Old 10-07-2007, 04:00 PM   #1
d0pe240
d0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of light
cusco coils
noooooooooooooooothing
d0pe240 is offline   Reply With Quote
Old 10-07-2007, 04:36 PM   #2
sliEighty
sliEighty's Avatar
sliEighty is making a name for him/her selfsliEighty is making a name for him/her self
Send a message via AIM to sliEighty
is the rear leaking at all, you might have to rebuild them
livin on the east cost is harder then you think...
ECM for life lll
sliEighty is offline   Reply With Quote
Old 10-07-2007, 04:45 PM   #3
d0pe240
nope the rear isn't leaking. all of them are in good shape. im a noob at suspension. ill try to get pictures up tho.
Old 10-07-2007, 06:10 PM   #4
LimitedEdition
LimitedEdition is a name known to allLimitedEdition is a name known to allLimitedEdition is a name known to allLimitedEdition is a name known to allLimitedEdition is a name known to allLimitedEdition is a name known to allLimitedEdition is a name known to allLimitedEdition is a name known to allLimitedEdition is a name known to allLimitedEdition is a name known to allLimitedEdition is a name known to all
The collars are locked. You should have gotten two wrenches to unlock and adjust them. They just turn. If you dont have the wrenches, I usually just grab a Flathead and LIGHTLY tap on of them until it loosens. Then lower to the desired hieght. As for dampening, play with them. If they dont tighten, you might need a rebuild.
LimitedEdition is offline   Reply With Quote
Old 10-08-2007, 01:52 PM   #5
d0pe240
So your saying adjust it by moving the collars that the spring is sitting on? the dampenings are tight and i can hear them click each time.
Old 10-08-2007, 03:17 PM   #6
d0pe240
also i was wondering, how do you know how much preload is enough?
Old 10-08-2007, 03:21 PM   #7
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
usually you would want zero preload or only a couple of mm of preload. zero preload is when the spring is nice and taught between the locking plates and to the upper hat. basically you just set it so that the spring doesnt jiggle around and isn't compressed. you adjust ride height by lowering.raising the entire shock body (lower locking plate/nut whatever its called). what are your spring rates?
Old 10-08-2007, 05:18 PM   #8
d0pe240
their 7/5. in the picture, does that look like an ok perload? thanks for the help guys.
Old 10-08-2007, 06:01 PM   #9
all stock
all stock is on the path to ruinall stock is on the path to ruin
doesn't look like you can adjust much preload with that helper spring there.
NASA PTD/SCCA ITS
all stock is offline   Reply With Quote
Old 10-08-2007, 06:07 PM   #10
d0pe240
so it can come out? i read helper springs give a more better ride, so if it can come out, the ride would be harsh?
