Old 10-13-2007, 12:43 PM   #1
nanner47
nanner47 will become famous soon enoughnanner47 will become famous soon enoughnanner47 will become famous soon enoughnanner47 will become famous soon enough
powersteering leak = (
So the steering in my 90 240 has been acting up recently. When i turn the wheel at full lock the power steering belt stops moving which causes the steering wheel to pulsate. So i got under the car and noticed that when i lock the drivers side wheel, fluid stars leaking out of the tie rod dust boot, and weird gurgling sound happens.Does this mean the rack is fked up?, or does it mean i need new tie rods?. The bushings are a little worn on the drivers side inner tie rod but the rod itself is not bent or anything....
nanner47 is offline   Reply With Quote
Old 10-13-2007, 12:57 PM   #2
frsh2fourty
frsh2fourty's Avatar
frsh2fourty has a spectacular aura aboutfrsh2fourty has a spectacular aura aboutfrsh2fourty has a spectacular aura aboutfrsh2fourty has a spectacular aura aboutfrsh2fourty has a spectacular aura aboutfrsh2fourty has a spectacular aura about
Send a message via AIM to frsh2fourty
I am not positive, if its a leak or not, but I read on a few forums that on 240s, using power steering fluid causes the seals to deteriorate, and that you have to use, don't quote me on this but, automatic transmission fluid. I could be wrong on the alternate fluid to use, but I know that using the power steering fluid has been known to eat away at the seals. I am not sure what all needs replacing, but i'm sure a search can find out more details.
frsh2fourty is offline   Reply With Quote
Old 10-13-2007, 04:02 PM   #3
nanner47
its weird, it only leaks when i jack up the car, i jacked it up from the subframe, and it would leak out with the tires in the air, but when i lower the car and do the same thing, it doesnt leak at all... but the powersteering belt still gets stuck at full lock, maybe the p/s pump is worn?
Old 10-13-2007, 05:23 PM   #4
Sil-Abc
Sil-Abc's Avatar
Sil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfection
Send a message via AIM to Sil-Abc
ur steering rack is getting to the point of being useless and broken. it shouldnt leak at all period. ull need to fix the seals or get a refurbished rack and sometimes whenever the rack starts to go out/leak, ur ps pump goes out along with the rack. so the sooner u fix that rack, the sooner u can preserve that ps pump.
ALSO frsh2fourty is right, u need to use AT fluid and NOT POWER STEERING fluid.
IM JON WAYNE ESQ.... bitch
Sil-Abc is offline   Reply With Quote
Old 10-13-2007, 05:29 PM   #5
burnsauto
burnsauto's Avatar
yeah i'd get a new rack. if you have aftermarket inner tie rod ends, and you plan on keeping them, i'd pull them. most new racks come with new inner tie rod ends and require a core of the old rack and pinion.
you're right about the fluid though. ive worked on 100% unmolested s13s where they use automatic transmission fluid. auto trans fluid helps with seals and such becaus when it heats up, it expands, so if you have a small leak and arent running tranny fluid already, you can throw some in at a first step towards fixing the leak.
Old 10-13-2007, 05:34 PM   #6
AznDrftr.
AznDrftr.'s Avatar
AznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond reputeAznDrftr. has a reputation beyond repute
Send a message via AIM to AznDrftr. Send a message via MSN to AznDrftr. Send a message via Yahoo to AznDrftr.
Auto tranny fluid? Wow, never knew thanks a lot for that info.
My buddies is leakin to but its leakin from that joint pivot point where you move the steering wheel left to right, it oozes out of that, but im assuming i can just replace that and be good?
I think its like a seal in there.
AznDrftr. is offline   Reply With Quote
Old 10-13-2007, 05:44 PM   #7
ae13bravo
ae13bravo's Avatar
ae13bravo is a name known to allae13bravo is a name known to allae13bravo is a name known to allae13bravo is a name known to allae13bravo is a name known to allae13bravo is a name known to allae13bravo is a name known to allae13bravo is a name known to allae13bravo is a name known to allae13bravo is a name known to allae13bravo is a name known to all
Send a message via AIM to ae13bravo Send a message via MSN to ae13bravo
Yeah bro, just get a new rack like burnsauto said. My rack was doing the same thing. So i replaced it. Its really easy to do. The atf stuff is true. My refurbished one came with atf in it. thats how I found out about the ATF for the power steering. I payed 100 for mine.
ae13bravo is offline   Reply With Quote
Old 10-13-2007, 05:47 PM   #8
SoCal-s130
Where did you get your's for $100? Mine needs replaced as well and the lowest price I have found is 200. But I think these are brand new.
Old 10-13-2007, 05:48 PM   #9
WERDdabuilder
WERDdabuilder's Avatar
PS fluid will fuck yo shit up!
dexron 3.
and yea, where did you get it for 100? i need to replace my rack asap.
When the power of love overcomes the love of power, the world will know peace
Old 10-13-2007, 07:05 PM   #10
ae13bravo
ae13bravo's Avatar
The one I got was a refurbished one. But yeah I got for around 100 bucks plus core. PM me if you guys want more info.
Old 10-13-2007, 07:07 PM   #11
nanner47
are DE racks compatible with SOHC car's? ive got a 90 and id like to swap he rack from my friends 91 240 parts car
Old 10-14-2007, 05:35 PM   #12
nanner47
anyone?............
Old 10-14-2007, 05:49 PM   #13
burnsauto
burnsauto's Avatar
yeah, it'll work, same part numbers..
Old 10-15-2007, 01:27 PM   #14
ae13bravo
ae13bravo's Avatar
s14 rack and Pinion for 120 Plus core
dexron 3.
Alright..... This for all of those of you guys that wanted to know where I got my Rack and Pinion. Its one of my friends shop, K&E 2 ...Its in El Monte, CA.....Number is 626 575-1966. Tell them Alex reffered you to them and that you are from zilvia.net and he will hook you guys up with a refurb rack for 120 plus core. . PM me if you have any questions. These are racks for the S14. Not sure about the S13's. oh yeah you guys have to pick it up. they dont ship or deliver. But if you need it really bad send me a pm and I'm sure we can work something out.
Old 10-15-2007, 01:51 PM   #15
Munch
Munch's Avatar
Munch is an unknown quantity at this point
man thats a damned good price...from kragen its nearly 300 bucks and even with the associate discount, still like 230. Wish that place wasnt all the way down there or else ide get one too.
Munch is offline   Reply With Quote
Old 10-15-2007, 05:52 PM   #16
WERDdabuilder
believe they use the same rack. correct me if im wrong.
thanks for the info.
Old 10-16-2007, 03:27 PM   #17
ae13bravo
ae13bravo's Avatar
s14
No. They are different part numbers.
Old 10-16-2007, 03:38 PM   #18
Nikeboy355
Nikeboy355's Avatar
Nikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond repute
I've purchased from K&E and they always have good parts and great prices...
Much better than Autozone!...
Nikeboy355 is offline   Reply With Quote
Old 10-16-2007, 04:24 PM   #19
ae13bravo
ae13bravo's Avatar
WAY BETTER Prices!!! Thats been my auto parts store for the last three years.
Old 10-16-2007, 04:31 PM   #20
Slowrolla97
Slowrolla97's Avatar
Slowrolla97 is an unknown quantity at this point
Send a message via AIM to Slowrolla97
A lil off topic but if you guys are going out and buying racks see if they have any hicas racks. I have one in my car and I love it. Steering is quicker and feels better. Also get aftermarket bushings for the rack. That is one over looked part that makes a world of difference
Slowrolla97 is offline   Reply With Quote
Old 10-29-2007, 11:17 PM   #21
nicku
nicku will become famous soon enoughnicku will become famous soon enoughnicku will become famous soon enoughnicku will become famous soon enoughnicku will become famous soon enough
the hicas rack will work on the front?? I thought the hicas rack is on the rear, isnt it? and by the way, I found something on ebay. and it is called "rack and pinion" is it the one i am looking for?
nicku is offline   Reply With Quote
Old 11-05-2007, 05:42 PM   #22
burnsauto
burnsauto's Avatar
the front rack and pinions between the fws and the aws (hicas) systems are different.
and yes....a rack and pinion is what you're looking for.
