Old 09-24-2007, 03:01 AM   #1
t . b o z
t . b o z's Avatar
t . b o z will become famous soon enought . b o z will become famous soon enought . b o z will become famous soon enough
For those with aftermarket tension rods...
I recently replaced my worn out OEM tension rods with the SPL units. I realize that they are spherical rod ends, and that they will probably make some noise, but should they make a popping noise when making tight radius turns? Or at all?
t . b o z is offline   Reply With Quote
Old 09-24-2007, 03:23 AM   #2
Neejay
Neejay's Avatar
Neejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfection
highly doubt it...
Be sure to contact SPL tomorrow. Are you 100% sure its the tension rods?
Neejay is offline   Reply With Quote
Old 09-24-2007, 03:31 AM   #3
GSXRJJordan
GSXRJJordan's Avatar
popping noise could be bolts stripping out... I can't really think of anything else. The only way they're noisier is bumps/rattles while driving over bumps and trying to turn, not like "bangs" or "popping". Something's definitely wrong.
Old 09-24-2007, 03:49 AM   #4
az_240
az_240's Avatar
Trader Rating: (41)
az_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really nice
Feedback Score: 41 reviews
Send a message via AIM to az_240
torque em down tight..... i just installed mine the other day and they only popping noise I get is from the 2 way diff or from the 6 puck clutch.
Awesome tension rods btw
az_240 is offline   Reply With Quote
Old 09-24-2007, 11:57 AM   #5
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
are your tie rods in good condition? since you did mention that you replaced your worn out tension rods, usually popping when turning is tie rods as well, so i'd check those, it could just be since you got those back up to par, now your noticing other worn out bushings
Slip Gypsies Blog
not sure if you realize this
Old 09-24-2007, 12:04 PM   #6
Neejay
Neejay's Avatar
Very good point...especially when going from rubber to spherical tension rods...now the tie rods are possibly showing signs of their age...
Old 09-25-2007, 12:03 AM   #7
t . b o z
t . b o z's Avatar
Nope. They're Tein inners and outers, installed about 5 months ago.
And besides, the steering feels nice and tight, no slop in the steering wheel. I dont get it, I look at my ball joints, they look fine, no grease coming out.. all the bolts on the front carriage are on tight. Im at a loss.
Old 09-25-2007, 12:19 AM   #8
WilloW
WilloW's Avatar
WilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfection
Send a message via AIM to WilloW Send a message via Yahoo to WilloW
I've got the SPL TC rods on mine and there's no noise, so you might want to go back and check like they said.
WilloW is offline   Reply With Quote
Old 09-25-2007, 02:38 AM   #9
kandyflip445
kandyflip445's Avatar
Could be the strut mounts seizing. If the bearings are toast in those it can pop when you turn.
My 240 vBgarage
Old 09-25-2007, 03:25 AM   #10
s13monkey
s13monkey's Avatar
s13monkey is a splendid one to beholds13monkey is a splendid one to beholds13monkey is a splendid one to beholds13monkey is a splendid one to beholds13monkey is a splendid one to beholds13monkey is a splendid one to beholds13monkey is a splendid one to beholds13monkey is a splendid one to beholds13monkey is a splendid one to beholds13monkey is a splendid one to beholds13monkey is a splendid one to behold
Send a message via AIM to s13monkey Send a message via Yahoo to s13monkey
check the nuts on the control arm i had the same problem sometimes if your driving on a bad road the vibration can cause the nuts to come loose or they were just not tight enough. if the poping noise happens when you brake it that.
s13monkey is offline   Reply With Quote
