Old 09-20-2007, 08:26 AM   #1
SimpleS14
SimpleS14's Avatar
Clutch pedal feeling awkward...
So I recently replaced my clutch, flywheel, slave cylinder and clutch line (to the slave) and bled the system. For some reason the pedal is slow to come back up and I have alot of play where I can push the clutch pedal half way before it engages or disengages.
I've ordered some speed bleeders that should be coming in later today, so I'm going to put those on the dampener and slave cylinder, while wrapping telfon around the clutch line threads. Then I will see if I can adjust the clutch pedal.
With that said...does anyone have any other suggestions?
Goals are dreams with a deadline.
L.H.O.O.Q.
SimpleS14 is offline   Reply With Quote
Old 09-20-2007, 08:32 AM   #2
Super Soap
Super Soap is an unknown quantity at this point
exactly like that george, now come pick me up!
Super Soap is offline   Reply With Quote
Old 09-20-2007, 08:36 AM   #3
ecuastyle84
ecuastyle84's Avatar
ecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to all
Send a message via AIM to ecuastyle84
did you replace the clutch master cylinder?...same thing happen to me when doing my clutch...im pretty sure thats your problem.
ecuastyle84 is offline   Reply With Quote
Old 09-20-2007, 12:37 PM   #4
Neejay
Neejay's Avatar
Neejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfection
Sounds like what mine was doing when I had air in the system. Speedbleeder should take care of that.
I also installed a speedbleeder (only one, because I removed the damper) and it made it easy as cake.
Neejay is offline   Reply With Quote
Old 09-20-2007, 02:30 PM   #5
SimpleS14
SimpleS14's Avatar
How does the pedal feel with the damper gone?
L.H.O.O.Q.
Old 09-20-2007, 02:40 PM   #6
Neejay
Neejay's Avatar
Well, it definitely doesn't have that "smooth" feeling anymore, but it does feel more responsive. But I also added a SS clutch line at the same time, so that may have helped a bit too.
I did SS clutch line + speedbleeder + damper removal at the same time.
The thing is though, I just started driving manual. I've been driving manual for about 3-4 weeks now...
Old 09-20-2007, 07:09 PM   #7
ilovecoupes
ilovecoupes's Avatar
ilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to behold
yea my shit hardly comes back up and ive already bled it for an hour. all new master and slave
ilovecoupes is offline   Reply With Quote
