#91 |
I have the 2/3 circle camber plates and they have the spring binding issue.
240on430, just to make it clear, you didn't say if it fixed the problem or not. After replacing the plates, is the problem gone 100%? |
#92 |
I'm using KTS coilovers. I don't have any sound while turning but I have to "help" the steering wheel to go back to center position and every so often I have to re-tighten the spring lock nuts.
#93 |
you are right about the wheel going back to center. with the old mounts the wheel use to be straight sometimes and tracked sometimes.
#94 |
i'm gonna call stance as well since i'm having the same problem.
i went to get an alignment and the place said that i have memory steer, as the wheel will continue to follow the same route as you were going (won't return back to center). but it only happens on one side.... then i read the rest of the posts on this thread and ppl are saying the same thing and also experiencing stiff steering. any updates on the new hardware? |
#95 |
for the people that don't want to read my whole post...with the new replacement mounts, the noise went away, steering is lighter, and the the steering effort from left to right is the same....the problems were fixed with new front mounts.
#97 | ||
![]() Join Date: May 2004
This vid was taken 4/20/07 btw...not long after i bought them. [ame]http://www.youtube.com/watch?v=rk6zeAgka5g[/ame] (edit: woah...i didnt know u could embed youtube videos on this forum, thats pretty awesome) Quote:
That is GREAT news to hear...i'm definitely gonna need to call them up and see if i can get some replacements...unfortunately the only documentation i still have is the packing slip that came taped to the box, not even the invoice. Hopefully they'll be able to do something. Hah, maybe they'll hook me up since i started this thread...ynever know. |
#99 | |
they didn't ask where or when i got the coilovers, but i told them i had them for a couple months. the plate is defective and i'm sure they'll be glad to send you new mounts in exchange for your old mounts. they include a ups label in the box to return the old mounts. |
#100 | |
Yeah, i have the old style 2/3 plates. Well, its also good to know that they didnt get all into trying to find your invoice number and stuff like that when u got yours. Ill definately be getting in contact with them soon, then perhaps i too can be rid of this annoyance. Yay. |
#101 |
Ack, I emailed Stance yesterday about them since 240on430 reported his success. Got a response today saying they are waiting for responses from the 3 other testers before sending them out. Whoever you are (logik23, etc.), please try it out and respond to them. Thanks.
#102 | |
#103 |
![]() Join Date: May 2005
I got my new mounts, but they sent me 2/3 mounts, not full circle. I haven't installed them yet, but I'm going to try to do it tomorrow or Sunday, I work so much it's hard to find time. Anyways, I'll get back to you guys ASAP!
-1992 Nissan 240SX LE -1998 Jeep Grand Cherokee 5.9 Limited |
#104 |
how does the top look? the same as the old mounts? the mounts you have mounted now are the 2/3 also?
#105 |
It looks like this was their plan all along and it's the reason why they are not sending us the replacement mounts yet. Here's my theory:
They were originally using the full circle mounts which were great. You can see in KiDyNomiTe's review (4th and 6th pictures) that the mount has the full circle. Then somewhere along the line, they decided to change to the 2/3 circle (reducing the materials = cheaper and/or lighter?). Then it turns out that the 2/3 circle mounts have seized ball joints. I'm guessing they don't have S13s/S14s at their disposal for testing so they are sending out some full circle and some 2/3 circle mounts as replacements. They're probably going to hear that the full circles fixed the problem and the 2/3 circles still have the problem. Well, that's my theory anyway. |
#106 | |
That is most likely what happened. The ones I had originally were 2/3. one is way to tight and the other doesn't move at all. Now I installed my replacement mounts (2/3) and they are worst, neither of them move at all this time. I'll call them after the weekend and get them to send me some full circle mounts. Fucking idiots use me as a test subjet for their crap. I have better things to do then take my coils apart every week.
#107 | |
#108 | |
Also, it shouldn't take too long to replace the mounts. Just jack up the car, unbolt the top nut, slide the strut out of the mount, unbolt the mount, bolt in new mount, slide strut back in, bolt on top nut. No need to take the coilovers out. |
#109 |
I have gr+pro's on my s13 and Ive been having the binding problem since day one and Ive been on the phone with Stance at least once a week trying to fix the problem. So I finally got them to send me new mounts after trying everything I could think of and everything they suggested.
So, i just received my new mounts in the mail and they are still the 2/3 circle mounts. I guess Ill put them in anyway and see what happens. Im gonna be pissed if I have the pull the coilover out one more time, this is rediculous after paying $1200. |
#110 |
I also noticed that this might a problem with mine pretty soon. I noticed that it will click sometimes and other times i wont feel it click when I turn the knob. I really hope its not getting screwed up.
#111 |
Yeah, you don't need to take the coilovers out, just undo the top 3 bolts on both sides, pull them both down (you can't really pull them down one at a time because of the sway bar). Then undo the 4 little allean key bolt, then undo the top nut, it's pretty easy. You could just undo the allen key bolts and leave the top plate attached to the car, but I find its harder to line up the allen key bolts them to line up the top bolts in the hole of the strut tower.
By not undoing the bottom bracket, you don't lose your allignement. (As long as you put the allen bolts back in the same place, but thats easy, just count the lines.
#112 | |
#113 |
well i installed my new mounts(2/3 circle replacements) today. It definitely isnt clunking anymore the way it was but it does it randomly but not as loud.
But now I have another problem...At a standstill when i turn the wheel the steering wheel vibrates but it doesnt clunk as loudly. Its too late now but Ill double check everything tomorrow to make sure its tight. Also, I noticed that the wheel isnt pulling as much after a tight turn. |
#114 |
Full circle is the only way to go. It seems thats not only is the 2/3 defective, but they have varrying quality. Some are partialy seized, some are almost seized and some are completly seized.
#116 |
I haven't added preload, but there is a small amount preload already.so if anyone is about to install full circle mounts, add more than a couple rotations of preload and let us know if you have any noise problems.if nobody reports back...ill have a good amount of time to add more preload on wednesday.
#117 |
I just installed a set of GR +'s and having the same exact problems everyone here has. But my coilovers for some reason make a clunking noise when i turn and when i drive over a bump. Any bump i hit it makes a really loud nasty clunking noise like something is loose. Anyone have that problem?
#118 | |
#119 |
#120 |
i know its not the exhause for sure because its coming from the front, it sounds like the strut is moving... but i know its no because i had my friend drive my car while i checked everything out, i have no yet torqued the top nut down yet, so i'll try to zap it lightly with a torque gun.
