Old 09-23-2007, 02:35 PM   #1
slo
slo is making a name for him/her selfslo is making a name for him/her self
s13 Bad TPS???
Hey guys, i've searched for this to no success....
It's really the driveability issue. No CEL's. If I'm easy and slow on the throttle, everything's fine. It's when I WOT the gas pedal when the car seems to hesitate for a second then accelerates. Do you think the TPS went bad?
It's the '92 240sx with the stock ka. Thanks a lot in advance guys. You guys rock!!!
slo is offline   Reply With Quote
Old 09-23-2007, 02:47 PM   #2
bo2o
bo2o's Avatar
bo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfection
check your tps see if the voltage even gets up to 4.5 ref voltage.
sounds to me like you have a fuel problem
fuel filter, fuel pump issue
fS! vlsd ! slim fans ! hid kits ! lug nuts !
http://www.zilvia.net/f/search.php?d...earchuser=bo2o
^^^click^^^
bo2o is offline   Reply With Quote
Old 09-23-2007, 02:54 PM   #3
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
It could also be a lazy MAF sensor but that is not possible to test for without a lab scope. Try cleaning and tightening the connections. (forboth the MAF and TPS)
Old 09-23-2007, 09:51 PM   #4
s13rookie
s13rookie's Avatar
s13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant future
Send a message via AIM to s13rookie
It could be a TPS issue without it having gone bad. Its possible it just got out range, which you can check/fix in 5 mins with a 6mm wrench and a meter.
It could also be your fuel system, as was mentioned above. You would have a lot more issues than just at wot if it was the MAF though.
Start with the cheap and easy fixes first though. Tps, maf, connections, fuel filter, etc
good luck
Ive spent most of my money on cars and women...the rest i wasted
s13rookie is offline   Reply With Quote
