Old 09-25-2007, 10:01 PM   #1
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
Replacing motor mounts- EASY WAY???
I'm replacing my motor mounts on my s14 KA. I have access to many tools, multiple jacks, and an engine hoist.
With that being said, does anyone have a quick tip/easy method of doing this? How much time would you allot?
Thanks!
(right now i'm thinking of just chaining the engine/exhaust manifolds, lifting motor up few inches with hoist(with tranny mount still connected) and replace... Any better ideas?)
gotta240 is offline   Reply With Quote
Old 09-25-2007, 11:12 PM   #2
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
I had to drop the sub frame a bit to work it out.
Jung918 is offline   Reply With Quote
Old 09-26-2007, 02:18 AM   #3
az_240
az_240's Avatar
Trader Rating: (41)
az_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really nice
Feedback Score: 41 reviews
Send a message via AIM to az_240
its a bitch... I had to do it with 2x4s and two jacks. Just do one side at a time. took me a couple hours to do.
az_240 is offline   Reply With Quote
Old 09-26-2007, 12:14 PM   #4
thejapino
thejapino's Avatar
thejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfection
I loosened the tranny crossmember/chassis bolts. Don't undo them, just loosen them. It gives you more angle to work with when you raise the motor off of the mounts.
WTB: 13kg springs! Eibach, Stance, or Swift.
thejapino is offline   Reply With Quote
Old 09-26-2007, 12:22 PM   #5
adoboboy
adoboboy's Avatar
adoboboy is just really niceadoboboy is just really niceadoboboy is just really niceadoboboy is just really niceadoboboy is just really niceadoboboy is just really niceadoboboy is just really niceadoboboy is just really niceadoboboy is just really nice
Send a message via AIM to adoboboy
I used one jack. lifted at the oil pan, put a block of wood under the pan so you don't dent it.
Replaced them one at a time.
The driver side is easier to do, I'd start there.
Had to take off the tranny cross member to put the back one on but yeah it'll take a couple of hours the first time you do it.
adoboboy is offline   Reply With Quote
Old 09-26-2007, 12:33 PM   #6
Dream240
Dream240's Avatar
- Loosen the front subframe bolts (4) BUT DON'T REMOVE THEM OR THE ENGINE WILL KILL YOU!!!
- Also loosen the 4 tranny crossmember bolts to give you some free play.
- Take off the top locking nut on each motor mount.
- Jack up the engine from the back where the tranny meets the engine, use a wood block to avoid damage.
- Once you have the engine supported by the jack, remoe the lower locking nuts on the mounts.
- Continue to jack up the engine until you can guide the mounts out, bottom stud first.
- the reverse order for the re-install.
GL
Old 09-26-2007, 12:48 PM   #7
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
Lift car
Secure engine with hoist (this avoids lifting/supporting the engine on the oil pan)
Loosen tranny mount so you can swivel engine
Loosen cross member and drop it ~1 inch (Don't completely remove it)
Soak mounts bolts in liquid wrench and wait for a bit if they're stubborn.
Use a swivel socket to remove the mount bolts if possible
reassemble your shit
Lower car onto ramps and make sure everything is tight.
Old 09-26-2007, 12:53 PM   #8
KFLS14
KFLS14's Avatar
KFLS14 will become famous soon enoughKFLS14 will become famous soon enoughKFLS14 will become famous soon enoughKFLS14 will become famous soon enough
I just did this last weekend but my trans was out so it was a tad easier. I wrapped around the intake manifold and lifted that up then,removed. Left it unbolted and then wrapped around the engine metal motor mount on block. I used some strong pulling neon orange rope tow/anchoring thing lol Took me 1hr . I did this to my friends s14 a while back with trans in, just had to hoist it up and remove a bracket off the firewall. Just make sure you don't get hung up on anything in the bay when hoisitng. Are you doing polyeurth. mounts? if so they are great nasty!
*When reinstalling mounts do not install the bottom nut on the mount. You need free play in most cases..if you have a buddy he can guide the mount in as you slowly lower the hoist.He will make sure bolt lines up into hole the gets his hand out when its lined up. I saw a two buddies struggling for about 30mins+ beating on the engine using pry bars cause they bolted the lower motor mounts in.
KFLS14 is offline   Reply With Quote
Old 09-26-2007, 01:04 PM   #9
aznpoopy
aznpoopy's Avatar
hm
this is how i did it in like 2003
#0 loosen upper motor mount bolts
#1 raise car
#2 support motor by jacking it from where the tranny meets the motor; no need to raise it alot (i did it by the oil pan cuz i'm not smart)
#3 unbolt bottom bolts
#4 curse cuz they are stuck and you also need a swiveling socket for one of them
#5 pb blast, the right socket, a torch and a big breaker bar
#6 curse cuz its a pain in the ass to slide the motor mount in place
#7 bolt everything back, replace, etc
Old 09-26-2007, 01:19 PM   #10
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Passanger side mount bolt is a snap iirc.
Driver side sits at a funky angle and you can strip the nut if you use a regular socket. Don't ask how I know this...
Old 09-26-2007, 01:32 PM   #11
MrChow
MrChow's Avatar
MrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant future
Send a message via AIM to MrChow
Originally Posted by aznpoopy View Post
hm
#1 raise car
What I did. It was like only a 30 min job. One problem I had was that I had to take off my oil filter.
Originally Posted by TheSquidd View Post
Are you the guys that buy your KSports and just turn the dampening knob to 32?
"It's stiff and hurts my livers! I'M A HANDLING GOD!"
WTT: 2 way for 1.5 way LSD
MrChow is offline   Reply With Quote
Old 09-26-2007, 01:37 PM   #12
smelly240
smelly240's Avatar
i hate doing them... the end.
or is it - I had to burn them apart once and then cut that shit with a whizwheel and nail it with an air hammer (shit was rounded off)
another time i broke the bolt - that worked out ok tho.
on one car we used the urethane windowweld shit and it is working good still.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
