Old 12-06-2001, 09:56 PM   #1
240sxspeedracer1
240sxspeedracer1 is an unknown quantity at this point
Send a message via AIM to 240sxspeedracer1
I have a '90 240sx.  It cranks good, but sometimes it doesnt crank at all.  It has nothing to do with the battery or the alternator but this is the problem....
When i go to crank it, it doesnt even make a cranking sound(like if the battery was dead) &nbsp;then I shake the car(I jerk my body forward to move the car) and then it turns on fine. &nbsp;What the heck kind of problem is that?<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>? &nbsp;I dont understand it at all.. &nbsp;So when I shake the car, I crank it and it turns on perfectly, no problems while running either...help me, somebody told me its the ignition switch...is that possible?
240sxspeedracer1 is offline   Reply With Quote
Old 12-06-2001, 09:58 PM   #2
240sxspeedracer1
BTW, I DONT JUMP START THE CAR, AND I DONT ROLL IT INTO A START, i JUST SHAKE THE CAR AND THEN AFTER SHAKING IT IS PERFECT.
Old 12-06-2001, 09:58 PM   #3
Guest
Posts: n/a
a loose connection somewhere
Old 12-06-2001, 10:06 PM   #4
240sxspeedracer1
loose connection to battery? &nbsp;the two wires connecting to pos and neg are really tight on the battery. &nbsp;what kind of wires besides those?
Old 12-06-2001, 10:14 PM   #5
Guest
Posts: n/a
i dunno..... check anything that might cause a non-starting problem... ignition system especially.
Old 12-06-2001, 10:17 PM   #6
Zenki Two40
Zenki Two40 is an unknown quantity at this point
yeah, sounds like somethin' ain't goin' through right (wiring). cuz when ur shaking it it's probably just catching on, i'm having a problem like this w/ my stereo speakers in my room right now <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'> .
Zenki Two40 is offline   Reply With Quote
Old 12-07-2001, 01:10 AM   #7
misnomer
misnomer's Avatar
Check the button and wiring under the clutch. If that switch isn't activated, nothing will happen.
Old 12-10-2001, 10:16 AM   #8
KoukiS14
KoukiS14's Avatar
KoukiS14 is an unknown quantity at this point
Send a message via ICQ to KoukiS14 Send a message via AIM to KoukiS14 Send a message via Yahoo to KoukiS14
Had the same problem on our 90 Stanza. . same KA24E engine. . &nbsp;It turned out to be a loose wire, so sometimes we'd have to pop the hood and plug it back in. . wasn't really &nbsp;an issue when we found that out. .
-Rob
KoukiS14 is offline   Reply With Quote
Old 12-10-2001, 10:29 AM   #9
NoTuchn
NoTuchn is an unknown quantity at this point
theres some loose wiring somewhere... check battery, alternator, ignition, starter, etc. wires.
NoTuchn is offline   Reply With Quote
Old 12-10-2001, 10:48 AM   #10
whateverjames
whateverjames's Avatar
whateverjames has a little shameless behavior in the past
Send a message via AIM to whateverjames
yuuup. i've had that problem a lot, that white powdery stuff gets built up on the terminals, and the wires were loose. i put lithium grease on the terminals (after cleaning them) and tightened up the wires, and now it starts up every time.
whateverjames is offline   Reply With Quote
Old 12-10-2001, 11:00 AM   #11
alchemist
alchemist is an unknown quantity at this point
its possible that there is a dead spot on the starter. &nbsp;Shaking the car decently can cause the starter to move a bit and allow it to start. &nbsp;to test this theory. &nbsp;do this. &nbsp;obviously while in neutral. &nbsp;If it doesnt start one day, dont move anthing, or shake the car......go and apply 12V directly to the starter. &nbsp;If she doesnt turn, and you didnt shake the car, &nbsp;that means that you most likely found the culprit, a bad starter. &nbsp;
alchemist is offline   Reply With Quote
