Old 10-01-2007, 05:06 PM   #1
iRun
iRun is an unknown quantity at this point
SARD Torque Control Valve
Ordered this from More-japan on Thursday and the UPS man nocked on my door this morining. Just wanted to post up some pics. Its the SARD Torque Control Valve, regulates the diameter of the exhaust piping. TCV has smaller piping diameter to give you torque at low rpm and opens up to give you more power up top. Im very impressed with the quality of the product. Im planning on installing it this coming weekend when Im free and Ill keep you guys updated.
iRun is offline   Reply With Quote
Old 10-01-2007, 05:18 PM   #2
Nikeboy355
Nikeboy355's Avatar
Nikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond repute
Looks like that fits where the stock cat goes...
How much and is there any controls or does it just work by itself?
Nikeboy355 is offline   Reply With Quote
Old 10-01-2007, 05:45 PM   #3
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
i believe that one works by itself. apexi makes something similar to this and you can control it
lexus baby
5t341tH is offline   Reply With Quote
Old 10-01-2007, 06:09 PM   #4
iRun
Yeah it basically bolts up where the stock cat is. It works off of exhaust backpressure. There is a spring loaded valve aand when exhaust pressures reach a certain limit, then the valve opens up releasing the backpressure.
Old 10-01-2007, 06:10 PM   #5
burnsauto
burnsauto's Avatar
yeah ive seen that thing before, its got a throttle cable setup on it (or something along those lines..) i was wondering how this setup worked....does the line go into the cars interior and you manually change the valves position, or does it run into the engine band and works off the throttle body...
Old 10-01-2007, 06:16 PM   #6
driftenthusiast
driftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to all
I have one friend with this, he says he felt a difference, but you can hear a rattle from inside it at low RPM.
nissan tech
driftenthusiast is offline   Reply With Quote
Old 10-01-2007, 06:26 PM   #7
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
How Much?! .
gotta240 is offline   Reply With Quote
Old 10-01-2007, 06:44 PM   #8
iRun
I paid $230 for it.
Old 10-01-2007, 08:41 PM   #9
5t341tH
5t341tH's Avatar
yea it goes into the interior and u can pull? it so it opens up
lexus baby
Old 10-01-2007, 08:48 PM   #10
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
Let us know how it goes. I was planning on getting one also.
I think some of you guys are mistaken this for the apexi one. That ones uses a cable that you route inside of the car to adjust the valve.
This sard product uses a spring system inside. When there is more pressure it opens up more.
Just FYI, Kure Motorsports is the US importer for sard.
Jung918 is offline   Reply With Quote
Old 10-01-2007, 08:53 PM   #11
Ian
Ian is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfection
Kure International actually
I've driven a car with one...I couldn't tell you if it did anything but rattle and help for noise at low throttle...
Team Pterodactyl
SHARK ATTACK!!!
LookOutDrift
Originally Posted by Brian
No it isn't
This is "cool stickers"
not"let's make our car look like a pile of shit and dead babies"
Ian is offline   Reply With Quote
Old 10-01-2007, 09:14 PM   #12
KwKouki
KwKouki's Avatar
KwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfection
Send a message via AIM to KwKouki
I was under the impression that the Apexi one was for exhaust note not performance
KwKouki is offline   Reply With Quote
Old 10-01-2007, 09:23 PM   #13
bloodangels13
bloodangels13's Avatar
bloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of light
Send a message via AIM to bloodangels13
that would be me.... i ran a 3'' test pipe before i could tell it made a nice difference... i drove it both ways the same day i changed to the sard tcv.. for daily the rattle is a lil annoyin to some but i got use to it... the increace in low end punch and slightly quicker spool make it all worth it
i've ran mine for about a year now with no issues also it did quit my car down a noticable amount ... when i first ran the TCV i ran a 3'' apexi N1 now im running a dual n1 and its even more of a difference
bloodangels13 is offline   Reply With Quote
Old 10-01-2007, 09:26 PM   #14
Jung918
Jung918's Avatar
^ Kure needs to make up their mind because their websie is http://www.kuremotorsports.com/
Old 10-01-2007, 11:21 PM   #15
PhilthyS13
PhilthyS13's Avatar
PhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfection
I've had one of these for over 6 months. I'm really happy with it. I had a 3.7 inch exhaust before with a test pipe, so it was pretty loud. I got a new 3 inch exhaust with this, so I can't make a pepsi challenge comparison, but I am really happy with it. It is quieter at low rpms, and it does open up when you hit the gas.
It's basically a 3 inch mushroom shaped plunger with a 1-1.5 inch hole in the center, so at low rpm is remains closed (exhaust passes through the small hole). You can see it best in the bottom pic. When you step on it, the plunger moves back, opening up to the full width of the pipe.
It does rattle slightly, but that's just when warming up the car and the rpms are up a little - like 2kish. It sounds like finger cymbals that belly dancers use. Not very bad and only noticeable to you.
It's rebuildable, too.
PhilthyS13 is offline   Reply With Quote
Old 10-02-2007, 12:35 AM   #16
jobestudios
jobestudios is a jewel in the roughjobestudios is a jewel in the roughjobestudios is a jewel in the roughjobestudios is a jewel in the roughjobestudios is a jewel in the roughjobestudios is a jewel in the roughjobestudios is a jewel in the rough
post pics looking inside please I wonder what system the mines r34 uses, looks completely different, and computer controlled.
-Jackson.Vaughn.Photography-
jobestudios is offline   Reply With Quote
Old 10-02-2007, 09:15 AM   #17
!Zar!
!Zar!'s Avatar
I've had this for ages.
It's a waste of money. All it does is quiets your car down a little.
Let alone, it's pointless to have any backpressure on a turbo car.
After time the soot and age will make the plunger stick.
Shit is weak.
Old 10-02-2007, 10:05 AM   #18
iRun
Here's a pic of the inside. When exhaust pressure builds up, the valve opens and exhaust gas is allowed to flow through the hole as well as around the sides. Here's the link to the full description:
http://www.more-japan.com/SARD-Torqu...s-p-16892.html
Old 10-02-2007, 10:40 AM   #19
steve shadows
steve shadows's Avatar
that sounds like a horrible nightmare.
no thanks
Like Me on FaceBook !
Old 10-02-2007, 11:27 AM   #20
smelly240
smelly240's Avatar
I'm not sure what kind of car i would put this on... but i know it wouldnt be mine.
I have a 3in hiflow cat and that quieted my car down some (til the ewg opens anyway) and it made it sound deeper - where before it sounded snarly and mean... so if u want the car quieter just get a cat (i got a cat because i need it to get my car registered as a collectible - must meet certain amount of emissions regulations )
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
Old 10-02-2007, 12:03 PM   #21
azndoc
azndoc's Avatar
Trader Rating: (47)
Feedback Score: 47 reviews
I've always known it to be Kure International. Their great people. Dealt with them alot over the past year.
Both the website
and
www.kure-international.com
both websites works and lead to the company.
Old 10-02-2007, 01:30 PM   #22
Nikeboy355
Nikeboy355's Avatar
I agree with Steve... This is not a good thing...
Old 10-02-2007, 01:32 PM   #23
Koopa Troopa
Koopa Troopa's Avatar
Koopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfection
Send a message via AIM to Koopa Troopa
You are correct
Buy my Stillway shifter!
Koopa Troopa is offline   Reply With Quote
Old 10-02-2007, 04:26 PM   #24
Jung918
Jung918's Avatar
Both the website
and
Do you have an account with them?
Old 10-03-2007, 05:21 PM   #25
iRun
There's alot of hater's but I wouldnt knock a product before youve tried it. A few members on here have run this with sucess and my cousin actually runs this on his 240 and he likes it. So I will install it and keep you guys posted.
Old 10-03-2007, 05:42 PM   #26
GSXRJJordan
GSXRJJordan's Avatar
The only way I'd put up with any additional rattles (especially in the cop-unfriendly zone of idle-3000rpm) would be if it could spool a GT3071 or TD06-20G a few hundred RPM faster... otherwise I'll just stick with a $30 straight 3" test pipe into my Apexi WS Noir. Let us know how you like it, and what kind of setup you're running.
Old 10-04-2007, 09:23 AM   #27
!Zar!
!Zar!'s Avatar
Shit is weak.
You Fail.
Your friend is just hurt over the fact that his butt dyno is the only thing that changed when he installed that.
Old 10-04-2007, 11:02 AM   #28
steve shadows
oooooh I love butt dynos!
Old 10-04-2007, 11:09 AM   #29
misfitsfreak81
misfitsfreak81's Avatar
misfitsfreak81 is an unknown quantity at this point
SR
I do. Do you need something? let me know.
mike
North Shore Performance Auto
misfitsfreak81 is offline   Reply With Quote
Old 12-06-2007, 12:24 PM   #30
EAT Motorsports
EAT Motorsports's Avatar
EAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of light
Send a message via AIM to EAT Motorsports
SARD TCV is on sale for $160 these are best to quiet your car down and give you some backpressure out of boost... less drone less poping with that 3inch exhaust. It will give you some low end and isn't much more expensive than what some test pipes are going for...
http://www.zilvia.net/f/showthread.php?t=167288
EAT Motorsports is offline   Reply With Quote
