sr20det timing
what can cause my timing to be way off the mark?i checked the timing and it was beyond 20deg the marks werent close to the needle....i think it can be a bad knock sensor...when i try to adjust it to 15deg i have to move the cas all the way counterclockwise and when i do that the ehxaust smell like gas....
ok i checked the timing again and this time from the entire #1 coil pack harness and was at 15deg.....but i still dont get why it was way off the i check it from the black wire in back of the valve cover?someone?
Sometimes when you use the wire at the back of the motor, if you have the pickup flipped the wrong way, you will get a wildly inaccurate timing reading. Try flipping the pickup around the wire and see if the reading goes crazy again. Whichever value is lower is the correct one (IIRC)
Amateur snowboarder, music buff, bedroom documentarian, closet Nissan fanboy, apprentice mechanic, certified Honda nut, EFI 101 attendee/graduate "You are going to work all your life to become an overnight success." -Warren Miller |
