Old 10-25-2007, 02:50 PM   #1
Curb King
Curb King's Avatar
Curb King is an unknown quantity at this point
SR S14 SR20 Motor Problems
So i finished my swap and was starting it up. It started fine but was idling around 2k but smooth wasn't too woried about that. I noticed a leak coming from one of my turbo lines It was a milky brown color. I immediatley shut off the engine and pulled the dipstick. Crap the oil was a milky brown color. I also was runing it without the raiator cap and i had coolant shooting out the radiator. This led me to believe that i had a blown head gasket. I took the head off, and the gasket looked fine. There was no blow by on the head or block. I measured the head and it wasn't warped. I couldn't even fit .010 in any spot. I turned the crank over and checked the cylinder walls. I couldn't see any cracks or holes. Anyone got any suggestions on other things i could look at or other tests i could run?
Curb King is offline   Reply With Quote
Old 10-25-2007, 03:07 PM   #2
KA-Owner
KA-Owner is an unknown quantity at this point
u sure its not transmition leaking or Brakes lines or any fuel lines or injectors??
KA-Owner is offline   Reply With Quote
Old 10-25-2007, 03:32 PM   #3
S14DB
AFC #1
S14DB's Avatar
You sure the Turbo wasn't blown?
Old 10-25-2007, 03:37 PM   #4
Curb King
Curb King's Avatar
If the turbo was blown would that cause the radiator fluid to shoot out of the radiator cap. I know the turbo needs to get rebuilt cause it doesn't sound healthy neverhad a turbo car before.
Old 10-25-2007, 06:32 PM   #5
Curb King
Curb King's Avatar
Also does it matter if the metal straight edge reaches all the way across the head or not?
Old 10-25-2007, 06:40 PM   #6
S14DB
AFC #1
S14DB's Avatar
Did you do a leak down test?
Old 10-25-2007, 06:44 PM   #7
Curb King
Curb King's Avatar
Not yet but once the head goes back on i will. I was thinking if i did that i with the turbo off i could rule out the engine as the culprit.
Old 10-25-2007, 08:35 PM   #8
jskateborders
jskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond repute
Send a message via AIM to jskateborders
Your headgasket might just be thinner in some spots from overheating. You have to get a new headgasket anyways, so see if that fixes your problem. If not, dare I say cracked block? Is that common with the sr aluminum blocks?
jskateborders is offline   Reply With Quote
Old 10-25-2007, 08:45 PM   #9
reflexdb
reflexdb's Avatar
reflexdb is making a name for him/her selfreflexdb is making a name for him/her selfreflexdb is making a name for him/her self
Send a message via AIM to reflexdb
Well, definitely sounds like you've got coolant in your oil, hence the milky color. That shouldn't be there. I would also guess blown HG. Replace.
reflexdb is offline   Reply With Quote
Old 10-25-2007, 08:46 PM   #10
Max_PSi
Max_PSi's Avatar
Max_PSi will become famous soon enoughMax_PSi will become famous soon enoughMax_PSi will become famous soon enough
You replaced all the fluids b4 you started the car correct?
How long was the car running for? The only time you'll really have water shooting out of the rad is if its already overheating.
Max_PSi is offline   Reply With Quote
Old 10-25-2007, 09:09 PM   #11
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
i agree on the hg being the problem. put it back together /w a new gasket (might as well go commetic or something spiffy + arp studs), don't reuse the headbolts. however it wouldn't cause you too much headache to take your head to a machine shop and just have them pressure test and deck the thing. not that much money at all. i think you'll be fine once you reassemble if the head is ok.
i would have suspected hg as well if it were me...however i wouldn't have a pulled the head until i did a leakdown & compression test. gl man
Dave =]
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 10-25-2007, 10:48 PM   #12
Curb King
Curb King's Avatar
There was no blow by that me or my buddy could see on the hg. I have an apexi hg waiting so im ok in that area. The car was only running for a total of a minute and thats not continuos just made sure all the cylinders where firing and had oil pressure. Is it still possible that the hg was blown or thinned out even tho there wasn't any blow by.
Old 10-25-2007, 11:12 PM   #13
GabeS14
GabeS14's Avatar
GabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfection
Dave =]
totally agreed....get ARP headstuds since your doing HG!!
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap.
GabeS14 is offline   Reply With Quote
Old 10-26-2007, 01:21 AM   #14
Koopa Troopa
Koopa Troopa's Avatar
Koopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfection
Send a message via AIM to Koopa Troopa
My car with 270 cams doesn't even idle that high..... I'd play it safe and get the head decked anyways.
Buy my Stillway shifter!
Koopa Troopa is offline   Reply With Quote
Old 01-05-2009, 08:31 AM   #15
obsolete
obsolete is an unknown quantity at this point
Old thread bump!
If there was air in your system, would the radiator be shooting out coolant? I was bleeding my system the wrong way and it started to shoot out coolant after a while. stupid me.
1. turn car on
2. add coolant
3. engine reached operating temp.
4. coolant started to bubble a bit in the fill hole
5. little bit later, smoke started coming out and then coolant gushing out
I will bleed it properly, but wanted to see if what i did will cause coolant to gush out. if not maybe something else is wrong.
obsolete is offline   Reply With Quote
Old 01-05-2009, 08:41 AM   #16
95KA-Turbo
95KA-Turbo's Avatar
95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of
This is a mighty old thread to bump...but good job searching.
When I first put my motor in w/ new turbo lines and what not it shot coolant all over the place, haha. It was not continuous though, it was like one big bubble and was over.
I'm not so sure about your coolant "smoking" though. Do you just mean it was hot and steaming? That seems bad - because that means you're creating vapor and not cooling efficiently.
Instagram - SJKnoop
95KA-Turbo is offline   Reply With Quote
Old 01-05-2009, 08:53 AM   #17
obsolete
well, it was almost all water actually. there was considerable amount of steam coming out. what could cause this? temp gauge stayed in the middle. do radiators ever go bad? how could i tell?
