Old 09-26-2007, 06:51 PM   #1
riander4
riander4 is an unknown quantity at this point
Strange sr20 Problem
Hey guys i searched a few key words and couldnt find anything related to my problem so here it goes.
My redtop sr20, smic, hks ssqv, stock boost, 3 inch exhaust, is how it sits.
After sitting for the night ( temps sometimes dip as low as -5 right now where i live) I will start the car up, and it will bog out between 500-1500 rpm for about 5 seconds. It feels like its going to stall, but never has, and after 5-10 seconds it comes up to around 1500 rpm which it stays at for a few minutes before it slowly warms up and goes back to normal.
I have an apex'i EBC, and when driving its reads my boost gets to .50 atm (7psi) And holds steady, so i dont think its a boost leak.
Idling is quiet normal, car sits and idles between 860-930 rpm, all the time.
Also what i find is strange, when the car is bogging immediatly following startup, if i give the engine full throttle, there is NO response, NO throttle response until the engine has figured itself out and corrects this bogging problem (like i said 5 or so seconds after start up.)
If anyone has had this problem before or can shed some light on it, it would be greatly appreciated, because as it gets colder, i can only imagine this getting worse!!
Thanks
Ryan
riander4 is offline   Reply With Quote
Old 09-26-2007, 07:04 PM   #2
Sil-Eighty SE-K
Sil-Eighty SE-K's Avatar
Sil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfection
Send a message via AIM to Sil-Eighty SE-K
check you ignition timing and DONT USE THE LOOP in the back of the engine.... mock up a makeshift inductive pickup with a plug wire between coil #1 and the plug in cyl #1
also try checking the TPS signal with a volt meter.... should sweep from around .5v closed to about 4.5v WOT (give or take .1-.2v) your pretty much looking for a random spike in voltage (5v or 0v) anywhere in the sweep
also could be the temp sensor to the ecu?
Originally Posted by JTunedMotorsports View Post
get off the thread...no one cares...
Sil-Eighty SE-K is offline   Reply With Quote
