown quantity at this point
Quick Ca18det Wastegate question
Stock t25 turbo/wastegate I don't know which vacuum line to tap in to for my wastegate and I wanna be sure before i do anything... I was thinking about trying to tap the line between the TB and the hotpipe on my fmic... let the flaming begin!
Folken is offline   Reply With Quote
Old 08-31-2007, 10:08 AM   #2
Folken
Folken's Avatar
let me change the question, for you guys w/ sr20s or ca18s in... are you running the wastegate vacuum hose to the FMIC piping somewhere before the TB plate or somewhere after like the FPR hose?
Old 09-01-2007, 07:57 PM   #3
superJoy
superJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of lightsuperJoy is a glorious beacon of light
Vacuum source on the hot pipe is fine for the wastegate actuator.
Basically, the closer to the turbo the better. It'll work post-TB but it won't work as well.
superJoy is offline   Reply With Quote
Old 09-01-2007, 08:31 PM   #4
Folken
Folken's Avatar
thanks, I ended up using the FPR line... I guess i need to retee somewhere closer... the tapping before the turbo in to the intake pipe wouldn't work would it?
