Old 09-03-2007, 08:52 AM   #1
slow240
slow240 is a well-known jackass
SR weird boost problem
hello,
after running hard at an extended period in the rain, i suddenly experienced some sort of boost limiter. i usually boost to 15psi, but for some reason when im about to reach max boost the engine hits some sort of limiter. it sounds just like the bee-r rev-limiter only difference it just limits my boost. driving at partial throttle or anything except wot i can reach 7k without any sign of anything wrong. its just the boost gets limited at wot.
has anyone experienced this? any info is appreciated.
i have an s13 redtop, z32maf, 550cc injectors, emanage blue.
slow240 is offline   Reply With Quote
Old 09-03-2007, 11:37 AM   #2
guitaraholic
guitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of light
damn, you have what sounds like the exact same problem I have. If you find anything out let me know, I'll do the same.
guitaraholic is offline   Reply With Quote
Old 09-03-2007, 12:04 PM   #3
Gjohnson7
Gjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura about
Stock T25???????? Blov??????
LSX Kouki Project, swap completed in Dec 09
Gjohnson7 is offline   Reply With Quote
Old 09-04-2007, 05:11 AM   #4
slow240
@gutaraholic, sucks to not boost to the usual levels huh. i hope someone can help us with this.
i have a gtir t28 and ssqv vta, but i was boosting 16psi fine for weeks with no problems at all. and from my experience if ever i was leaking from the vta ssqv it wouldnt sound or have symptoms as i have. or is it the bov??
Old 09-04-2007, 07:03 AM   #5
slow240
tried the car out again tonight. surprisingly the problem is gone. i guess driving on the highway at 150kph cruising speed in the pouring rain will cause some water droplets to slip through the filter and pass by the maf. my intake is placed right behind one of the airdams on my bumper.
i hope its just that...
guitaraholic, try your car out after a few days, maybe the water thats causing the misfire is all dried up by then.
Old 09-05-2007, 03:05 AM   #6
skylindrftr
skylindrftr's Avatar
Trader Rating: (26)
skylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfection
Feedback Score: 26 reviews
if you have a boost leak, i believe there is a sticky or faq on how to make your own home made boost leak tester...
skylindrftr is offline   Reply With Quote
Old 09-05-2007, 10:16 AM   #7
guitaraholic
Thanks for the tip slow,, actually found my problem might be elsewhere though. I moved around my Boost Gauge to share the same vacuum line as the BOV instead of the WGA, and now I am getting a reading of 15psi and more (if I let it), so its stuttering because its boosting too high and either blowing out the spark or detonating, either way, I am keeping off the pedal for now. I have the WGA hooked straight off one of the vacuum line nipples on the manifold, still getting crazy boost. Anyone have any suggestions? I do plan on pressurizing the WGA to see if it functions like normal tonight.
Old 09-05-2007, 10:49 AM   #8
Koopa Troopa
Koopa Troopa's Avatar
Koopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfection
Send a message via AIM to Koopa Troopa
Water getting into your intake is just water injection.. It'll turn the drops into vapor and just super cool your fuel/air mixture.. Don't worry about water droplets getting into your shit..
Buy my Stillway shifter!
Koopa Troopa is offline   Reply With Quote
Old 09-06-2007, 12:35 AM   #9
slow240
guitar, i think the best place to tap the boost gauge is as near as possible to the intake manifold. yeah sounds like you were overboosting, good thing your ecu cuts you off before you did damage.
koopa, yeah.. thats good after the maf. but i dont think water droplets on the hot wire of the maf is good. it could cause a spike in the maf voltage because of the sudden drop in temperature. maybe thats why the ecu suddenly limit the boost.
