Old 11-16-2002, 11:07 PM   #1
wpayne
wpayne's Avatar
wpayne is an unknown quantity at this point
I'm just looking around and I just want to make sure what the offset is. Why should I take it into consideration when buying rims and what is a good offset for the 240 S13 4 lug? What ranges can I go with or what is acceptable or optimal?
Too many people use cars as an extension of their PENIS and they make me sick. A car is to get you from point A to point B or for motorsports. Not revving around town at stop lights.
Check out my mods!: 50,000watt super amp and JDM lights!! Yeah right...
S13 Silvia K's I got for free (I'm in japan now)!! Woot woot!
'99 25GT-T Skyline (I don't want to list all the parts) http://welcome.to/skylinegtr
'92 240sx HB
wpayne is offline   Reply With Quote
Old 11-16-2002, 11:20 PM   #2
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
there is a LOT of info out there on this subject.  SEARCH.  both here and google.
basically, the offset is an indication of how far away from the centerline of the wheel the back of the mounting pad is.  imagine slicing the wheel in half.  however much space is between that halfway point, and the part that actually touches the hub is the offset.
stock S13 wheels are 15x6 +40mm
type in "wheel offset calculator" in google and figure out some good combos for you (after measuring how far away you are from "flush" with the setup you have now).
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 11-16-2002, 11:27 PM   #3
adey
adey's Avatar
adey is an unknown quantity at this point
Keep in mind that the offset that looks "best" on our cars is also highly subjective.
Some people like the "flush-with-fender" (there's a japanese term for this that slips my mind) look, some people like their wheels completely tucked inside the body, and others like the wheels to stick out of the body...
For me, "best" offset for a 15x7 wheel is between +5 to +15 in the rear, and about +20 in front.
As the wheel's width increases, offset should move down as well, if you want to retain space between coilovers/suspension and the tire/rim (so that you don't rub).
Instagram: @SX180HKG
adey is offline   Reply With Quote
Old 11-18-2002, 12:20 AM   #4
wpayne
wpayne's Avatar
Ok, the reason why I'm asking is because I found a set of used rims that are 17x7.5 with a +42mm offset. These are the results of the Wheel Offset Calculator:
"The clearance from stut housing to the inside of the wheel will be 21mm LESS
The outside edge of the wheel will EXTEND an extra 17mm"
This means there will be less space if I were to get an adjustable coilover setup right? What if I were to upgrade my breaks. How would this come into play?
'92 240sx HB
Old 11-18-2002, 09:06 AM   #5
uiuc240
uiuc240's Avatar
yes, you will have less room for coilovers.  and i can almost guarantee that Z brakes won't fit with that offset.  however, offset is NOT the issue with Z brakes....you need to be checking the spoke design.  each wheel will fit differently.  for instance, a 15x7 +5mm SSR Reverse Mesh won't fit with Z brakes either...  does that make sense at all?
Eric
2002 Mazda Protege5
