Old 09-07-2007, 12:17 AM   #1
prang11
prang11's Avatar
prang11 will become famous soon enoughprang11 will become famous soon enoughprang11 will become famous soon enoughprang11 will become famous soon enough
Mas or O2 problem
My brothers redtop is having some problems.
The car is having a hard time holding an idle. I expect this to either be because his MAS or his O2 sensor is fucked. The car will idle at 750rpm, once throtle is applied it will stutter then go no higher than 2500rpm. Obviously an ecu problem, code 55, 55 - Other Malfunction. CONSULT Terminal Required....
What we have tried: We put my AEM Uego on the car with a bung over 18" behind the turbo with the white wire (0-5 volt) hooked up to the stock O2 sensor read out wire. I always thought this could replace the stock O2 sensor, I may be wrong. The Idle came out at 15.3:1, seems a bit lean.
We replaced what we thought was a leaking injector but nothing changed. Maybe we need to have all 4 injectors rebuilt
The MAS is a stock KA24e and has worked fine before. This seems to be the only thing that has not been tested or changed.
The cars mods:
Stock redtop
3" elbow, DP, and exhaust
Front mount, ssqv
We have an safc not hooked up.
The car ran for a good 10 hours before any problems started. We put the elbow, DP, exhaust and intercoller on then had it tuned by unnatural. It ran fine for a few hours then problems started.
So MAS is my guess. Any other ideas??
Thanks guys.
prang11 is offline   Reply With Quote
Old 09-07-2007, 12:48 AM   #2
240tek
240tek is an unknown quantity at this point
IACV, Check it's not clogged and working properly.
240tek is offline   Reply With Quote
Old 09-07-2007, 01:22 AM   #3
prang11
prang11's Avatar
IACV, would this cause it to run rich?
IACV stands for? Now that I go search for it.
Thank you, any one else?
Old 09-07-2007, 01:57 AM   #4
GSXRJJordan
GSXRJJordan's Avatar
15.3:1 is too lean, not too rich. That's actually not bad for idle on stock engine management.
IACV = Idle Air Control Valve. Pull the big vacuum line going into your intake piping, next to the throttle body. Shoot a bunch of carb cleaner in there, start the car (which will burn it out), repeat. Basically, that's it.
Old 09-07-2007, 12:34 PM   #5
prang11
prang11's Avatar
Well you got me on the lean. Probably shouldnt be posting technical crap after a "F I F" Fifth or vodka. So clean the IACV, I spoke with unnatural and they immediatly said replace the MAS.
Guess we are on the hunt for a local sohc MAS.
Oh boy.
Old 09-07-2007, 12:58 PM   #6
los_inc
los_inc's Avatar
los_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond repute
Send a message via AIM to los_inc
DON"T USE CARB CLEANER!!!!11!!!!!!!!
use throttle body cleaner
carb cleaner will destroy all rubber it touches
-los
i once had to use about a can and a half to get my iacv clean
los_inc is offline   Reply With Quote
Old 09-07-2007, 01:12 PM   #7
prang11
prang11's Avatar
Throttle body cleaner it is. I may have to try this on my stock KA to make that thing idle a bit better. Just spray it in there. Turn car on. Wash rinse and repeat till it idles better.
Thanks
