Old 09-27-2007, 07:38 PM   #1
1989rps13
1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute
Send a message via AIM to 1989rps13
do motor mounts give better response??
well ive had my sr for a couple of months and it was pulling soo nice and fast i loved it in everyway
but now my engine shakes a lot
and whenever i accelerate it lags to accelerate
im like wtf
and extremely dissapointed
i feel like im driving on a sr20det thats not even turbo'd
1989rps13 is offline   Reply With Quote
Old 09-27-2007, 07:44 PM   #2
240truk
240truk's Avatar
240truk has a spectacular aura about240truk has a spectacular aura about240truk has a spectacular aura about240truk has a spectacular aura about240truk has a spectacular aura about240truk has a spectacular aura about
I dont think your sr would feel that slow just because of the motor mounts. are you running on all the cylinders?
240truk is offline   Reply With Quote
Old 09-27-2007, 07:44 PM   #3
240sxScores
240sxScores's Avatar
240sxScores is making a name for him/her self240sxScores is making a name for him/her self
Send a message via AIM to 240sxScores
Did you check for boost leaks, or anything else?
240sxScores is offline   Reply With Quote
Old 09-27-2007, 07:54 PM   #4
1989rps13
idk why sometimes it feels slow and sometimes it acts right
l
Old 09-27-2007, 08:18 PM   #5
Dutchmalmiss
Dutchmalmiss's Avatar
Dutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfection
Send a message via AIM to Dutchmalmiss
then it's either wiring, a sensor, or a filter in need of replacement.
Pignose, biaaatch.
Dutchmalmiss is offline   Reply With Quote
Old 09-27-2007, 11:33 PM   #6
Rayne
Rayne's Avatar
Rayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfection
im like wtf
To answer the question....yes stiffer motor mounts will give better responce, in terms of transferring more power down the driveline. The less the engine and transmission moves the better. However there are trade offs when using stiffer motor mounts. The vehicle tends to shake more as the mounts get stiffer. If your car is a daily driver new stock mounts will be fine. Aftermarket, polyurethane, mounts are best used if the car is taken to the track regularly. Solid, aluminium, mounts.....are best used for track only cars that get trailered to and from the track.
Personally speaking I took an old set of stock mounts and refilled "impregnated" them with construction grade polyurethane adheasive. For the time being all of the additional vibrations is tolerable. The difference is noticble but tolerable......
If you want to go the route I did polyurethane sealant has more give than the adheasive. But will make things seem more solid without too many vibrations transferring into the cabin. Another thing....allow the motor mounts to cure naturally.
Rayne is offline   Reply With Quote
Old 09-28-2007, 07:41 AM   #7
supreme_1
supreme_1 is on the path to ruinsupreme_1 is on the path to ruinsupreme_1 is on the path to ruin
where did you get this construction grade polyeurathane adhesive?
supreme_1 is offline   Reply With Quote
Old 09-28-2007, 10:34 AM   #8
steve shadows
steve shadows's Avatar
you can get it like anywhere.
Ive done it too, use polyurethane caulk
Like Me on FaceBook !
Old 09-28-2007, 10:38 AM   #9
Kouki
Kouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud of
Use a tube of window weld on that shit
Kouki is offline   Reply With Quote
Old 09-28-2007, 10:50 AM   #10
1989rps13
well thanks for the feedback ima go look around for some motor mounts later on and get it done because wow i absolutely hate the engine vibration i get from the cabin plus just gets me sad poppin up the hood and seeing the whole engine vibrate as if its going to fall apart :/
Old 09-28-2007, 06:26 PM   #11
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
your problem has nothing to do with motor mounts...
fuck, why hasn't anyone told you to do this yet? Pop hood. Look through gab in hood at your motor. Start car. Did the motor move more than an inch or so?
Then, with ebrake on(and no one and nothing in front or behind the car obcviously), slowly disengage the clutch with the car in first and reverse. Dont drop it so the motor stalls, just let it out to see the motor move...
Shouldn't move too much.
gotta240 is offline   Reply With Quote
Old 09-28-2007, 07:43 PM   #12
SittinFlush
SittinFlush is an unknown quantity at this point
Color tube your looking for is Brown and Yellow IIRC. But I dont think your problem is a motor mount.
SittinFlush is offline   Reply With Quote
Old 09-29-2007, 01:39 AM   #13
Rayne
Rayne's Avatar
I bought it from Home Depot. I am not sure if you can buy any at Lowes. I have not checked there yet.
If you can not decide on which brand to get. PL is what I used on the set of mounts I have in my car. Liquid Nails, is what a lot people recommend. Either brand will do the job well. Personally speaking I have used both brands and it all boils down to how much are you willing to spend.
If and when you impregnate the mounts do not bake them. Allow them to cure naturally. You can find more information about the process on the site some where. Search for it.
Old 09-29-2007, 01:49 AM   #14
supreme_1
sorry for the hack but, right on thx for the info
Old 09-29-2007, 01:52 AM   #15
A Spec Products
A Spec Products's Avatar
Yes
I think so
I had my KA in my car, it ran fine, nothing special
Took motor out and realized one of the mounts was completely gone, like nothing, so motor was pretty much running on one mount
We put that same motor into another car with new mounts, that thing feels like the fastest KA ever
Only changed mounts
So yeah, I think it helps
A SPEC PRODUCTS CORP
Old 09-29-2007, 01:55 AM   #16
supreme_1
it is a little more responsive imo all my mounts were shot ( both engine, and tranny) now when i replaced all of them, i find that the engine doesnt shake at all, and that the throttle response is a little bit snappier but not to the " OH SHIT I JUST GAINED HP" extent.
